Discussing Help with brembo big brake kit! in the 99-04 Forum. I installed the brakes on my 99 gt but i think these brakes feel worse ...
Old June 28th, 2008, 05:50 PM   #1
1999 Mustang GT
I installed the brakes on my 99 gt but i think these brakes feel worse that my stock ones. I havent noticed and improvement. Is this normal and I should wait for the brakes to set in? Any help??
Old June 28th, 2008, 05:59 PM   #2
superbeef1000's Avatar
what all was replaced? it may take some time for them to set in you should not hammer on the breaks for a while ,and make sure you have installed them as instructed to the tee
Old June 28th, 2008, 06:02 PM   #3
1999 Mustang GT
yea i did exactly on the instructions even took my time longer than the time it said. i replaced the stock 99 gt rotors and calipers to the brembo 4piston calipers and 13 inch slotted/drilled rotors
Old June 28th, 2008, 06:04 PM   #4
so what is the problem ,,,,noise or are they just not clamping like you exprected
Old June 28th, 2008, 06:07 PM   #5
1999 Mustang GT
I didnt install the stainless steel lines because they only had three lines of thread and would make my brakes leak
Old June 28th, 2008, 06:08 PM   #6
1999 Mustang GT
When im driving fast and then start to slow down on the freeway my old brakes you to feel like they were helping me stop faster than these
Old June 28th, 2008, 06:09 PM   #7
you should install them they will keep the pedal from feeling mooshy and send the clamp load to the pads
Old June 28th, 2008, 06:11 PM   #8
it will take some time to set in ,,not only that but they may need to bleed the lines again to make sure all air is out ,,i had to do this a couple times with mine
Old June 28th, 2008, 06:16 PM   #9
1999 Mustang GT
ok ill do that agian next week 2 be sure thanks dude
Old June 28th, 2008, 06:44 PM   #10
I Touch Myself Sometimes
HMUSN's Avatar
91 Sonic Blue Goodness
19.83 @ 12mph
you def need to install those lines. all your doing is bottlenecking your breaks.
that's why you are having those issues.
MILITARY CREW
FOUNDER
Originally Posted by DeMello View Post
looks like i demellowed myself
sry OP
SCT Custom Tuning, JLT intakes, Aeroforce Interceptor OBDII gauges and PLX widebands
email joe@tricktuners.com
Old June 28th, 2008, 07:46 PM   #11
1999 Mustang GT
i would but then my brake lines will leak because it only get three lines of thread.
Old June 28th, 2008, 07:49 PM   #12
HMUSN's Avatar
19.83 @ 12mph
here
Mustang Brake Lines and Mustang Brake Hoses at AmericanMuscle - Free Shipping!
MILITARY CREW
FOUNDER
sry OP
Old June 28th, 2008, 07:57 PM   #13
1965 Coupe
Could be your stock master cylinder can't keep up with the added demand as well. Might be something to look into.
http://i17.photobucket.com/albums/b57/mustangclint/SIG-Zers.jpg
Old June 28th, 2008, 08:14 PM   #14
no1sirbutler's Avatar
2001 KB'd GT
Its not the master cylinder. I have wilwood 6 piston calibers and my master cylinder is working fine. I would install ss brake lines and then rebleed them. Even w/ only 3 threads those lines will seal if you tighten them properly.
Don't make KENNY scream at you!!!!
Old June 28th, 2008, 08:16 PM   #15
HMUSN's Avatar
19.83 @ 12mph
welcome to the forums btw.
MILITARY CREW
FOUNDER
sry OP
Old June 28th, 2008, 08:29 PM   #16
serjo's Avatar
I think you just need to bleed them more.
BTW what kind of brake fluid are you using? dot3?
Might not be a bad idea to get some SuperBlue fluid. When changing brake fluid you have to bleed the brakes till the new fluid starts to come out...that way you know you have definitely bled all the air out.
When I did mine I had air coming out all the way to the new fluid, so it could be anywhere in the lines.
Threads Similar to: Help with brembo big brake kit!
Big Brake Kit or New Rotors daz 99-04 18 February 4th, 2008 05:40 PM
For Sale: Brembo 13" Front Big Brake Grand Turismo Kit blownvert For Sale 11 August 25th, 2007 01:31 PM
For Sale: Brembo 13" Brake Grand Turismo Kit 13" B blownvert For Sale 0 August 23rd, 2007 10:28 AM
For Sale: Brembo 13" Front Big Brake Grand Turismo Kit blownvert Northeast 2 August 16th, 2007 10:42 AM
big brake kit 06RedfireGT 2005+ 22 June 26th, 2007 10:17 PM
