Boost/vac gauge problem
Old June 16th, 2008, 12:36 PM   #1
00silvergt's Avatar
2000 Mustang Gt
00silvergt is on a distinguished road
Ok I have an autometer boost/vac gauge installed. I have the boost line tapped into the discharge tube and the vac teed into the Fuel pressure sensor. Then I have the vac line and the boost line Teed together and hooked to the gauge.
The problem I am having is that when everything is hooked up I am only reading half the amount of vacuum on the gauge that I should be reading, and No boost.
If I unhook one or the other, the readings are normal.
What am I doing wrong?
Tuned by Joe at Tricktuners.com
Old June 16th, 2008, 12:44 PM   #2
99mustanggtman's Avatar
1999 GT
99mustanggtman will become famous soon enough
iTrader: 7 reviews
Send a message via AIM to 99mustanggtman
heres how it should be done, the bypass valve needs to be tee'd to the fuel press. line, then you should have another teeinto one of the two vacuum lines coming out of the plenum, one of those lines goes into the fiel press. rail sensor and the other you need to tee into, altho it doesnt really make a difference, when you do that it should read correctly
Single 67mm turbo, ported pi heads, edelbrock vic jr. manifold w/HPP plenum, terminator shortblock, return fuel system... Goal 600+ rwhp.
Old June 16th, 2008, 12:47 PM   #3
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
i don't know where you put it really, when i had mine i had a dual t put in over on the left top left side of the engine compartment where the vac lines orginally come in. I cut the one hose, put the 4 way in and had the orginal line coming in, the gauge on 1 end, the line that went to my bypass valve on one side, and of course the other half of the orginal one at the 4th nipple.
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Old June 16th, 2008, 12:48 PM   #4
00silvergt's Avatar
2000 Mustang Gt
Ok thanks guys!! I appreciate it.
Old June 16th, 2008, 01:43 PM   #5
saleen73 is on a distinguished road
i had the same problem. i had to run a seperate power wire for each gauge. they would all turn on. but wouldnt read any boost or pressure. try running a seperate power wire
Old June 16th, 2008, 03:04 PM   #6
The Mean Green
MATT02GT's Avatar
MATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really nice
My Autometer guage only had 1 boost/vac line and 2 wires for power to the lights. The boost/vac should be all mechanical (will work without power). Just connect the 1 line into a vacuum line (mine is by the egr valve). You do not need to tee them off into seperate lines.
Bolt on list in Garage..
Old June 16th, 2008, 03:16 PM   #7
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
+1 Mine has only one line.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old June 16th, 2008, 03:24 PM   #8
MM's nicest mod, :)
i think he knows it only has one line, when we are talking about the T we are talking about T'ing it off the stock line. I don't see anywhere about anyone talking about 2 lines coming off the gauge. You should already be t'd off the stock line for the bypass valve so just either put a + looking splitter where the t is or t off further down the line.
Old June 16th, 2008, 05:15 PM   #9
The Mean Green
MATT02GT's Avatar
Am I reading this wrong?? Sounds like he split the one line????
Threads Similar to: Boost/vac gauge problem
Boost Gauge beheivjer 2.3 Mustangs 10 May 20th, 2008 01:44 PM
Boost Gauge...Need help ASAP!!! blackhavok 2005 - 2010 20 January 13th, 2008 01:21 AM
boost gauge prinzzz 2005 - 2010 1 December 30th, 2007 06:23 PM
Boost Gauge mmvi V6 Mustangs 9 December 26th, 2007 10:30 AM
