the 2k s/c buildup.....
LinkBack (3) Thread Tools
Old June 21st, 2008, 01:47 PM   3 links from elsewhere to this Post. Click to view. #1
DeMello is an unknown quantity at this point
originally written on mustang forums and thoguht id share it with you guys for those of you that dont know aobut id like to learn more about it (not saying im going to do it...just want to learn)
spent some time talking to hmusn and he siad its not very realitic and was done with cheap parts but he had to go so i figured other smart car guys on this site would have more input
FROSTBITEN -
Many many people have been asking me how I got my supercharger kit for less than $1500. Well, this is how its done. Please make this a sticky.
Even if you dont have an 00-04 you can still get it done just as cheap. I have just quoted prices for a non-intercooled Vortech setup. Search through SuperchargersOnline.com :: Home :: Superchargers and supercharger accessories by Vortech, Paxton, Whipple, ProCharger and much more! and you can find prices for different makes and models. I do not work for them but they just have good service and they helped me build my kit.
This is a list of parts youll need to buy.
Vortech Bracket Assembly $289
SuperchargersOnline.com :: Product: Vortech Mounting Bracket Assembly for 2000-2004 Ford Mustang GT with 4.6L
includes:
3/8-16 x 1-3/4" HXHD G8
3/8" AN960 Flat Washers
Belt, K061080-Gatesd Saleen
Mach, 2000 GT Mtg. Brkt
8mm x 1.25 x 65 Soc
8mm x1.25 x 140 HXH
5/16 AN-Washer
6mm x 1.0 x 50mm HXHD Zinc
8mm x 1.25 x 25 HXHD
Radiator Pipe-Stnlss
#24 Gold Seal Hose C
Adel Clamp, 3/4' ID
10-24 x 1/2 Soc HD Cap, Zinc Plt
#10 Flat Washer
10mm x 1.50 x 140 Hex Head
10mm Washer, Zinc Plated
10mm x 1.5 x 65 Bolt, SHCS
#8 x 3/4 Sheet Metal
2000 2V Idler Ply Assy.
Idler Plt Assy, 2V GEN3
Idler Pulley, 6Rib 3" Flangd
Dust Cover (Idler Pulley)
12mm x 1.75 x 20mm Pld
Spacer, Idler Plate 2V G3
3/8-16 x G8 HXHD
1/4 SAE Washer, Pltd
M8 x 1.25 x 140 Bolt
Vortech Discharge Assembly $189
SuperchargersOnline.com :: Product: Vortech Discharge Assembly for 1996-2004 Ford Mustang GT with 4.6L (Satin)
includes:
Discharge Tube
3" x 2" Sleeve
2-3/4" x 2" Sleeve
#44 Hose Clamps
#48 Hose Clamps
#16 Hose Clamps
Bosch Bypass Valve
1" x 3.5" Heater Hose
1" x 13.5" Heater Hose
5/32" x 52" Vacuum Line
5/32" TEE
1" Hose Union
1" x 90 Degree Rubber Elbow
Vortech Air Intake Assembly $204
SuperchargersOnline.com :: Product: Vortech Air Intake Assembly for 1996-2004 Ford Mustang GT with 4.6L
includes:
90 Degree Intake Elbow
MAF Meter Bracket Assembly (be sure to order the correct size if you are using a 90mm MAF)
#56 Hose Clamps
3-1/2" x 2" Sleeve
3-1/2" x 9" Flex Hose
#52 Hose Clamps
Air Filter
1/4-20 x 3/4" SHCS
1/4-20 Nylock Nuts
1/4"SAE Washers
Inlet Elbow
3/4" NPT x 1" Hose Fitting
5/8" x 48" Hose
3/4" x 27" Hose
7/16" Rubber Grommet
5/8" Barb
Vortech Oil Feed Assembly $22
SuperchargersOnline.com :: Product: Vortech Oil Feed Assembly for 1996-2004 Ford Mustang with 4.6L & 1996-2001 Ford Mustang Cobra with 4.6L
includes:
1/4" x 26" Oil Feed Hose
.525 Crimp Ferrules
#4 Swivel x 1/4" Hose Barb Fitting
1/8" NPT -4 x 45 Degree male Elbow
1/4" NPT Street TEE
1/4" NPT x -4 90 Degree Fitting
-4 Flare to 1/4 NPT
Vortech Oil Drain Assembly $23
SuperchargersOnline.com :: Product: Vortech Oil Drain Assembly for 1996-2004 Ford Mustang with 4.6L & 1996-1998 Ford Mustang Cobra with 4.6L
inlcudes:
1/2" x 14" Oil Drain Hose
#8 Stainless Hose Clamps
90 Degree 1/2" Alum. Tube
Tube Nut
Male Connector
Vortech Bracket Assembly: $289
Vortech Discharge Assembly: $189
Vortech Air Intake Assembly: $204
Vortech Oil Feed Assembly: $22
Vortech Oil Drain Assembly: $23
Total: $727 before tax/shipping
That is cost for EVERY single item you need to put a Vortech S, SQ, or T trim on your 2000-2004 Mustang GT. Only thing left to buy is the head unit. They are fairly easy to find if you search Ebay, SVTperformance.com, or Corral.net . A used S-trim sells between $400-800 depending on assumed mileage and condition. I bought mine for $700 with discharge pipe and intake. If you want a new head unit they cost $1849 for a brand new satin V-1 s-trim. A used head unit WILL be alot cheaper and perform just as well. Even if the unit needs a rebuild, the cost is about $350 from vortech or you can find some performance shops that can do it for around $100. Mine was in great condition when I picked it up from a guy on Ebay. Even bieng a 6 year old head unit it had no shaft play and seems to be in perfect condition.
