gear ratio? - Forums at Modded Mustangs
post #1 of 16 Old June 17th, 2008, 10:43 PM Thread Starter
rainier446's Avatar
gear ratio?
whats the factory gear ratio for the rear end on a 2000 GT?
2010 GT Black (as if there's any other color)
340hp 320tq
Black Mustang Club Member #2.0
rainier446 is offline
post #2 of 16 Old June 17th, 2008, 10:45 PM
BLK01SS's Avatar
If I am not mistake it is a 3.27 ratio
Topless Mustang Club Founder
2000 Mustang Gt 5.4 SOLD
2001 Camaro SS
Originally Posted by rk_2000_Z/28 View Post
Black C6Z06=pure, hot, nasty, unprotected sex
BLK01SS is offline
post #3 of 16 Old June 17th, 2008, 10:50 PM
The Mean Green
MATT02GT's Avatar
Bolt on list in Garage...... MM Insomniac Crew
MATT02GT is offline
post #4 of 16 Old June 17th, 2008, 10:52 PM Thread Starter
rainier446's Avatar
all i know is that my mechanic is telling me that the 3.73's in my car are factory....i bought the car a lil over a year ago and now they tell me that 1/4 of the pinion teeth are all chewed up and i have to replace it. just doesn't seem to me that factory spec rear ends are gonna do that, especially after 75,000 it just now decides to jack up? incorrect installation has to be the reason
340hp 320tq
post #5 of 16 Old June 17th, 2008, 11:07 PM
BLK01SS's Avatar
It definatly doesn't have 3.73 stock but if it does now and the pinion gear is messed up it probablly is from incorect install. Have you ever noticed a whine commin from the rear?
2001 Camaro SS
BLK01SS is offline
post #6 of 16 Old June 18th, 2008, 09:17 PM Thread Starter
rainier446's Avatar
I have never noticed a whine but there was some slack in the trans that I thought was either a missing tooth or horrible u-joints
340hp 320tq
post #7 of 16 Old June 18th, 2008, 09:20 PM
HMUSN's Avatar
iTrader: 11 reviews
if your teeth were chewed up you would know it man. trust me..
HMUSN is offline
post #8 of 16 Old June 18th, 2008, 09:23 PM
BLK01SS's Avatar
If there was any missing teeth I think it would have already broken by now. What do you mean by "slack" exactly?
2001 Camaro SS
BLK01SS is offline
post #9 of 16 Old June 19th, 2008, 05:10 AM
Achieving more N/A power!
gills99stang's Avatar
Send a message via AIM to gills99stang
I was about to say its 3.55 but I was thinking of the newer Mustangs. The 2000 Mustangs came with a 3.37 gear ratio.
http://www.miracerros.com/mustang/2000_specs.html
Maximum-Cars.com - 2000 Ford Mustang GT Information and High Resolution Images.
Brendan
'99 Mustang GT [ 318 rwhp N/A ] - SOLD ()
'04 F150 XLT SuperCab
gills99stang is offline
post #10 of 16 Old June 19th, 2008, 10:50 AM
2000 Ford Mustang Specifications
3.27
JLT - Accufab - MPH Heads - VT Stage 2 N/A cams
Manley Valves/Springs - Centerforce Dual Friction
BBK LT's - BBK o/r H - Bassani catback
FRPP 4.10s - XCAL2 - BBK UDP's
306rwhp/333rwtq
2000stangGT is offline
post #11 of 16 Old June 19th, 2008, 02:16 PM
cliffyk's Avatar
Find another mechanic, the 3.73s are not stock and as HMUSN said if "1/4 of the pinion teeth are all chewed up" you would know it--it would scream like a banshee under load...
-cliff knight-
My Mustang
SOLD! - 2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat,
PP 70mm TB & plenum, Ralco RZ_flywheel, RAM HDX clutch, 3.73s, 262 rwHP/305 lb-ft.
new ride - 1998 SL500, 5.0L 32V 326/347 HP/tq
cliffyk is offline
post #12 of 16 Old June 19th, 2008, 02:37 PM
yojoe600's Avatar
yea that guy does not know anything
Originally Posted by supermachone View Post
it was something like the tinman from the wizard of oz pinching off a tight fart...
Cat Club Co-Founder
yojoe600 is offline
post #13 of 16 Old June 19th, 2008, 03:03 PM
~C~
~C~, The Other White Meat!
~C~'s Avatar
Send a message via AIM to ~C~
def 3.27, and def take it to another shop....not a dealer please!
BLOWN Bumblebeast!
370 rwhp / 381 ft lbs
~Tuned by JJ at WMS
"Like the blind man says......We shall see...."
~C~ is offline
post #14 of 16 Old June 19th, 2008, 03:43 PM
Self proclaimed A-hole
White99stang's Avatar
yeah my rearend had missing teeth on the ring gear and you would know it trust me.
White99stang is offline
post #15 of 16 Old June 19th, 2008, 11:49 PM
US Air Force (retired)
Eagle2000GT's Avatar
2000 GTs come stock with 3.27 gears. After dynoing my car I had a tuner tell me that my speedometer was wrong and that I had 3.73 gears. When I had the car retuned the new tuner said he had to adjust my speedometer because it looked like I had 3.55 gears. I jacked up the car and turned the rear wheels. It looked to me like I had 3.27 gears. As it turns out, I have 3.27 gears. Whoever put in the white face gages put the speedometer needle in the wrong place.
Lift up the rear of your car and put a caulk mark on both the tire and the driveshaft. Turn the tire one complete revolution and count the number of times the driveshaft goes around. If it goes around 3 1/4 turns then you have 3.27 gears.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370.
USAF 1969-1996: Vietnam veteran. Aircraft maintenance. ICBM Operations. Research & Development.
Also own: 1997 Harley FXDWG, 1998 F-150, and 2002 Corvette LS1
Eagle2000GT is offline
post #16 of 16 Old June 20th, 2008, 04:46 AM
cliffyk's Avatar
Verifying indicator needle placement is one good use of the HEC diagnostic mode (click here). The digital vehicle and engine speeds displayed in the diagnostic mode are the actual values that the PCM and cluster electronics believe to be true.
The gauges themselves are just servos driven by the cluster electronics, the needles can be pressed on in any position to achieve best accuracy compared to the digital signal.
-cliff knight-
My Mustang
cliffyk is offline
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/76334-gear-ratio.html
MySpace.com - External Link Alert This thread Refback July 14th, 2009 03:11 AM
gear ratio? This thread Refback June 19th, 2008 06:41 AM
