Discussing Drivability tune in the 99-04 Forum. At partial throttle what is the timing supposed to be at? Trying to get the ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2000 GT
Drivability tune
At partial throttle what is the timing supposed to be at? Trying to get the drivability under control. WOT is supposed to be at mid-high teens with 15 psi boost.
I have a datalog for anybody that is interested. My wideband is currently being sent back for repairs... so only got the narrowband o2's. But its only partial throttle anyways, WOT is dyno tuned.
2000 Black convertible GT: KB 14psi, and other goodies... |
2000 GT
bump, also its around 30s at partial throttle is why im asking, thats a huge difference.
might be a touch high, but thats normal for part throttle timing. if you go wot from 2000 or so the timing should drop way back to more like 9 or 10(just throwing a number out here) and then climb to peak timing from there
99 limited edition conv. KB 2.1 9 psi intercooled.vt stage 3 blower cams,gt40 fp/bap,vt covers,frpp 3:73's,demolet cai,accufab 75mm tb,Sct Ba 2400,tri-ax,bfg kdw's,magnaflowsTuned by Joe at http://www.tricktuners.com |
2000 GT
cool thanks... i thought that seemed high. Im getting an ignition code too, and i just replaced the cops (mechanic lent me a set of 8) to see if that would get rid of the problem. So was thinking maybe it was misfiring cause of huge amounts of timing at partial throttle.
2000 GT
While WOT in 3rd, shifting to 4th it practically falls on its face. It stumbles huge. What do you think would cause that? Have a datalog of it. Also still seems low on power, and minor stumbling.
What would cause the shifting issue? Anythoughts? Mechanics take awhile to get time to look at it.. and joe has been busy and hasnt responded.
2000 mustang gt
11.79@115.83
the timing at part throttle shouldnt cause any misfire issues, unless it set way to aggressive, even then it should ping instead of anything else. do you know what total timing is???
stock long block, bolt ons, slicks, and a little squeeze N/A-12.81@103.7 N2O-11.79@115.8 parting out 04 cobra, pm me for details |
2000 GT
Partial throttle is low 30s, when WOT it goes to 11-13 with 15 lbs. Not sure what total timing is. Also had missfire parameter turned on the last datalog, and wasnt set off once.
The radiator temp was at 185 for 45 min drive, didnt go above it. IAT was at about 140-156. And underhood temps seem super hot. Dont know if that would have any effect on drivability. Cause it does to it when it is first driven still...
2000 mustang gt
11.79@115.83
those temps are about right if its hot and just running around. i would make sure the plugs, fuel filter, and the fuel are all good. check the afr's, and go from there. if its running a little lean or if you have too much timing, this issue can occur.
2000 GT
fuel filters pretty new. Plugs are ngk tr55's... i heard those arent so good of plugs. Should i switch to autolites 103's? I have boost a spark, so im not sure if that would be whats the matter...
Might have to get re dyno tuned.. for driveability. He just did WOT in 4th, and idle. Didnt mess with drivability at all. to make matters worse my a/f gauge took a dump on me and has to be sent back...
2000 GT
tr6's i mean, not the 55's.
datalog the fuel pressure drop across the injectors at the shift and see where you are
2000 mustang gt
11.79@115.83
the ngk's should work just fine for your app. i would just take it to the dyno and have it tuned, or have someone else tune it.
2000 GT
I dataloged that actually, fuel pressure drop across injectors at rail. And it looks like theres some funky stuff going on. Same with fuel source.
At wot its around 50-55 (seems right) but towards the end went to 90 for a second. Some of the problem spots of sputtering was at 20's or 50s (spikes). At one point, i saw the pressure at 2 for about 4 seconds... and that is bad! Looks likes that happened in a few spots. That could be after i let off but still... Think ill need some dyno time... Mechanic that i had messing with the drivability doesnt have a dyno, so he cant mess with the WOT stuff. Unless the frp is connected some how.
Blown 03 GT
def get a dyno tune, should solve the problems.
2000 GT
Had a dyno tune for WOT and idle, but we didnt mess with the drivability. Should have!!! Kinda annoyed, i didnt know better but he should have.
2000 mustang gt
11.79@115.83
the connction and the sensor good on the fuel rail?
2000 GT
No idea on the sensor if its good or not... no codes for it. Connection is good. I should email you the datalog so you could see some of the issues. I got the times where is was extremely fubared. It has more than just those spots though...
2000 mustang gt
11.79@115.83
send it to me and i will take a look at it.
2000 GT
It wont let me pm you a file, and your email is locked. Can you pm me your email? Thanks for helping me out!
Threads Similar to: Drivability tune
| Dyno tune vs Sniper email tune | itschristorres8 | The Clubhouse | 72 | May 22nd, 2008 05:27 AM |
| Drivability | 07stanggt | 2005+ | 43 | April 8th, 2008 10:38 PM |
| dyno tune or downloaded custom tune | silvergtstang99 | 99-04 | 2 | January 31st, 2008 11:49 AM |
| nitto DR drivability | leebunnyz | 2005+ | 42 | August 10th, 2007 05:49 PM |
| dyno tune & flash tune | miafan | 2005+ | 4 | May 31st, 2007 05:05 AM |
