Popping In Steering Column
i have a few problems with my car, maybe someone can help me with. first off there is a popping sound coming from the steering column. second there is a noise coming from the tranny area which sounds like rubbing only when i first come out of gear. third and most annoying is the rear end whinning in the car. can anyone help? there are aftermarket gears.
2002 gt bbk fenderwell CAI, flowmaster 2 chamber, steeda tri-ax |
#2 | |
Re: popping in steering column
i would bet you the whining is from your ring and pinion set or the bearings that go with them, prolly just need to get a bearing kit, while your at it change to 4.10's or 3.73's
#4 | |
But they do whine !!! so it might be possible they are the source of the whine seeing ass he said it came from the rearend and the ring and pinion set are in the rear just my two cents
AS srry not ass
#7 | |
I would think it has to do with a number of things such as product quality, machining specifications and installation, however some stock vehicles do make some gear wine.
Re: Popping In Steering Column
2004 GT....4.10s, SCT X Cal2, BBK Lts, BBK O/R Xpipe, Flowmaster catback with Super 40 mufflers, BBK 75mm TB & Plenum, K&N Filter w/no silencer, Steeda UDP, Steeda TriAx, and Steeda G-Trac stages 1, 2, 3, and 4, blower is on the way!!! |
#10 | |
popping
ok the steering column is a easily fixed, go under the the wheel and you will see a cover pop that off and you'll see some c type bolts holding the column in just tighten them and it will go away.
Ill give it a try....thanks
i dont know I 'see ass' around my car too..
Anyway I have the same popping in the steering column, particularly when I make left turns at a low speed. I thought I may have dented the lower control arm while jacking the car up but it looks fine, somebody told me it might be the steering rack..regardless, my car is not under warranty. If there was something loose how much do you think Ford would charge me to tighten a few bolts?
#15 | |
I install alot of gears. Both oem stuff at work and performance stuff at home. Not all gears are created the same and can & do make noise even when set up properly. The newer stuff from FRPP stinks!! They are made by Motive gear and do make noise no matter how they are set up. Not bashing you here, but since you work where the oem stuff is made, what happened to the Explorers, F-series, expeditions, and mustang ring and pinions? I seem to replace a lot of them at the dealership due to noise? All the tsb says about the gear sets are they are a "more robust" design.......... |
Threads Similar to: Popping In Steering Column
| Popping out of 2nd | weems | 4V / SVT | 21 | June 10th, 2010 01:53 PM |
| still popping through intake. Help!!!!!!!!!!!!! | nasty92LX | 5.0 Mustangs | 1 | September 19th, 2007 01:37 PM |
| Decreasing power steering pump pressure for tighter steering | 83 5.0 | 5.0 Mustangs | 6 | January 7th, 2007 08:24 PM |
| Car Is Popping Out Of Gear | 97CobraSvt | 96-98 | 9 | November 20th, 2006 09:02 PM |
| Clutch Popping | hmotes | 5.0 Mustangs | 10 | November 13th, 2006 12:25 PM |
