Emergency/Parking Brake Spring Compressor?
Old June 19th, 2008, 02:01 PM   #1
Garhfer's Avatar
2004 Mustang GT Conv.
Garhfer is on a distinguished road
Send a message via AIM to Garhfer
Do they sell some type of tool that'll compress the spring for the parking brake on the rear calipers? I had to take off the bolt that holds the spring on to get to the caliper bolt with a damn rachet because the spring was in the way and a wench kept slipping off and now I can't get the spring back on it's like 2 inches away from the damn bolt when I put it in the hole it's supposed to slide into... these damn rear calipers are the biggest fucking hassle ever!
2004 GT Boosted by Vortech
Old June 19th, 2008, 02:23 PM   #2
99mustanggtman's Avatar
1999 GT
99mustanggtman will become famous soon enough
iTrader: 7 reviews
Send a message via AIM to 99mustanggtman
the way i did it just took patience, thats the only help i can offer, sorry
Single 67mm turbo, ported pi heads, edelbrock vic jr. manifold w/HPP plenum, terminator shortblock, return fuel system... Goal 600+ rwhp.
Old June 19th, 2008, 02:44 PM   #3
Garhfer's Avatar
On the parking brake spring? What tools did you use?
Old August 27th, 2011, 03:45 PM   #4
Ubida's Avatar
03 v6 Mustang Coupe
Ubida is on a distinguished road
Just did this myself. After hours yesterday, messing with the spring and finally getting pretty PO, I woke up this morning, and had a stroke of genius.
Tools needed:
1 zip-tie, needs to be heavy duty, cuz the spring has a lot of pressure in it.
1 set of vice grips
1 set of wire cutter
This is pretty self explanatory:
Start compressing the spring using the vice grips.
Tie the zip-tie around the spring, but allow the ends of the spring to be exposed, allowing it to grab.
Keep clamping the spring and tightening the zip-tie each time.
Repeat until the spring is compressed enough to fit back onto the bracket.
When you get the spring compressed enough, just fit the ends into the proper holes, and cut the zip-tie.
Old August 27th, 2011, 10:35 PM   #5
MineralGreyGT's Avatar
MineralGreyGT will become famous soon enough
^ I used a similar method except i used a bench vise which works a little better than the vise grips. I strongly recommend wearing safety glasses of some kind cuz if you compress that spring and it slips on the teeth that sucker has alot of stored energy and she goes flying. GL
http://img192.imageshack.us/img192/9175/sig1xts.jpg
Old August 27th, 2011, 11:42 PM   #6
86er's Avatar
so you were takin the rear caliper off and had to remove the parking brake spring? Extensions are a tool that lets you leave the spring on. Ive never had to remove a parking brake spring to take anything off of the rear brakes
Just a truck
Old August 28th, 2011, 12:52 AM   #7
Ubida's Avatar
03 v6 Mustang Coupe
Yea, don't judge me, but it was my first time messing with brakes, learning as I go.
Once I figured this out, it only took me about 10 minutes.
Gotta make do with what I have.
I don't have a garage or even a bench vise. Wish I had my own garage.
Old August 28th, 2011, 07:43 AM   #8
1999 GT 35th LE
99GT35thLE has a spectacular aura about99GT35thLE has a spectacular aura about
I've always used a big pair of channel lock pliers to squeeze the cable holder together and just slide the cable out.
Things work a lot better when you have a car on a lift!
Drive it like you stole it
Old August 28th, 2011, 11:29 PM   #9
86er's Avatar
Not judging just sayin home slice
Just a truck
Old August 29th, 2011, 12:10 AM   #10
Ubida's Avatar
03 v6 Mustang Coupe
lol, Home Slice
Threads Similar to: Emergency/Parking Brake Spring Compressor?
Emergency Brake WAR-PARTY The Clubhouse 4 December 16th, 2007 12:07 PM
Emergency brake cable help Newtgadget 5.0 Mustangs 1 October 16th, 2007 08:57 PM
emergency brake problems usmcsawgunner 5.0 Mustangs 4 June 15th, 2007 01:26 AM
parking brake spring beisenho Classic Mustangs 0 April 19th, 2007 10:12 PM
Emergency!!!!..............................Brake flames_blue V6 Mustangs 15 April 12th, 2007 08:28 PM
