Discussing lifter for degreeing in the 99-04 Forum. After a few hours of searching I have found nothing but mixed info on using ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
After a few hours of searching I have found nothing but mixed info on using a solid vs hyd. lifter for degreeing. Im trying to figure out which is true before I buy a solid lifter from MMR. Ive read that a solid lifter isnt needed, then the next post will say that one is needed, next post says that it is only needed to chek/test open/close events and not intake center line degreeing.
you can use a collapsed hyd for degreeing by the centerline method(max lift). this is how I did mine and I checked it with a adjustable solid and the measurements where the same. you HAVE to use an adj. solid to degree from the open/close events
99 limited edition conv. KB 2.1 9 psi intercooled.vt stage 3 blower cams,gt40 fp/bap,vt covers,frpp 3:73's,demolet cai,accufab 75mm tb,Sct Ba 2400,tri-ax,bfg kdw's,magnaflowsTuned by Joe at http://www.tricktuners.com |
Thanks, and by collapsed you mean the lifter is sitting down in the head as far as it can correct? Once again something ive read about but no specifics as to exactly what collaspsed is referring to.
yes,stick it in a vise and slowly collapse it to the bottom of travel
Threads Similar to: lifter for degreeing
| Last Question Before Degreeing Cams | andres0286 | 99-04 | 6 | June 7th, 2008 01:39 AM |
| Cam Degreeing Help!! | andres0286 | 99-04 | 4 | May 31st, 2008 12:09 PM |
| Degreeing a cam | shurb125 | 5.0 Mustangs | 30 | December 27th, 2007 11:31 PM |
| How much lift at lifter? | 5literJeff | 5.0 Mustangs | 2 | March 15th, 2007 10:00 PM |
| Overview Degreeing a cam | IcantDo55 | 5.0 Mustangs | 0 | October 4th, 2005 12:25 PM |
