I Poop Entirely Way Too Much
Blown 03 GT
New BBK throttle body and plenum
Any know anythin bout this? Are there any tests yet? It has the potential to flow better being on piece and at $250 its a great deal. Im upgradin my stock tb and plenum for my novi install so what do you guys think bout this thing? BBK: 1996-2004 Mustang 4.6L GT 78mm Throttle Intake
Bbk=stick
![]() HP 401 TQ 380 | Vortech V-2 SQ Intercooled | 410 Gears |Accufab 75mm TB | UPR O/R X Pipe | Flowmaster 40s Eibach Sportline Springs | Steeda U&L Rear Arms | Subframe Connectors | Steeda Sport Shifter |
Blown 03 GT
I was wondering more about the flow numbers
![]() iTrader: 1 reviews
looks pretty badass at least and the price is definitly cheaper then a bbk t/b and plenum
Just Another Bolt on GT [IMG]http://i45.tinypic.com/54f5ua.jpg[/IMG] Stock Longblock - 287/276 Low 12s NA! 10s on the spray? |
i have the bbk combo and i havent had any problems out of it
2004 Black Mustang GtWhen I see a 5.0...I respect my elders. |
well 78 mm is probably to big for NA rite?
2003 mustang gt
yr 1965 @ 88mph
![]() ![]() ![]() ![]() iTrader: 5 reviews
well ive heard that sometimes 75 is too big so i figured i should def wait till i have FI to get something as large as 78
2003 mustang gt
yr 1965 @ 88mph
yea i would agree
Stick with 75mm accufab
2002 GT SOLD 2003 Mustang GT Cobra Clone SOLD Procharged @ 8psi 458 rwhp ![]() Mods in Garage
It's pretty, and I bet would be pretty damned good for a f/i setup.
Running n/a I doubt there would be any measurable diffrence between the new BBK integrated unit and any good aftermarket plenum with a 70 mm TB. If you look at Accufab's flow data (click here for my reformatted version) you can see that on an n/a 2V, with a decent plenum, going from a 70 mm to a 75 mm TB does nothing because the outlet of the upper plenum/intake manifold inlet becomes the weak link.
-cliff knight- My Mustang 2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat, PP 70mm TB & plenum, DF Commando, Steeda UDPs, Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs 3.73s, 262 rwHP/305 lb-ft. Flex-fuel: burns gas and rubber...
so 70 for NA and the 78 combined set for FI
2002 Ford Mustang GT
I am curious to know if this would hurt a NA car. I am very tempted to buy this, as 230 bucks is a whole lot better than 400 bucks for the Accufab. Sure a NA car doesnt need such massive air flow, but it seems like a good way to upgrade the stock Tb/Plenum. However if it were to hurt performance, I would opt for the Accufab. Anyone have any dyno runs to show the effect of a large TB?
I used to have a 70mm, I changed heads and cams and upgraded to accufab 75mm. I think that 78 is too big for NA. You will loose power
I think it's cool.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS. ![]() NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES! TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
Blown 03 GT
I still dont get how a bigger inlet will hurt you? I doesnt make any sense from an engineering view, if its too big you just wont pull the max air thru that it can handle.
It can impact charge velocity.
Air has mass and therefore inertia, and the intake stream is a series of pulses as valves open and pistons fall, not a steady flow. If the velocity of each pulse is lessened (as can happen with too big a hole) then the inertia (which keeps the intake pulse in motion and tends to "shove" it into the cylinder) will be lessened. This can and does impact performance. Once you start forcing the air in (as in forced induction) the importance of the inertia of the charge becomes much less of a factor, what you want then is a big-ass hole to push the air through.
so basically it would benefit me to get that bbk throttle body since im going turbo on my stang correct?
Penetration before detonation
2001 Mustang GT
13.85 @ 100.5 w/3800 ft. DA
I'd say stick with the 70mm. Mike Murillo told me 75 is just too big for the kind of power we push around in our 2vs N/A. He said the 70 would work fine- I have the BBK plenum and TB and love it. My car pulled real hard with the plenum and my K&N- sounds vicious under the hood, too.
WHOOP!
7.44@95 (1/8)
![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
![]() Buy my: Nitrous Accessories Diablosport Programmer In The Classifieds |
Threads Similar to: New BBK throttle body and plenum
| throttle body and plenum | oh2swapped | 99-04 | 11 | May 17th, 2008 12:16 PM |
| plenum/throttle body | Jucostud | 96-98 | 11 | February 19th, 2008 12:19 AM |
| PP Throttle body/plenum ? | auburntiger7231 | 99-04 | 10 | October 12th, 2007 08:56 PM |
| throttle body and plenum HP | Cantbeatblack | 99-04 | 16 | October 1st, 2007 10:51 AM |
| Anybody have the BBK Trottle body and plenum?? | auburntiger7231 | 99-04 | 7 | August 8th, 2007 03:13 PM |
