Anyone who may have experience this!! plz help
Old June 27th, 2008, 01:46 AM   #1
Killax15 is on a distinguished road
Ok guys as some of you kno i have been having a serious brake problem since i bought this car last yr i have a 2000 mustang gt but with the cobra brake kit that was put on it when i bought the vehicle last august but ,yea man this brake problem is really hurtin me im at the point where i dont even want to drive it anymore. i had my friend check out what could be the problem to make me get pedal kick back after down shifting as well as my brake pedal pulsating and make a noise at the same time cant seem to find the problem. You guys know how when you make a left turn or your pulling out of a parking space and you hear your power steering pump make a whine noise? well the wierd thing is when i push down on my brake at a stand still thats the noise that it makes but my steering feels fine which is also wierd. Also we popped the hood to try to hear where the noise was mostly coming from so we used a metal pipe and put it on the abs unit you can hear sum noise/rattle then when you apply the brakes, so then we went to the master cylinder u can hear the noise/rattle then while the power steering fluid cap was off it seems if when i apply the brakes the fluid kind of goes at a stand still but once you get off the brake pedal the fluid looks like its flowing fine, but this was the kicker we lastly put the metal pipe on the power steering pump and thats where the noise/rattle was the loudest coming from there, also i notice sum dark oil around the vacuum leading up to the power steering pump, but like i said my steering seems find its just this damn brake pedal kick back when down shifting and the noise/pulsating of the brake pedal, oh and sometimes the brake pedal will feel like im grinding on rocks and wont really let me brake
Old June 27th, 2008, 02:52 AM   #2
1999 Mustang
Invictus is on a distinguished road
First off,
The noise is coming from your hydroboost/ mas. cyl unit located in the corner of your engine bay above the driver's side valve cover.
Process of elimination.
First i'd bleed the breaks entirely. Starting with the valve the FURTHEST away from the master cyl. then moving close. So start with the passenger side rear, then driver side rear, then pass. side front, then driver side front.
Then repeat again until there are no air bubbles at all. Make sure the mas. cyl. resovoir doesn't go dry... Then when you're done, bleed the two valves on the master cyl itself.
You will need a buddy to pump the pedal for you while you open/close the valves. Or you can buy a one man bleeder kit from any parts store.
Hope it helps.
Old June 27th, 2008, 09:33 AM   #3
andres0286's Avatar
andres0286 is an unknown quantity at this point
Send a message via MSN to andres0286
Another thing is, if the brakes were brand new, you will need to season the brakes. Its quite a long process. When I got my Baer brakes, I forgot to do it and when I pressed the peddal, it trembled and was really hard to brake. Check this out from Baer
http://www.baer.com/technical/brakin...seasoning.php:
2002 GT SOLD
2003 Mustang GT Cobra Clone SOLD
Procharged @ 8psi
458 rwhp
Mods in Garage
Old June 27th, 2008, 10:27 AM   #4
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
My guess is that the noise is coming from your ABS. A similar problem occurred on my 96 Cutlass and my daughters 99 Escape. Both times the notched ring on the axle had cracked giving the system a false reading. Because of the crack the system thought that one wheel was spinning faster than the other so it activated the ABS every time the brakes were applied.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old June 27th, 2008, 11:30 AM   #5
crappy_head's Avatar
2001 GT
crappy_head is on a distinguished road
Send a message via MSN to crappy_head
damn man thanks,i got the same problem. i got the loud squewks and and ABS light turn on randomly. how did you fix it? how much did it cost?
HP 401 TQ 380 | Vortech V-2 SQ Intercooled | 410 Gears |Accufab 75mm TB | UPR O/R X Pipe | Flowmaster 40s
Eibach Sportline Springs | Steeda U&L Rear Arms | Subframe Connectors | Steeda Sport Shifter
Old June 27th, 2008, 12:07 PM   #6
12.73@111.36
I had to have a shop fix it. On the Cutlass they replaced the axle. On the Escape the had to machine press a new ring (I wish I could remember what its really called.) onto the axle. It will probably cost around $350.
Old June 27th, 2008, 12:54 PM   #7
BLK01SS's Avatar
1/8 7.95@82.43
BLK01SS has a spectacular aura aboutBLK01SS has a spectacular aura about
I found better luck with a rubber hose like a radiator hose on find weird sounds(try that), but as for you problem you said that you noticed sum dark oil around the vacuum leading up to the power steering pump, check that out you might have a clogged vaccum, thats the best I can come up with right now, try those things that every one has posted and let us know.
Topless Mustang Club Founder
2000 Mustang Gt 5.4 SOLD
2001 Camaro SS
Originally Posted by rk_2000_Z/28 View Post
Black C6Z06=pure, hot, nasty, unprotected sex
Old June 27th, 2008, 01:37 PM   #8
yojoe600's Avatar
yojoe600 will become famous soon enough
i having the pedal problem where it doesnt want to stop
Originally Posted by supermachone View Post
it was something like the tinman from the wizard of oz pinching off a tight fart...
Cat Club Co-Founder
Old June 27th, 2008, 06:25 PM   #9
Wow i actually thought i was the only one that has this problem lol, its very annoying but if there was a problem where one of the o rings or tooths broke to the abs wouldnt my abs light come on if so no abs light at all comes on. Is it possible that if theres air in the HCU or in the brake lines that this can cause pedal kick back and that noise and false activating the abs?
Old June 27th, 2008, 11:07 PM   #10
andres0286's Avatar
Air in the line will cause a soft pedal
2002 GT SOLD
Procharged @ 8psi
458 rwhp
Mods in Garage
Old June 28th, 2008, 12:30 AM   #11
1999 Mustang
read my post please and go try it. then post back
Threads Similar to: Anyone who may have experience this!! plz help
your best experience Black Five 0h 5.0 Mustangs 3 May 6th, 2008 04:15 PM
Any have any experience with these phones?? stanglifemike The Clubhouse 32 March 28th, 2008 12:26 AM
help plz, trying to pull out the stock guage, asap plz 91cobra5.0 5.0 Mustangs 4 March 20th, 2008 04:51 PM
Anyone w/SVO experience? sweet99 96-98 4 November 7th, 2007 05:34 PM
First experience with a programmer!?!?! RStrick0352 2005 - 2010 1 May 2nd, 2007 11:35 AM
