![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 15 reviews
best way to flush radiator and all??
this water and all is pure brown and gritty and stuff. Flat NASTY! what is the best way to flush this. Ive heard you can buy radiator flush. Worth it? give me some steps. Thanks!!
Proud American
1. Empty it.
2. Fill it with water. 3. Run the car til its warm. 4. Drain it again. 5. Fill up agian with water. 6. Drain after warm again. Do this until the water being drained comes out clean... Then put in your 50/50 coolant mix...
RIP Travis Billings ![]() 1996 Mustang GT - Racecar 1995 Mustang GT - Daily Driver Special Thanks to: PoorMan Motorsports Full Parts Supply MIA Motorsports For any Chassis Related Work or Drag Wings 25.3 SFI Chassis Build Never Lift Racecars |
aight cool.
Proud American
BTW it can take up to 8 times of just filling it with water. Its a long process, but this way will help clean the block too...
1999 Mustang GT
unless your an earth friendly hippy i would just pull it over a drain and flush it.
remove the petcock from the bottom of the rad on the passenger side and the engine block drain plugs(if you want to, i usually dont). Fill it up and run your cleaner through it, if your gonna flush it u should buy a coolant system cleaner to run through. Then just let a hose run into the overflow and let the car run until nothing but pure clean water is coming out of the drainage. The hose trick is a nice way to avoid taking the block plugs out. It allows u to just run enough water through it that it cleans the whole system anyways. Dont buy 50/50 because ur getting ripped off. Instead of paying for half water get pure coolant and mix it yourself. Run it again until at normal operating temp, check all hoses and gaskets for small leaks and call it a day.
BBK CAI, March UDPs, Eibach Sportline Springs, MM C/C plates, Koni Yellows, Centerforce DF clutch, FRPP Billet Flywheel, B&M Pro-Ripper Shifter, BBK ceramic LTs, BBK catted X-Pipe, SLP LM1, EBC rotors, 4.10 FRPP gears 5.4 4V coming soon |
im a construction mechanic and when we flush coolant systems we drain the coolant and fill it back with water and put about half a cup of the powder type dishwashing soap(cascade) in the system and let it run then drain it then run it with pure water then drain it and replace the coolant...i am acutally going to do my coolant system this weekend...ill let you know how it goes...and im topping mine off with royal purple purple ice :-)
2004 Black Mustang GtWhen I see a 5.0...I respect my elders. |
48.47@ 12.58
You mean your top radiator hose? see if it has a hole or the clamp came off.
#8 | |
KB'd GT
used to i would take the hose off the heater coil,an drain the radiator an put the water hose into the hose on the heater coil an flush it also.both hose on the coil also 1 at a time.and it also pushing it threw ur heads and stuff.then fill ur radiator start the car. let the thermostat open an after it runs for ahile,flush it again threw the radiator
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
Id go with what mustangmatt said thats what I usually do, just drain what I can, refill with water, run it a bit, and repeat until I get 100% water. For cleaning out the brown gunk in the reservoir if you have any you can use the radiator flush stuff. I usually just pull the reservior off and fill it with 1/3 the bottle of flush and water and repeat until I use all the flush that way its a bit more concentrated in there to break down all that junk vs that little container of flush in 14qts of water. then drain and refill to whatever mix you prefer. Each to their own but im running 70% water 30% zerex original.
I just read the rest of the posts and what joe said would be quite a bit more time saving. Never though about doing it that way. Last edited by ajm; February 11th, 2009 at 06:29 PM. |
WOW... this was an old thread. F! LOL!
I was like.... WTF, i didnt post that.
![]() 4.75 MMR 900se Livernois ported heads HP 292s blower cams Procharger D1sc at 20+ psi IW 15% OD pulley (and more bolt ons) E85 ![]() Tune/numbers coming shortly!! |
wow haha, i didnt even look at the dates i just seen it at the top and seen all the replies were today.
Threads Similar to: best way to flush radiator and all??
| radiator flush | sivart | 5.0 Mustangs | 14 | December 5th, 2009 04:42 AM |
| coolant flush question | juan310 | V6 Mustangs | 12 | July 20th, 2007 01:51 PM |
| Radiator Flush | MustangMo | V6 Mustangs | 12 | June 6th, 2007 06:50 PM |
| I NEED A... Radiator flush | El_Cangri | V6 Mustangs | 13 | May 18th, 2007 02:10 PM |
| Fluid Flush/Changing | DSEZ | General Tech | 1 | January 31st, 2007 05:05 PM |
