Discussing shift kit in the 99-04 Forum. i was lookin around for a shift kit, and i was readin some bad stuff! ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
shift kit
i was lookin around for a shift kit, and i was readin some bad stuff! i'm thinkin about gettin one of those electronic shift improvers instead. does anyone have any info on this subject? what do you recomend?
91 Sonic Blue Goodness
19.83 @ 12mph
you want an electronic shift improver? Buy a tuner.
I put a transgo in my f150 awhile back and it was junk. Went back to stock and then put a b&m in about 5 months ago. The b&m works great but its bit too firm for just general street driving. Even if youre at low rpms taking off from a light when it hits 1-2 it gives you a real good jerk. I put a fairbanks in my 01 mustang about 2 weeks ago and love it. Shifts arent uncomforable when crusing in town like the b&m but when you get on it you can definetly feel it.
hey thanx, i'll check out that fairbanks! the reason i was lookin at the electronic one was because you don't have to remove the trans pan to install, and it has a switch with 2 settings for like 40 bucks.
I read some stuff about those while looking at the kits for the f150. Im not sure how accurate or true it is but I read about them having issues w/ cooking electrical components. I got the fairbanks from ford-aode.com. A lot of people seem to like the "j-mod" as well but I never have been too big of a fan of it as I never could find clear straight foward directions on how to do it.
19.83 @ 12mph
^ ask itschristorress on here.. he knows a lot about them
2001 GT
there are a 100 threads on this ??????? do the jmod and enjoy
2001 Gt,auto,J mod, 4:10s, B&M cooler, Hitech stage 2's, NX plate 100 shot, 75 mm tb, C&L upper plenum,BBK X with magnaflow's,Black FR 500,S,SCT tune from Bama chips.
2001 GT
well it very ease to install and there are a couple companies that sell them.I got mine from vap auto VAP Auto - Intake Spacers, J-Mod Kits & more!
04 Mustang GT
wait he has a 04...didnt they start doing the j-mod on the 4r70w's back in late 02?
#11 | |
2001 GT
yes you are correct
well vap auto is out of stock, but i found em at bc-automotive for $300. do ya'll think thats too much to give for one? how much should i be expecting to pay?
Are you sure about this?
I know they (Ford) *did* change the accumulator stuff, which was part of the original J-Mod, but I don't believe they enlarged the holes in the separator plate which is the second part of the J-Mod. To the OP all you need from VAP is the separator plate which is in stock I believe. That's where I purchased mine. You don't need to purchase the entire valve body because there is no drilling in the valve body with a J-Mod... Simply drop the pan, drop the valve body and install the J-Modded separator plate and new gaskets, bolt it all together, put in fresh fluid and you are good to go. If you find that you don't like it, just remove the plate and re-install your orignal. Here is the site with everything you need to know about J-Mod. TCCoA Transmission Article - Index BTW I am installing mine this week in my 2003 GT Vert... |
N/A 4v Guru
2003 Mach 1
All but one hole in the later 4r7's has been enlarged just like the j-mod. The big shift gain will be a spacer and stiffer spring for the accumulators if you are not wanting to go inside the valve body itself.
![]() Gone To Basic Training |
Doc8224 didnt you have the transco kit? how did you like it?
![]() 2004 Mustang GT DD-2002 Tacoma 4x4 |
N/A 4v Guru
2003 Mach 1
I loved the hell out of it. Just don't manualy down shift everywhere you go and you will be fine. I have been in 10 thousand discussions about the trans go kit sux, so and so forth, but I have used them alot and never had a problem. What killed mine was manualy downshifting all the time from high speed. It doesn't have enough fluid pressure to handle it when you aren't in the gas so it eats it up. It was my fault. i will tell you that if you lock up your auto do not drive it. It can create an extreme amount of load on the crank and cause thrust bearing failure. thats what happend to me.
#17 | |
Threads Similar to: shift kit
| shift kit | bullitt1238 | Drivetrain | 10 | April 9th, 2008 11:53 AM |
| Shift kit for 96 gt...? | jwood1389 | 96-98 | 5 | February 7th, 2008 01:43 AM |
| shift kit | mmvi | V6 Mustangs | 20 | June 11th, 2007 05:30 PM |
| shift kit | burin_rubber | Drivetrain | 3 | March 8th, 2007 09:58 PM |
| Shift kit | Mkenne4@tampabay.rr.com | V6 Mustangs | 13 | December 20th, 2006 01:57 AM |
