My Mustang Shuts Off After I Get Off Of The Highway Whats Goin On???
Old June 9th, 2008, 03:48 AM   #1
2004 MUSTANG GT
low 14's
GTSHAKER is on a distinguished road
My 04 mustang gt shuts off after i get off of the highway. the rpms will go under 1000 jump back up to 1000 then die. i am able to start it right back up and it seems to run fine minus the low rpm's while ideling, the car has longtubes and the cats are off i think the 02 sensors were takein off as well. i just had a tune up and only use premium gas. i cant think of what the problem would be since i take great care of my car, any ideas?
Old June 9th, 2008, 03:52 AM   #2
bullitt5576's Avatar
2001 Bullitt
bullitt5576 will become famous soon enough
did you check to see if your air filter fell off?
MM NEW EDGE COBRA CREW #2
Old June 9th, 2008, 03:56 AM   #3
2004 MUSTANG GT
low 14's
no i didnt does that cause it?ill check in the mornin but when it shuts off my battery light will come on then i just start it back up and my radio turns off so im thinkin electrical its not gettin hot or anything
Old June 9th, 2008, 03:59 AM   #4
2001 Bullitt
check both your terminal connections for corrosion and to see if they are both tight, if your air filter came off it can do all sorts of messed up things, so check that
Old June 9th, 2008, 04:01 AM   #5
2004 MUSTANG GT
low 14's
ok thanks appreciate it. i ran out and checked one of my terminals is kinda corrodid but not bad. my air filter is still on tho
Old June 9th, 2008, 04:20 AM   #6
2004 MUSTANG GT
low 14's
could it maybe be the altenator or bad battery?
Old June 9th, 2008, 07:25 AM   #7
FoxHoss's Avatar
02' GT
FoxHoss will become famous soon enough
Send a message via AIM to FoxHoss
is it an auto or a standard? may not apply to our cars but i dunno, ive got a stick. i know on a lot of cars i saw when i worked in a small shop, they would come in with a similar problem and it was because the converter lockup solenoid was going bad. again i dunno if our cars use em, but thats what it sounds like to me
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences
02' GT ~ Twin Screwed 469hp/493tq
Old June 9th, 2008, 03:26 PM   #8
2004 MUSTANG GT
low 14's
its a standard
Old June 9th, 2008, 03:33 PM   #9
B0B
Boost gets you laid
B0B's Avatar
2001 Mustang GT
12.93@113.7 (on the 18's)
B0B is just really niceB0B is just really niceB0B is just really niceB0B is just really nice
Send a message via AIM to B0B
with your car running, try disconnecting the plug on your idle control valve. if the car tries to die when you unplug it, your problem is elsewhere. but if you unplug the connector and there is no change then your IAC valve is likely the culprit. the surging idle kind of gave me the idea that it could be a bad valve.
'01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress
2003 Rubicon (wheelin rig)
2008 Silverado 4x4 (towin rig/road queen)
2009 KTM 450 XC-W (Brap Brap!)
Old June 9th, 2008, 03:43 PM   #10
stanginit's Avatar
stanginit is on a distinguished road
Your battery light will be on....this is normal when the car is not running.
'99 GT, BBK Long Tubes, BBK X-Pipe, Flowmaster Delta 40's Catback, Accufab 70mm TB, C&L Inlet Pipe and MAF, 3.73's, Eibach Pro-Kit, Tokico Ilumina 5-way Ajustables, Granetelli Upper and Lower Control Arms, 18" Chrome Bullets
Old June 10th, 2008, 04:12 PM   #11
2004 MUSTANG GT
low 14's
my mechanic buddy thinks it could be doing it cuz my o2 sensors are off
Old June 10th, 2008, 04:45 PM   #12
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
zinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud of
if its shutting off randomly it could be the fuel filter has gone bad. I had that problem, changed mine out and problem was fixed
Mods in garage. New mods, new track times soon.
Old June 10th, 2008, 04:45 PM   #13
Moderator
Could also be a bad fuel pump.
Old June 10th, 2008, 05:37 PM   #14
1992 Lx
11.39@119.24
no o2 sensors at all?? doesnt your car run like complete shit?
Old June 10th, 2008, 05:54 PM   #15
2004 MUSTANG GT
low 14's
yea actually it runs pretty good this is the first mech problem i have ever had with it idk why they took out my o2s when they put on my longtubes but im hopein maybe the diablo predetor will fix it so i can just tell the ecu the o2 sensors are off and turn off the egr valve but ill check out my fuel filter as well, i just got it changed about 4000 miles ago and only use premium but ill check it thanks
Threads Similar to: My Mustang Shuts Off After I Get Off Of The Highway Whats Goin On???
1996 3.8 mustang shuts off when put into gear tarat15429 V6 Mustangs 6 July 23rd, 2007 10:40 AM
Car Shuts Off new 5.0 94-95 7 March 26th, 2007 05:10 AM
95 Gt shuts off new 5.0 94-95 0 February 25th, 2007 06:16 PM
starts then shuts off sean97gt 96-98 2 January 18th, 2007 01:45 PM
starts then shuts off sean97gt 96-98 3 January 18th, 2007 02:00 AM
