LinkBack (1) | Thread Tools |
#1
03 GT
how much boost with no IC
how much boost can you run safely with a non-intercooled kennebell? and could you order the intercooler later from KB with everything? and how many pounds of boost is an IC 2.1 KB good for too. ive been pondering these questions for a couple days now and would really like to know cause im thinking about doing this. Thanks
![]() Just some Bolt-ons |
9psi
![]() Single 67mm turbo, ported pi heads, edelbrock vic jr. manifold w/HPP plenum, terminator shortblock, return fuel system... Goal 600+ rwhp. |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
6psi is recommended, 9psi would start pushing it if you are on stock bottom end. the heat a positive displacment puts out is the big factor. a centri can push it, the heat generated by them is less.
37 psi.
13.67 @ 99.3..5000 ft D.A.
![]() iTrader: 1 reviews
2000 Mustang GT- 4.10's, Hoosier DR's, JLT, 75 mm TB, Plenum, MAC LT's, VRS O/R X-pipe, MAC Catback 13.671 @ 99.11 (1.80 60') 5000+ ft above sea level - in El Paso, TX http://www.youtube.com/watch?v=U2l4JdEg3hg
03 GT
im game with that. but wow 9psi i guess ill have to wait and find out how it works out thanks
9 psi will set you up right around 400rwhp
03 GT
hmm that sounds good to me
2000 GT
I dont think you should do 9 with a kb without an intercooler. If you dont have an aftermarket radiator you are going to get some serious heat soak in minutes.
2000 Black convertible GT: KB 15psi, and other goodies... ![]() 1971 Datsun 240 z: Header and rebuilt motor. (The DD) |
03 GT
i dont plan on going 9psi really just 6 then maybe 7 once i get i dyno tune tell i can muster up the money for the intercooler
03 GT
whats a good aftermarket IC cause paying KB $1K for one seems like a lot
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/78024-how-much-boost-no-ic.html
| how much boost with no IC | This thread | Refback | June 29th, 2008 10:13 AM | |
Threads Similar to: how much boost with no IC
| How Much Boost? | BLOWN89 | General Tech | 9 | January 30th, 2008 09:59 PM |
| How much boost? | Cor9er | 94-95 | 8 | July 26th, 2007 03:22 AM |
| how much boost??? | droppedbass87 | 96-98 | 4 | June 23rd, 2007 03:18 PM |
| Turbo Boost vs Super Boost | droppedbass87 | General Tech | 12 | October 16th, 2006 10:56 AM |
| How much boost should i be seeing? | Stangtuner | General Tech | 2 | December 21st, 2005 09:58 PM |
