#21 |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
there is an accessory wire (usually 2) off the wire harness from the key switch. it is an actual accessory wire, that is where you need to tap off for switched 12+ power scource. i used a high to low input converter and tapped off my rear speakers. if you are in good with an aftermarket accessory shop, they can get a wire color code guide off directtech.com
Threads Similar to: Those of you running aftermarket sub/amps with the stock headunit
| Bridging stock amps (front door subs) | tribaltek | 2005 - 2010 | 17 | May 20th, 2008 05:30 AM |
| How to install aftermarket headunit | zinc02GT | Audio/Video | 1 | February 2nd, 2008 02:20 AM |
| Stock Amps | Reset | Audio/Video | 4 | August 10th, 2007 01:57 PM |
| Stock 460 Amps! | jerb43 | Audio/Video | 1 | November 15th, 2006 10:10 AM |
| Quick Question (Stock Amps) | mikethetigerrr | Audio/Video | 9 | November 6th, 2006 12:47 AM |
