Discussing Big Problems in the 99-04 Forum. Ok i posted a thread a while back about my goinf fucking nuts due to ...
Old July 1st, 2008, 11:47 PM   #1
injected03stang's Avatar
2003 MUSTANG GT
11.86 @ 114.21
Big Problems
Ok i posted a thread a while back about my goinf fucking nuts due to the o2 sensor wires being torn into well i got that fixed reset my pc (left the battery unhooked for at least 2 hours) got everything fixed started it up it had a horibble miss through all rpms and idled like it has hellacious cams so i let it run for a littl bit to see if it would clear up it started to die anwas almost impossible to keep it running then when it died would not start again any ideas???? also i can hear air sucking from somewhere almost like my intake is cracked but its aluminum and i havent ran it hard... latley
Originally Posted by jdansby1 View Post
Street racing kills-Go kill yourself!
BLUE MUSTANG OWNERS CLUB
FOUNDER MEMBER # 1
REtarD HATERS CLUB
CO-FOUNDER MEMBER #2
(Blue Branch Founder)
Old July 2nd, 2008, 12:43 PM   #2
2003 MUSTANG GT
11.86 @ 114.21
anyone????
FOUNDER MEMBER # 1
REtarD HATERS CLUB
Old July 2nd, 2008, 01:08 PM   #3
2003 MUSTANG GT
11.86 @ 114.21
well thanks for all the help guys
FOUNDER MEMBER # 1
REtarD HATERS CLUB
Old July 2nd, 2008, 02:42 PM   #4
Resident Bubblehead
00vabchgt's Avatar
so where is the vacuum leak coming from if it's not the maifold? check all you hoses and make sure the connections are tight...
also, are you throwing any codes?
Submariners Do It Deeper
Military Crew
MM1 (SS)
Bluenose
US Navy Veteran
Originally Posted by MamaStang View Post
"Boy Danny....nice cock ya got there. "
Old July 2nd, 2008, 05:53 PM   #5
2000 GT
Sounds like a big vacuum leak, or intake leak. And give time for people to respond...
2000 Black convertible GT: KB 14psi, and other goodies...
Old July 3rd, 2008, 02:37 PM   #6
2003 MUSTANG GT
11.86 @ 114.21
i checked all my hoses none of them.... sold msy sct so i cant see what codes its throwing but the check engine light is on so i know its throwing sumn the leak is on driver side around the second injector from the front i cant find where though?
FOUNDER MEMBER # 1
REtarD HATERS CLUB
Old July 3rd, 2008, 02:39 PM   #7
HMUSN's Avatar
91 Sonic Blue Goodness
19.83 @ 12mph
maybe it's a bad injector
Old July 3rd, 2008, 03:20 PM   #8
2003 MUSTANG GT
11.86 @ 114.21
i dont think its the injector... its also running waaaay rich
FOUNDER MEMBER # 1
REtarD HATERS CLUB
Old July 3rd, 2008, 03:23 PM   #9
HMUSN's Avatar
19.83 @ 12mph
uh huh.
check plugs and coil packs and the o rings on the injectors.
Old July 3rd, 2008, 03:25 PM   #10
2003 MUSTANG GT
11.86 @ 114.21
ive had an injector unplegged i know its not that its completely fuckin nuts i mean crazy backfires popn n all kinds of bad shit lol
FOUNDER MEMBER # 1
REtarD HATERS CLUB
Old July 3rd, 2008, 08:04 PM   #11
cliffyk's Avatar
First read the DTC(s) so you will have some idea of what the problem is.
However it seems you know what at least part of the problem is, fix the intake manifold leak...
-cliff knight-
My Mustang GT
2003 GT, UPR X, Magnaflow, 180° stat,
PP 70mm TB & plenum, Sniper Commando tuned
3.73s, 252 rwHP/296 ft.lb.
Multi-fuel: burns gas and rubber...
Old July 3rd, 2008, 08:21 PM   #12
adrenaline=lifeline's Avatar
13.86@100.3
Originally Posted by HMUSN View Post
uh huh.
+1 sounds like my problems wen i had 2 bad plugs. course the sucking sound not quite wat i had cept from back seat
13.96 at 97.49
STOCK AUTO
13.84 at 100.3 (spinning)
W/3.73s
Next Mod: Motor/Tranny swap
Old July 3rd, 2008, 11:16 PM   #13
2kGT's Avatar
Sounds like your car needs to be scrapped. Ill take your wheels
Accufab 75mm tb & plenum
MRT h-pipe
Flowmaster catback
FRPP king cobra clutch
FRPP aluminum driveshaft
FRPP 4.10 gear
TA Perfromance girdle
Steeda tri-ax shifter
Moser 31 spline axles
FRPP C Springs
Old July 4th, 2008, 02:43 AM   #14
superbeef1000's Avatar
im thinking vacume leak ,, inspect all the hoses again i has a problem like this once and it was the hose that comes out of the passanger side valve cover it was a week hose and was sucking shut and created a small crack in the under side of it
Threads Similar to: Big Problems
SCT's Big Air Meter -BA3000 BIG AIR MAF obdnanr V6 Mustangs 26 February 14th, 2008 05:17 PM
New Problems... Big Probelms Speedstang302 5.0 Mustangs 36 December 2nd, 2007 09:34 PM
Replaced Clutch....Big Problems White 89 5.0 Mustangs 40 October 24th, 2007 08:51 PM
new rebuild,big timing problems,need help tim si 5.0 Mustangs 26 October 6th, 2007 12:27 AM
Cobra Big Brake Kit Problems OcOnnor220 99-04 3 August 7th, 2007 04:35 AM
