Header Gasket Problem
Ok. Well i have a pretty bad leak on the drivers side header gasket. I put lt's in and used the paper gaskets they provided... bad idea hahaha.
Is there any easy way to change the gaskets out? I really dont want to spend another weekend on my car, dropping the k, and lowering the engine. Is there any other way to just change the gaskets? I figured that i'd just change both sides since i'll be in there. I'm looking at either frpp or percy copper gaskets
Resident Bubblehead
if you can reach the bolts without having to pull all that shit back out, just unbolt the header, slide the gasket out, slide the new one in, and bolt everything back up. that's if you can get the bolts out without pulling everything back out...
well derrick (8t6gt) is gonna bring his engine hoist down from michigan and we're just gonna raise the engine a couple of '', instead of taking the k member back out and dropping the engine... thats not really safe anyways.
We're just gonna unbolt the headers from the mid, then unbolt the engine from the mounts on the K, and raise her up a couple of ''... is that possible guys?
Resident Bubblehead
i don't see why it wouldn't be possible. are you pulling the tranny too, or are you gonna drop it first? i would unbolt the tranny first personally...
yeah, we're unbolting the tranny too... forgot to mention that.
N/A 4v Guru
2003 Mach 1
It might be easier to support the engine with the hoist and just lower the K, not take it out but just loosen bolts and lower it some. Obviously there is a little more to it than that but you know what I mean. thats how we got to mine. Combination of raising the motor a bit and lowering the k a bit. Was able to get to the bolts easily thru the fender well.
![]() Military Crew U.S. Army Aviation Apache's Lead The Way |
#7 | |
How long do you think this will take? It took me, stevigx, 8t6gt, and another buddy, 2 days to freakin do them! I'm not lookin for that shit again.
I'm incompatent though. so i dont count haha
![]() Mineral Gray Club Member #2 Just your average 22 year old dumbass If you didn't build your car, and your bragging about it, STFU |
hahaha. steve, derricks bringin his engine hoist back from MI this sunday. He's also bringin all his tools. I'm orderin an alum flywheel as well, i figured as someone's working on the header bolts, someone can be doin the flywheel, u kno lol
What the freaking hell man! Where are you coming up with all this cash. sweet lord. I can't keep up with this shit
I'm a manager and i work 5 days a week lol.
#12 | |
N/A 4v Guru
2003 Mach 1
If you do it like I said it realy won't be too bad. Did you leave the studs in or use the bolts?
We left em in. Its better to do that anyways right?
I do remember, the #2 cyl stud came out... but we somehow got it to fit back in there like it was new.
high temp threadlocker. actually had to use it on 3 of the studs. didn't even think to use the bolts
on the passenger side?
We had a huge problem on the driverside with clearance issues... it was impossible to get to the #8cyl bolt... good god!
Threads Similar to: Header Gasket Problem
| Header Clearance Problem...... | 88stangGT | General Tech | 1 | March 28th, 2008 08:52 AM |
| Header problem.. | Stangzilla | 5.0 Mustangs | 19 | May 24th, 2007 12:09 AM |
| could header bolts be the problem? | ddashtrois | 99-04 | 4 | March 30th, 2007 08:55 PM |
| header gasket install? | superbeef1000 | 99-04 | 3 | March 18th, 2007 11:20 PM |
| Header or suspension problem? | mystang428 | 99-04 | 3 | March 1st, 2007 08:09 PM |
