My Car Is Falling Apart
My 00' GT is on it's last leg I'm afraid. I just had to fix both rear axle seals, and for some reason it has started burning up all the oil in the engine. Also now when I accelerate, I hear a sound as if something is really straining under the hood. I so far have added a diablo sport chip, which messed up my stock computer and wouldnt allow me to start the car. I added Hi Flow Cats, CAI, .373 Gears, had the car lowered, and 18" Rims. I don't what to do with this car anymore.
Suggestions? |
unstoppable @ speed of light
Sell it before anything else happens to it!
Then look for a four valve for around 25,000 to 30,000 Of course if you don't want to spend that much money you could just look for a cheap foxbody car and save your money for a new engine and drivetrain setup. |
48.47@ 12.58
your high flow cats are probably causing the blow by which is an easy fix.
and did you tune the car for them? that could be the issue. another reason could be the tune didn't set properly. did you pull your fan and oil pump fuse before tuning it?
I had all those things installed by a racing shop. I didn't actually do any of the work myself. I think originally everything was tuned correctly but, like i said the chip malfunctioned and wouldn't let me start the car so I took it out. I guess I need to get it put back in.
00' GT CAI HI-FLOW CATS LOWERED DIABLO SPORT CHIP .373's |
RLY SRS
I think DIABLO is your problem...
Go with SCT... You are not the first that I have heard problems out of the Diablo products from... Get a good tune with the SCT and you will much happier...Or just buy and SCT XCAL 2 and have them tune with that... |
Thanks to google, I know what SCT XCAL 2 is (diagnostic computer)? Wish I knew what I was doing. I'll have to look into getting that chip fixed and look into the one you mentioned.
RLY SRS
SCT XCAL 2 is a flash tuner...
They can tune your car without having to use a chip... I think you should look into it... |
I have a hypertech at my house, would that work?
the diable and sct do the same exact thing its just whichever you choose or whichever one your tuner uses. as for the high flow cats causing blow by? explain that to me please. ive always been under the impression that blow by is caused by the piston rings failing or giving out.
Cigar Assassin
yeah, i had problems with my diablo and now have a sct and have had no problems. I am a beleiver now.
2008 Acura TL-S - 2008 Honda Pilot EX-SE - 2008 Cain F Big Bear Paradox ![]() |
the sct does by far have better software though
11.21@123 -150 shot
![]() iTrader: 1 reviews
I am going to be selling my Predator and going with the xcal due to my tuner only using that tuning software. For an off the shelf tuner, the Predator is not bad. It lets you change alot of parameters.
I need like a crash course in mustang modding. Where did you guys pick up the knowledge?
48.47@ 12.58
ok. no problem: in a nut shell when you have high flow cats (TUNE FOR THEM!!!) it takes longer for them heat up so your 02 sensors compensate by adding fuel (like when you first start your car and your rpms are a tad high) when you run rich for enough of a time eventually you will get blow by. and yes you are correct about the piston rings. when you run rich for too long of a time it causes them to give out.
ill buy the rear end gears off you :award
haha, sorry no. Not to mention I don't have the stock gears anymore, and that it took a mechanic, 4-5 hours to remove them to do the axle seals
MM's nicest mod, :)
yeah diablosport is your problem for one, i have one on my car, can't get it tuned cause the chip i have now works but when my tuner tried 3 different diablo chips on my car with a better tune my car died about 5 minutes later, my mechanic thru a sct chip on there with a base tune, not even for my cams and stuff and it ran for an hour before i shut it off with no problems.
06 Dodge MegaCab Diesel 455rwhp/815rwtq REAL TRUCKS DON'T USE SPARK PLUGS |
#18 | |
2002 GT K&N CAI O/R X-Pipe Race Bullit Mufflers SCT Xcal2 w/Custom Tune By RWTD 4.10 Rear Nitto D/R's FR500 Rims 17x9 17x10.5
BTW i bet you anything that if your using a chip as oppose to a flash tuner...and especially if its by diablosport, jet, or hypertech...then thats the problem. SCTxCal II...the best tuner on the market...getcha one!
90k miles, bought it at 20k. I abuse it sometimes, I thought that's the fun of it though. Regular oil, no synthetics. Whatever the stock oil reccomendations are is what i've been using.
Threads Similar to: My Car Is Falling Apart
| I give up... my car is falling apart | 00SoSlow | General Tech | 19 | August 11th, 2006 07:08 PM |
