Discussing pass side valve cover removal in the 99-04 Forum. I was wondering if theres any little tricks or ways to make it easier getting ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
I was wondering if theres any little tricks or ways to make it easier getting the pass. side valve cover off or is it just more so a matter of playing around with it till you can get it off. The rear of the driver side one was kind of a pain. Also when taking off the timing cover did you guys drain the oil due to the 4 oil pan bolts?
03 mach 1
13.2@109
bump
the only thing i can say is on my 94 v6 i had to remove the upper intake manifold to get the covers off or at least that was the easiest way
2003 Mach 1, 5 speed MM MACH 1 CREW ![]() "Dont worry ive locked horns with this fucker before"- TasteMyThunder www.myspace.com/mustangracr94 |
1/8 7.95@82.43
To take off the passenger side valve cover you need to fully unbolt it then disconnect the fuel line that runs across the back, then unplug all of the coil and fuel injector plugs the pull up on it and move it around a bit and it sould come right out.
![]() If you're not 1st you're last -Ricky Bobby Topless Mustang Club Founder |
1/8 7.95@82.43
Yes drain your oil. But thats not b/c of the oil pan bolt it just help in case you happen to drop somethin in there.
Are you doing timing chains?
![]() If you're not 1st you're last -Ricky Bobby Topless Mustang Club Founder Last edited by BLK2KGT : June 30th, 2008 at 11:42 PM. Reason: forgot somthin |
Doin crower stage II cams. Thanks for the info the valve cover was kind of a pain due to the transmission dip stick tube but I ended up getting it after a little wiggling around and trying different things. Now the problem seems to be putting the keepers back in on the valve springs farthest to the back. Its a pretty tight fit.
2001 GT
dont drain the oil until after your done and have refired the car. after you run it for a short period I would then change it. lay a rag across the front of the pan to keep anything from falling in. make sure you plug up the 3 holes in each head to avoid dropping a keeper down there. the tranny dipstick makes it a pain to get the passenger valve cover off. good luck
2001 Gt,auto,J mod, 4:10s, B&M cooler, Hitech stage 2's, NX plate 100 shot, 75 mm tb, C&L upper plenum,BBK X with magnaflow's,Black FR 500,S,SCT tune from Bama chips.
All Throttle with a Bottle
12.91@105.29 @ 5800 FT
I just undid the bolts and it came right off... But it did take some wiggling to get it off.
+1 on the rags in teh head to keep the keeprs from falling, but make sure you take the rags out before you put the cover back on. that would cause a large oil pressure failure.
![]() We expect shit to break, look foward to realizing exactly when it is happening, and than obsess about dropping plenty of cash to rebuild stronger, so we can try to run it hard as hell and break again. We are sick individuals.
Threads Similar to: pass side valve cover removal
| Pass side PCV valve? | Eminembdg | 99-04 | 2 | May 27th, 2008 02:30 PM |
| Pass Side Scoop 04 GT | blackstang2004 | Want to Buy | 1 | March 7th, 2008 06:48 PM |
| turbo by pass valve | wadman | 2005+ | 7 | October 15th, 2007 10:48 PM |
| by pass valve | flattusmaximus78 | 2005+ | 8 | August 10th, 2007 05:22 PM |
| by pass valve | flattusmaximus78 | 2005+ | 3 | July 5th, 2007 02:14 AM |