If you find a head unit for $600, add the cost of the hardware ($727) and this comes out to $1327 for a COMPLETE vortech s-trim setup every part new but the head unit and fuel injectors. Even if you paid say $800 it would just come out to $1527 before tax and shipping. 96-98 models with the return style fuel system will need a FuelManagementUnit also.
Install takes a full days work to get it done right. Anyone with general knowledge of removing and installing bolts on the front of the timing cover, removing the belt, using a pipe tap, and swapping non-pressed pullies can perform this install.
Heres the install manual: http://www.vortecheng.com/pdf/manuals/4FH4FL218im.pdf
BTW my ebay head unit is still in perfect condition after 20,000 miles of street/track time.
INTERCOOLER:
You have three choices:
Vortech Air-Water SuperchargersOnline.com :: Product: Vortech Aftercooler System for 1996-2004 Ford Mustang GT 4.6L 2V with Factory Intake Manifold (satin)
$1599
Paxton Air-Air SuperchargersOnline.com :: Product: Paxton Air to Air Intercooler for 1996-2004 Ford Mustang & Cobra with 4.6L
$1399
DIY Ebay kit
$200~
I went with an Ebay intercooler and found BTI piping from a guy on Ebay so my install was a little easier.
Non-intercooled setups will make around 350-370whp on 8psi. Intercooled setups can make 370-390whp on 8psi and over 400whp on 10psi with supporting mods on a 99-04 GT.
Just Another Bolt on GT
[IMG]http://i45.tinypic.com/54f5ua.jpg[/IMG]
Stock Longblock - 287/276
Low 12s NA! 10s on the spray?
Old June 21st, 2008, 01:48 PM   #2
and i added 500 to his setup to include a tune which he didnt mention and could be why his engine blew lol
Old June 21st, 2008, 01:49 PM   #3
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
Old June 21st, 2008, 01:50 PM   #4
Originally Posted by HMUSN View Post
lol
dont take it the wrong way...i belive everythign you said....just trying to learn more
Old June 21st, 2008, 01:51 PM   #5
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
I'll sit back and watch this thread. should be fun. what did you other guys pay for your superchargers?
Old June 21st, 2008, 01:52 PM   #6
guessing 4-5k like you siad
Old June 21st, 2008, 01:52 PM   #7
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
I said over 5k when everything was done.
Old June 21st, 2008, 01:54 PM   #8
oh yea lol
Old June 21st, 2008, 02:00 PM   #9
1999 Mustang GT
hardhitter has a spectacular aura abouthardhitter has a spectacular aura abouthardhitter has a spectacular aura about
Send a message via AIM to hardhitter
2k+injectors/fuel pump/intercooler/maf
Vortech V2 Si
Old June 21st, 2008, 02:01 PM   #10
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
^ and you tune AND the mods in your sig..
Old June 21st, 2008, 02:03 PM   #11
but he doesnt need the other mods like exhuast and shit
and so plus the tune he did it for 3k
Old June 21st, 2008, 02:06 PM   #12
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
spotted! Demello after his 2K supercharger install.
Old June 21st, 2008, 02:08 PM   #13
didnt say i was doing it
Old June 21st, 2008, 02:10 PM   #14
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
k I'm going for a nice 10 mile bike ride. be back a little later to check on this thread
Old June 21st, 2008, 02:10 PM   #15
Old June 21st, 2008, 02:19 PM   #16
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
YouTube - Blown up
thats impossible dude, cause you see that car was at the track
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Old June 21st, 2008, 02:20 PM   #17
that was actaully really funny white
someday ill go
Old June 21st, 2008, 03:09 PM   #18
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
ok cut it short at 8 miles.. I'll make it up tonight.
Old June 21st, 2008, 03:10 PM   #19
lol
Old June 21st, 2008, 05:05 PM   #20
SteviGX's Avatar
13.538@101.72 before cams&slicks&gears
SteviGX will become famous soon enoughSteviGX will become famous soon enough
Send a message via AIM to SteviGX
that's gonna happen even if he done'st blow up haha
Guy snapped his tailshaft and sent it through the differential through the diff cover. about a 3K fix from what he said
o and thats mustangmanic in the right lane lol
Mineral Gray Club Member #2
Just your average 22 year old dumbass
If you didn't build your car, and your bragging about it, STFU
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/76829-2k-s-c-buildup.html
Everything about superchargersonline - Yahoo! Glue This thread Refback January 21st, 2009 09:02 PM
Lets take a look at Filter Washers » Blog Archive » ‘filter washer’ on the web This thread Pingback June 22nd, 2008 12:25 PM
2k » Blog Archive » the 2k s/c buildup….. This thread Pingback June 21st, 2008 08:59 PM
Threads Similar to: the 2k s/c buildup.....
Procharger buildup continued ryans88gt 5.0 Mustangs 78 March 17th, 2008 11:43 AM
Help Make Rough Draft Of Buildup?? patshea098 2005 - 2010 13 June 15th, 2007 10:00 PM
331-stroker buildup 173speed 5.0 Mustangs 10 November 3rd, 2005 10:19 AM
