Discussing turbo kit on a stock 2 valve in the 99-04 Forum. what turbo kit is the most recommended these days and will a stock 2 valve ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
02 mineral grey stang
14.65 @ 95
turbo kit on a stock 2 valve |
2000 mustang gt
12.01@114.69
hp and hellion are the big 2 that i seen used. both put down good power and are efficient. you will want to keep in mind the limit of a stock 2v around the low to mid 400's.
stock long block, bolt ons, slicks, and a little squeeze 1/4 E.T. 12.06@114.69 ![]() Only two defining forces have ever offered to die for you: 1. Jesus Christ 2. The American G. I. One died for your soul, the other for your freedom. |
TT Bullitt
HP and Hellion are the main two.
I have the HP kit myself and I did have a couple "problems" with getting everything correctly, this was about a year ago. I believe Hellion also makes a twin turbo kit now, and as far as power goes, that will depend more on things like single vs. twin and what kind/size turbos you have than the different turbo kits themselves. 8 psi can be safe on a stock engine if it has a safe tune. 9+ psi is pushin it. I'd recommend reading around as much as you can and trying to learn about how it all works. |
does that hellraiser kit make any more power with the stock supercharger on there?
2000 Mustang GT, Steeda Triax shifter, Underdrive pulleys, SLP LM2, MAC L/T and O/R H-pipe. Transmission fix, new clutch Coming soon: Brakes.
14.65 @ 95
I looked on the helion site yesterday and saw that hellraiser kit, holy smokes that cobra was pushin 900+ hp holy crap!!
July 08 ROTM
2004 Mach 1
Too Slow
If you're going to invest in a turbo kit, then you should invest in a forged lower end IMHO. Why not get all that you can get out of your engine as well. Besides a built engine and turbo, will perform that much better.
![]() MM MACH 1 CREW MEMBER #2 McCain/Palin '08 Arsenal0328 (10:32:19 PM): mso gives me a raging hard on |
01 nitrous injected GT
12s next time out...
how much you willing to spend?
i just asked in your other thread and in the end it all comes down to that
![]() NX wet kit, heater, purge, FPSS, window switch PLX DM-5 wideband, raptor shiftlight, msd tach adapter FRPP 410s, JLT CAI, STEEDA tri-ax, SCT x cal 3 STEEDA catback, SLP Loudmouths, UPR o/r X NITTO Drag Radials, Zoom racing clutch |
14.65 @ 95
i guess your right bout tha bottom end, built is better than blown up, I am lookin at 4-5k the hellion is about 5500 or so but that has everything including fuel system, headers, k-member etc. does that sound like a good deal?? and if i did fork out the extra for he bottom end, any recommendations??
not sure about the bottom end but hellion is a great company...if i had that much money to spend ill go with exactly wat your tlking about and a dyno tune
Resident Bubblehead
MMR has some nice forged rotating assemblies. you can also look into Livernois Motorsports. i got my forged rotating assembly from Sean Hyland Motorsport:
forged Cobra crank, forged Manley H beam rods, forged 17cc dish pistons (0.020" overbore), Federal Mogul bearings and rings... |
14.327 @ 94.53...4200 ft above sea level
just buy one of the built shortblocks from MMR...they are only about 2500 i think
I WANT AN LS1... I'M 4200 FT ABOVE SEAL LEVEL!!!!!!!!!! READ!!!!! |
TT Bullitt
If your gonna go with a forged bottom end, then you might as well go ahead and get a built tanny, rear end, and fuel system while your at it lol.
14.65 @ 95
has anyone done the 5-6 speed swap meaning the 3650 to the t56?? good or bad??
Some heads and an intake too lol.
VORTECH V1 S-TRIM ![]() 11.26@ 129 with only 516/453 on street tires New times coming soon with 598/531.......... Last edited by jivepepper : June 28th, 2008 at 02:36 PM. |
July 08 ROTM
2004 Mach 1
Too Slow
Research the archives using the search feature.
Threads Similar to: turbo kit on a stock 2 valve
| Turbo 3 Valve Terror Project | AMD692 | 99-04 | 4 | March 30th, 2008 12:13 PM |
| turbo by pass valve | wadman | 2005+ | 7 | October 15th, 2007 09:48 PM |
| Turbo HorsePower Twin Turbo kit | dblindberg | 2005+ | 34 | June 17th, 2007 08:05 PM |
| FS: BILLET GRILL; STOCK ROMEO VALVE COVERS;STOCK COIL PAKS | Invictus | For Sale | 7 | May 4th, 2007 07:14 PM |
| Stock Valve Springs | flamed 98 gt | 99-04 | 0 | March 20th, 2007 11:01 AM |
