Discussing burnout help!!! in the 99-04 Forum. ok, i'm getting drag radials on tomorrow and taking the car to the track ...
Old June 11th, 2008, 06:56 PM   #1
00gtCoolGuy's Avatar
14.211 @ 93.0...4200 ft above sea level
burnout help!!!
ok, i'm getting drag radials on tomorrow and taking the car to the track on friday night...
only problem is i can't burnout to save my life!!!! i've tried heel and toe but i can't keep the car standing still...i usually dump it at 4000-4500 but the car will still take off on me...and sometimes i fuck up and don't even get the tires spinning only the clutch!!! nothings working...
this is all in 1st gear
4.10's, Hoosier DR's (stock intake, stock exhaust)...nitrous kit awaiting install
Old June 11th, 2008, 07:20 PM   #2
2003 Mustang GT
what the hell are you doing to dump your clutch at 4500 and your car is just hooking lol
Old June 11th, 2008, 07:25 PM   #3
lol, it doesn't hook...but i can't get it to just stay put...
Old June 11th, 2008, 07:52 PM   #4
Slayer of Douchebags
Drgnracin72's Avatar
mustangless
rev higher, rev to 5000-5500 and side step the clutch and get on the brake as soon as you can. if it still isnt working, your doing something wrong and in that case, id suggest a linelock
NUKE THE UNBORN GAY BABY WHALES FOR JESUS
Old June 11th, 2008, 08:10 PM   #5
DiZzyBonne's Avatar
2001 Ford Mustang Bullitt
It should be easier in the water box anyway.
Current mods:
  • Maximum Motorsports XL Full Length Subframe Connectors
  • Catted Bassani X-Pipe
  • Borla Stinger Catbacks
  • H&R Super Sport Springs
MM Bullitt Crew Member #1
Old June 11th, 2008, 09:27 PM   #6
'02SilverBullet's Avatar
Ok as they said before... A line Lock will help ya out on this but its really not NEEDED.
But in any case...
With the clutch IN and tranny in 1st. The way I get it done is I put 1 half of my right foot on the brake and with my ankle I kinda lean it over and ease on the gas at the same time. When ya start getting some RPMs with the brake on start releasing the clutch. When you feel the suspension preload or lurch forward. You can start giving her more gas and while still holding the brake with the same foot all while letting the clutch on out. When the wheels brake loose you can go ahead and get off the clutch all the way and get the left foot on the gas.
This is just how I myself do it. And it even took my a few tries to get it down.
Mods Include......
BBK CAI
MM Caster Camber Plates
Baer Decalla Drilled and Sloted Rotors
w/ painted callipers
Hypercoated 18x9 FR500 Rims
Eibach Pro Kit Lowering Springs
More to come.....!
Old June 11th, 2008, 10:13 PM   #7
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
burnouts without a line lock are realy hard on the input shaft for the tranny. spend a little money and get a LL. they are cheaper than fixing your tranny and replacing brakes. and when you get the hang of it, second gear will give you a better burnout.
Gone To Basic Training
Old June 11th, 2008, 10:15 PM   #8
usually when i tried sidestepping it i would mash on the brake too hard and it would just stall...i'll try it a couple more times in a bit
i'm going to get a line-lock soon...just needed a quick fix for friday
has anyone else this much trouble learning how to do this? or is it just me lol
Old June 12th, 2008, 12:15 AM   #9
RTRBURN's Avatar
Buy the SLP kit for the 99-04..easy install...everything is pre-bent and has the correct fittings for our Mustangs.
But till then, back into the water box, Put in 2nd Gear, Press the brake and clutch in with the same foot, bring Rpms to 4500 then slip your foot off the clutch, keep the rpms from 4-5k rpm, tilt your power mirrors towards the ground so you can see smoke coming from your wheel wells. Once you see smoke go about another 4-5 seconds then let off the brake and keep the rpms at 4-5k till it hooks. The reason you do it in 2nd gear is because 1st gear revs to quickly to keep under control and in 2nd your tires will spin faster.
Old June 12th, 2008, 12:21 AM   #10
01 nitrous injected GT
12s next time out...
i have the same problem but havent tried since i got my gears and heard it should be alot easier
Old June 12th, 2008, 12:31 AM   #11
347stroker's Avatar
Just takes practice man, I use the side step and usually dont have a problem. As said above you shouldnt have a problem at all in the water box.
Foxlake stage 2 heads, CMS stage 2 cams, Custom Diablo tune, BBK LT's, BBK O/R H, Bassani Race Mufflers, MGW STS, 75MM TB, K&N CAI, Eibach Sportlines, 4.10's
Mineral Gray Club Member #1
Threads Similar to: burnout help!!!
burnout COmustang Street 22 May 18th, 2008 01:52 PM
Your first burnout Tiller88 The Clubhouse 36 April 15th, 2008 01:23 AM
Iraq burnout vs. Europe burnout. Fryrice Videos 12 February 18th, 2008 07:42 PM
Best burnout ever! WAR-PARTY The Clubhouse 22 January 12th, 2008 04:55 PM
burnout bluemustang04 2005+ 16 August 6th, 2007 04:25 PM
