LinkBack (1) | Thread Tools |
#1
![]() iTrader: 1 reviews
When should you replace coil packs
I'm sure as hell not about to spend $520 on new coil packs when i dont need to.
so when should you replace them, if you even do? there are some accel ones for $30 a piece but still pricey.
48.47@ 12.58
when they break.
no need to upgrade.
well how do i know when theyre 'broken' or do you mean like physically break?
btw how do i get to my spart plugs without taking the fuel rail off.
48.47@ 12.58
your car would not fire in that cylinder. you would know if a coil pack was bad.
as far as the fuel rail you just have to play with it a little and they will come out. I never took my fuel rail off when changing my plugs in my 01 GT
yeah but arent they directly under the rail, which means you cant get at them?
48.47@ 12.58
you can get to them without removing the fuel rail. it's just easier to remove the fuel rail for some people.
ah, ill have to try that then. is there a 'how-to' somewhere?
48.47@ 12.58
and i gap them between 1.32 mm and 1.42 mm?
48.47@ 12.58
.054 or whatever the conversion comes out to in mm
48.47@ 12.58
comes out to around 1.3716 mm
yeah 0.052 to 0.056 in
thanks
48.47@ 12.58
bahaha
i removed the fuel rail before i did mine just make sure to bleed the pressure off first or it makes a big mess
2004 Black Mustang GtWhen I see a 5.0...I respect my elders. |
Absolutely no reason to pull the rails. Just take out the bolts, twist the coil a little and it will pop right out of there.
2003 Cobra 9.5 @ 146 on radials Just a few bolt ons with a good tune 04 Mach1 9.78 @ 138.9 |
correct me if im wrong, but if you get a 9.5 second quarter mile, shouldnt you be going faster than 146?
#18 | |
That was with a loose converter on a maiden voyage with a new setup.
Here is a link to the video for you if you would like to see it
2000 GT
Your car will throw a code that even says what cylinder is out, there will be a primary circuit failure or whatnot.
And swivel sockets are your friend, dont remove the fuel rail. Just make sure you thread the plugs in by hand (without the ratchet) to make sure you dont cross thread.
2000 Black convertible GT: KB 15psi, and other goodies... ![]() 1971 Datsun 240 z: Header and rebuilt motor. (The DD) |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/79017-when-should-you-replace-coil-packs.html
| When should you replace coil packs | This thread | Refback | July 6th, 2008 10:53 PM | |
Threads Similar to: When should you replace coil packs
| coil packs | ricks01 | Modular Mustangs | 11 | July 13th, 2008 12:40 PM |
| Coil Packs or COP's?? | 68 dlxcoupe | 4V / SVT | 11 | April 28th, 2008 09:11 PM |
| Replacing coil packs on 02 gt | f4isvt | Modular Mustangs | 5 | September 3rd, 2007 09:07 PM |
| 2005-2007 Mustang GT 3V Coil Packs & Coil-on-Plug Connec | ozan169 | 2005 - 2010 | 4 | February 7th, 2007 09:03 PM |
| Help with coil packs | 99modular | 99-04 | 2 | July 23rd, 2006 09:09 PM |
