driveline or gears?
Old June 26th, 2008, 12:59 AM   #1
moosenuk17's Avatar
2000 ford mustang GT
moosenuk17 is a jewel in the roughmoosenuk17 is a jewel in the roughmoosenuk17 is a jewel in the rough
Send a message via AIM to moosenuk17 Send a message via MSN to moosenuk17 Send a message via Yahoo to moosenuk17
driveline or gears?
ok so i just got my first mods on, throttle body, throttle boddy space intake space, and CAI, should i get gears or a aluminum driveline first? i know some guys who can make me an aluminum driveline and cuz me a nice deal.. thanks.
Old June 26th, 2008, 01:00 AM   #2
moosenuk17's Avatar
sorrry bout all the bad spelling, kinda tipsy
Old June 26th, 2008, 01:04 AM   #3
the real shocker's Avatar
13.00 @ 105
the real shocker will become famous soon enough
sell the throttle body spacer and buy the gears with that... then get the driveshaft also...
throttle body spacer doesnt do much of anything for our cars
Old June 26th, 2008, 01:07 AM   #4
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
I agree that the spacer doesn't do much for the 2Vs but there's not a lot you can do now that you've bought it. Do the gears first. The driveshaft is an easy mod that can be done in a few hours even if you are trying to figure it out without any kind of direction. Just make sure to put a jackstand under the tranny before you disconnect the shaft.
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Old June 26th, 2008, 03:06 AM   #5
99mustanggtman's Avatar
1999 GT
99mustanggtman will become famous soon enough
iTrader: 7 reviews
Send a message via AIM to 99mustanggtman
get gears as your first mod
Single 67mm turbo, ported pi heads, edelbrock vic jr. manifold w/HPP plenum, terminator shortblock, return fuel system... Goal 600+ rwhp.
Threads Similar to: driveline or gears?
Driveline Question fosted285 2005 - 2010 20 February 15th, 2008 11:26 AM
What can the driveline handle 03_StangGuy 99-04 8 February 14th, 2008 10:49 AM
Driveline Install ??? adam0421 2005 - 2010 4 August 12th, 2007 10:01 AM
Driveline Clunking dumps 2005 - 2010 9 March 17th, 2007 05:21 PM
