Discussing QA1 Fitment Problems in the 99-04 Forum. The steering shaft hits the header going towards the driver side when it almost lines ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
All Throttle with a Bottle
12.91@105.29 @ 5800 FT
The steering shaft hits the header going towards the driver side when it almost lines up to the rack and pinion, but when the shaft isnt touching the header at all its almost an inch off.
How do offset rack bushings work and do you think they will fix my problem? I dont know how much difference its going to make, but an inch would be nice if I could get a set that would do that much difference.
![]() We expect shit to break, look foward to realizing exactly when it is happening, and than obsess about dropping plenty of cash to rebuild stronger, so we can try to run it hard as hell and break again. We are sick individuals.
2004 Mustang Mach 1
13.81@104.11
I don't know if this completely relates but do you have a set of C/C plates and are you sure you bought the right K-member? QA1 has two K-members and one if the the SN95s the other is for the New Edges. As far as the C/C plates go I've seen where sometimes they are required with an upgraded K-member, for what reason I'm not totally sure that's why I asked.
![]() 302rwhp 321tq |
2000 mustang gt
11.79@115.83
i never had any fitment issues out of mine, for the most part everything went right together. i was using stock bushings till my offset ones got here, it just popped alot. i think i have another set if you need them. the hole is closer to the bottom of the rack and pinion which raises it up a little bit. i know everything is really close on fitment, the steering shaft seems it is about to hit but it doesnt. if needed i might be able to get some pics on the wifes next day off.
stock long block, bolt ons, slicks, and a little squeeze N/A-12.81@103.7 N2O-11.79@115.8 parting out 04 cobra, pm me for details |
Threads Similar to: QA1 Fitment Problems
| pics of install qa1 k-member | tom2000r | 99-04 | 13 | May 6th, 2008 11:06 PM |
| For sale: QA1 k-member and control arms | Darrell | Chassis/Suspension/Brakes | 1 | April 22nd, 2008 04:17 AM |
| QA1 Tubular Control Arms (A-Arms) | keith0s | 5.0 Mustangs | 3 | October 19th, 2007 12:20 PM |
| O2 sensor fitment problems | throwedoff | 99-04 | 7 | May 9th, 2007 08:21 PM |
| QA1, K member full set-up and other moduar parts | Boomer | For Sale | 4 | March 26th, 2007 09:11 PM |
