Discussing OBD code P0320 in the 99-04 Forum. Alright guys, you all have help me out alot in the past...I need you ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
OBD code P0320
Alright guys, you all have help me out alot in the past...I need you again. I just replaced the engine in my 01. The motor went in without any problems ets, etc. Motor is running very smooth, however....when I really get on it (WOT) rpms at about 4500 to 5500 the engine cuts out like its hitting the rev limiter. It will only do this when I have the pedal to the floor, if I ease it up it will go to the rev limiter (have set at 6200 with a diablo tuner) and sputter like its supposed to. Then I got the dreaded check engine light, the code was this: P0320 Ignition Engine Speed (PIP) Input circuit fault.
What will cause this and what do I need to do to fix it? |
Come on guys! I'm counting on you...I don't want to go to the "stealership" This problem is killing me..I just wanna go fast and she just won't let me.
Thanks in advance!
'01 Stage 2 Roush #4682. Steeda Tri-ax short shifter, Motive 3.73 gears, BBK shorty headers, Basani X Pipe, Granatelli Pro COP's, BBK Underdrive pulleys, Lightning 90mm MAF, Accufab 75mm tb and plenum, Typhoon intake, Roush CAI |
it sounds like that the ignition is not keeping up with the rpms at WOT.
thats why it could be cutting out at higher rpms at WOT. can the diablo tuner data log?? |
or it is getting the wrong signal cause its an input fault.
Nowhere to be found
Visually inspect the Crankshaft Position (CKP) sensor wiring and the terminals in the CKP sensor connector. Look for corroded or loose terminal connections, poor solder crimps, wiring insulation damage, intermittent shorts, etc... If you dont see anything wrong replace the CKP sensor
Well, guys its been real and its been fun, but it hasn't been real fun for me the past 3 months. Money has been tight and need to cancel my cable service to save what I can. I hope to chat with ya'll in 6-7 months from now. Bye!
Here's what the shop manual says about possible causes for P0320...
I'd double and triple check the wiring,
-cliff knight- My Mustang GT 2003 GT, UPR X, Magnaflow, 180° stat, PP 70mm TB & plenum, Sniper Commando tuned 3.73s, 252 rwHP/296 ft.lb. Multi-fuel: burns gas and rubber... |
Thanks for the replies!
Modified88Dreamer...You are the winner!!! I went out and checked the CPK sensor and the connector had worked itself loose and was filthy. After cleaning the connections it clipped right back in place and it works like its supposed to! Thank you very much...I knew that I could count on you guys...your the best!!!!
Threads Similar to: OBD code P0320
| 94 OBD I trouble codes | bcnsucks | 94-95 | 4 | January 25th, 2008 07:40 PM |
| OBD II in a 95' | Snipe061 | V6 Mustangs | 4 | March 28th, 2007 11:21 AM |
| OBD/ SCT tuner help | 01Pooter | Electronics | 0 | February 17th, 2007 02:12 PM |
| OBD Fault Codes Help! | ROBBED666 | 2005+ | 1 | October 6th, 2006 07:16 PM |
| OBD 1 or 2? | crazyfast50stang | 94-95 | 15 | September 27th, 2006 10:06 PM |
