Discussing WHAT?HOW?... to make my 99 GT manual in the 99-04 Forum. I have a 99 mustang gt which i love more dan my gf. I want ...
Old July 5th, 2008, 05:19 PM   #1
1999 Mustang GT
I have a 99 mustang gt which i love more dan my gf. I want to know exactly what I need and how much it would cost to make my mustang into a 5 speed.
Old July 5th, 2008, 05:35 PM   #2
HMUSN's Avatar
91 Sonic Blue Goodness
19.83 @ 12mph
Performance parts and accessories for late model mustangs, including new and recycled parts.
Part Number: AMP-TC96-00aod to T45
Conversion kit includes the following:
- Stock shifter w/ball
- Bell w/Pivot ball
- Starter Plate
- Flywheel w/dowels
- Crossmember and Trans mount
- Wiring
- Pedal box w/Quadrant
- Shifter Boot
- Clutch case
- and all the necessary bolts
NOTE - clutch is optional and you will be retaining your stock drive shaft & computer.
Old July 5th, 2008, 05:50 PM   #3
1999 Mustang GT
Thanks a lot. My friend is selling his wrecked 99 gt 5 speed. Can I just swap all the parts? Is their any mods I have 2 do?
Old July 5th, 2008, 08:04 PM   #4
adrenaline=lifeline's Avatar
13.86@100.3
y swap? put on a manual valvebody
13.96 at 97.49
STOCK AUTO
13.84 at 100.3 (spinning)
W/3.73s
Next Mod: Motor/Tranny swap
Old July 5th, 2008, 08:28 PM   #5
1999 Mustang GT
whats that?
Old July 5th, 2008, 08:32 PM   #6
13.86@100.3
whats that?
makes ur auto a manual minus the clutch
13.96 at 97.49
STOCK AUTO
W/3.73s
Old July 5th, 2008, 08:40 PM   #7
1999 Mustang GT
how u do that?? Damn that sounds kleen.
Old July 5th, 2008, 08:42 PM   #8
1998 Mustang GT
Need to hit the track
i'm at this fork in the road as well. not really sure of what to do with my auto. but don't manual valvebodies always shift roughly? and that's not too streetable
Old July 5th, 2008, 09:22 PM   #9
13.86@100.3
no not if u get a good one, a shift kit, and tune u should be fine. may wanna add stall as well
13.96 at 97.49
STOCK AUTO
W/3.73s
Old July 6th, 2008, 03:30 AM   #10
dude496's Avatar
04 Mustang GT
build up your auto before you start doing manual valve body swaps. The stock tranny isn't the strongest thing around. I blew mine at 18k miles and now its blown again at 40k...worst part is i dont really get on the gas.
Since your friend has a wrecked car, it will be a pretty straight forward swap...assuming all of his parts are in good shape. If i were you i'd take most of his support accessories and use them to get it setup...i wouldnt waste the time on that tranny though. Ford swapped to a better one in late 01, can't remember the model number though...think it was 3650 on the older ones then t45 on the newer ones but dont quote me on that. If you are planning on putting more power to the ground down the road, during the swap would be a perfect time to upgrade to a built tranny.
Old July 6th, 2008, 03:55 AM   #11
1999 Mustang GT
why are the 3650 better? Can I use most of the 99 tranny parts and then change it or no?
Old July 6th, 2008, 07:01 AM   #12
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83
me and doc did a manual swap on his mach not too long ago. its not that bad, ist pretty strait foward. if you have a parts car right there, its easy and all the parts are there. the t45 is a nicer trans imo, but stock for stock the 3650 is a little stronger. the t45 has minor issues with 3/4 fork, and reverse, the 3650 has a rep of not liking aggresive 3-4 shifts, and has minor 3/4 fork issues if abused. the 4r70 and 4r75 are pretty strong in stock form, they however can not be down shifted manually, they drop line pressure and thats their #1 killer. there is a stand alone pcm for the 4r series trans, i do not know if it eliminates the line pressure issue.
stock long block, bolt ons, slicks, and a little squeeze
N/A-12.81@103.7
N2O-11.79@115.8
parting out 04 cobra, pm me for details
Old July 6th, 2008, 09:18 AM   #13
2kGT's Avatar
Originally Posted by dude496 View Post
i wouldnt waste the time on that tranny though. Ford swapped to a better one in late 01, can't remember the model number though...think it was 3650 on the older ones then t45 on the newer ones but dont quote me on that. .
I prefer the 45 - the 3650 is crap. The syncros go out in them like there is no tomorrow.
Accufab 75mm tb & plenum
MRT h-pipe
Flowmaster catback
FRPP king cobra clutch
FRPP aluminum driveshaft
FRPP 4.10 gear
TA Perfromance girdle
Steeda tri-ax shifter
Moser 31 spline axles
FRPP C Springs
Old July 6th, 2008, 11:28 AM   #14
Mustang RacR94's Avatar
03 mach 1
13.2@109
my mach has the 3650, and i hate it, blew a 2nd gear syncro already, locks me out of first sometimes, unless im at a dead stop, and i never even powershifted it, maybe im just running into bad luck, but i hear alot of bad stories about the 3650
2003 Mach 1, 5 speed
MM MACH 1 CREW
"Dont worry ive locked horns with this fucker before"- TasteMyThunder
www.myspace.com/mustangracr94
Old July 6th, 2008, 11:30 AM   #15
03 mach 1
13.2@109
and how do you shift with a manual minus the clutch, i know how to do it on my stick but that requires matching the rpms and thats not efficent
how does it work with the manual valve body? or do you just push the auto stick into a postion that says for example
1
2
3
4
and you just slid it up and down to choose gears? never heard of one of those
MM MACH 1 CREW
Old July 6th, 2008, 12:37 PM   #16
2000 mustang gt
11.79@115.83
its just an auto, but you have to select the gear you want it in. the trans does not shift at all on its own, you manually select the gearing. i do not recommend it for street use at all.
N/A-12.81@103.7
N2O-11.79@115.8
Old July 6th, 2008, 12:53 PM   #17
dude496's Avatar
04 Mustang GT
big time +1 there.
You will not see any benefits out of it unless you are making serious power.
Threads Similar to: WHAT?HOW?... to make my 99 GT manual
Manual usafimj 2005+ 3 December 14th, 2007 11:55 PM
Manual Youngin The Clubhouse 13 September 16th, 2007 07:15 PM
manual criptez V6 Mustangs 2 July 7th, 2007 02:42 AM
Hanes Manual or Bolt On Manual nHuman 96-98 2 February 21st, 2007 10:25 PM
MAKE SOME XMAS CASH TRADE INTERIORS WITH ME! MAKE $$ TO BOOT mediaultra Want to Buy 0 November 26th, 2006 12:40 AM
