Discussing How long do nitto DRs last in the 99-04 Forum. my nitto 315s DRs have maybe 7000-8000 miles on them and not only are ...
Old July 5th, 2008, 03:43 PM   #1
Stewie88's Avatar
03 GT
my nitto 315s DRs have maybe 7000-8000 miles on them and not only are they past the wear marker but the right one is getting close to bald in the middle. Ive only done 1 burnout with them and maybe a couple no traction takeoffs. How long are they suppose to last and when well i know when they need to be changed. And also what other 315s are out there that last longer?
2003 GT vert 5-speed K&N, PRO 5.0 shifter, shorty headers, o/r x-pipe, SLP IIs, 4.10s, 17x9 and 17x10.5 DD bullits, Nitto DRs
Old July 5th, 2008, 03:44 PM   #2
DeMello's Avatar
01 nitrous injected GT
12s next time out...
danm you got 8000k out of them
NX wet kit, heater, purge, FPSS, window switch
PLX DM-5 wideband, raptor shiftlight, msd tach adapter
FRPP 410s, JLT CAI, STEEDA tri-ax, SCT x cal 3
STEEDA catback, SLP Loudmouths, UPR o/r X
NITTO Drag Radials, Zoom racing clutch
Old July 5th, 2008, 03:46 PM   #3
Stewie88's Avatar
03 GT
yea whats up with that, how long do they usually last ?
Old July 5th, 2008, 03:49 PM   #4
DeMello's Avatar
well on AM they say up to 12k but it all depends on how you drive
ill be thrilled to get 5k out of mine
Old July 5th, 2008, 03:51 PM   #5
Stewie88's Avatar
03 GT
damn what other 315s out there do you recommend that last longer
Old July 5th, 2008, 03:52 PM   #6
DeMello's Avatar
street tires
Old July 5th, 2008, 03:57 PM   #7
silver99gt's Avatar
1999 Mustang GT
go to like tire rack or discount tire and type in what you want theres quite a few different ones out there, id go with just a nitto 555 though in a 315
Old July 5th, 2008, 04:04 PM   #8
Hillsbaseball08's Avatar
8.15@86 (1/8)
Yea the they don't last at all. I'm about to start just using them at the track.
07 GT500 & 2002 GT: 100 Shot Of Nitrous, 75mm BBK Throttle Body and Plenum, C&L Intake, Flowmaster Exaust, Bassani X Pipes, 3:73 Gear Ratio, BBK Upper and Lower Control Arms, Pro 5.0 Shifter, DiabloSport Tune, Underdrive Pulleys, Line Lock.
Old July 5th, 2008, 04:10 PM   #9
Stewie88's Avatar
03 GT
you can can get the nittos in 315 in none DR?
Old July 5th, 2008, 04:11 PM   #10
DeMello's Avatar
but i think their just as expensive
Old July 5th, 2008, 04:22 PM   #11
Stewie88's Avatar
03 GT
np as long as they last longer i never needed DRs anyways i dont have the power for them and i never go to the track
Old July 5th, 2008, 04:25 PM   #12
DeMello's Avatar
they help alot tho....we pretty much have the same mods and i can definitly tell the difference
Old July 5th, 2008, 04:27 PM   #13
Stewie88's Avatar
03 GT
hmmm i guess once it comes time ill prolly go with the DRs then i prolly miss em if i downgraded in rubber, Thanks
Old July 5th, 2008, 04:30 PM   #14
DeMello's Avatar
no problem
Old July 7th, 2008, 02:59 PM   #15
Blown 03 GT
Almost bald in the middle means you have too much air pressure in them, which makes the wear un evenly and faster. The DRs have more grip than street tires and if your makin decent power and using 90% of the tires grip to put it down all the time they will wear faster. You wont find a anythin othe than a street tire thatll last longer like demello said.
Old July 7th, 2008, 03:10 PM   #16
zinc02GT's Avatar
Slow
get a total of 6 rims. keep 2 for up front and have the other 4 separate. one 2 of the rims put the nittos 555rs and the other 2 put the same size tire as up front to save the 555rs... use the 555rs for the days or weeks you feel antsy and use the others for daily driving
The only way to learn about a car truely is to break something and fix it yourself...
Originally Posted by graystang01 View Post
cams demello'd a viper
nuff said
Old July 7th, 2008, 05:58 PM   #17
Stewie88's Avatar
03 GT
what should my tire pressure be at? Honestly i just put them on the way American Muscle sent them to me.
Old July 7th, 2008, 06:53 PM   #18
Garhfer's Avatar
2004 Mustang GT Conv.
my 315 555r's last like 15k miles, so you just need to lighten up on all the aggressive driving if you want them to last, I drive pretty aggressive on the street but you must be going nuts lol or doing a lot of burnouts...
And as for only using them for the track, there's way better tires out there for track only use so why use nittos for the track only tires?
2004 GT Boosted by Vortech
Old July 7th, 2008, 07:12 PM   #19
Stewie88's Avatar
03 GT
do you have DR nittos cause ive done one real burnout, but i do drive aggresive from time to time usually when im pissed off or really happy. But does anyone know what is a good street DD tire pressure should be at?
Old July 7th, 2008, 07:27 PM   #20
Garhfer's Avatar
Yeah, I have the 555r's which are the Drag Radials. I run 40 psi on the front 35 psi on the rears...
Threads Similar to: How long do nitto DRs last
nitto DRs DeMello The Clubhouse 40 June 4th, 2008 09:55 AM
Nitto DRs only extra 7 bucks :) DeMello The Clubhouse 39 May 28th, 2008 11:45 AM
BFG Comp T/A DRs suprajay79 99-04 3 May 7th, 2008 09:04 AM
DRs on a stock rear? HessiaN257 99-04 16 March 31st, 2008 12:02 PM
Gears and DRs HessiaN257 99-04 6 March 24th, 2007 10:04 PM
