Discussing Great deals on electric water pumps in the 99-04 Forum. Well I just found a hell of a deal on a new Meziere WP I ...
Old July 6th, 2008, 11:24 PM   #1
jivepepper's Avatar
Well I just found a hell of a deal on a new Meziere WP I got it and the relay kit for 299 shipped.
I bought it from summit for 251 and 34.96 for the relay wiring kit. I had to get them to price match on the relay kit. Meziere had it cheaper on their sight. Summit orginally wanted 45 for the relay wiring kit
VORTECH V1 S-TRIM
11.26@ 129 with only 516/453 on street tires
New times coming soon with 598/531..........
Old July 6th, 2008, 11:26 PM   #2
NavySeabee87's Avatar
2004 Mustang Gt
are water pumps worth it?
Flowmaster Catback, Bassani O/R X, Steeda UDP, RAI,
TBI-Black Bullitt Wheels/Nitto Tires, Lightbar,4.10 Gears, Adj. Shocks/struts, Plenum/T-body,Springs, MM CC Plates, Waiting on Procharger D1SC
MILITARY CREW
E4
Old July 6th, 2008, 11:35 PM   #3
jivepepper's Avatar
11-14 hp for $300 is not bad and it runs cooler in traffic. Plus I want to run a bigger crank pulley. So this keeps me from over spinning the water pump.
VORTECH V1 S-TRIM
Old July 6th, 2008, 11:37 PM   #4
2004 Mustang Gt
i was looking at buying one, just wasnt sure the actual difference it does. Would you think its a good time to buy it now for me? Or should i wait
MILITARY CREW
E4
Old July 6th, 2008, 11:53 PM   #5
2001 Mustang GT
12.4@111 (N/A)
hey what's up Jivepepper?
12.4 @ 111mph N/A 2V... (first trip out) in desperate need of a driver mod
N2O times coming soon
my junk at the trackhttp://www.moddedmustangs.com/forums/signaturepics/sigpic17788_2.gif
Old July 6th, 2008, 11:57 PM   #6
How hard is the install on this guy?
2004 Comp Orange GT - SLP Loudmouth, Pypes O/R X Pipe w/mils, Steeda Tri-ax, JLT Ram Air
Old July 7th, 2008, 12:25 AM   #7
B0B
B0B's Avatar
2001 Mustang GT
the speed of smell
i also heard the stewart water pumps can add double digit hp gains.. when/if my pump goes out i'll get one or the other.
'01 GT
P-1SC 383rwhp, 380rwtq
2003 Rubicon (DD)
05 Suzuki SV650S 55mpg
moddedmustang's drunk story teller
www.myspace.com/jeepwheelerbob
Old July 7th, 2008, 12:32 AM   #8
Sounds like this may be a well worth it upgrade... Might have to think about picking one up
Old July 7th, 2008, 12:40 AM   #9
jivepepper's Avatar
It would work nice with your udp's to free up some wasted power. I can't find any where else for less then 350 without the relay kit and before shipping.
Not much how's the beast running?
Not hard at all. Just release the tension off the belt remove 4 bolts reinstall and do the wiring..
I'm not familar with the stewarts?
Like I said the main reason I wanted it was so I could run a bigger crank pulley to help make more boost.
VORTECH V1 S-TRIM
Old July 7th, 2008, 12:53 AM   #10
lilmarc1988's Avatar
2001 mustang gt
hey do you need the relay kit? and the extra 3-4 hp is worth $100+ over the stewarts water pump?
Silver Vehicle Club Member #5
http://www.cardomain.com/ride/3112249
sex is like math, u add the bed, subtract the clothes, divide the legs, leave your solution, and pray you dont multiply!
Old July 7th, 2008, 01:30 AM   #11
jivepepper's Avatar
Well the relay kit allows you take the power right where the battery hooks to the fues box under the hood but still be activated when the key is turned.
You could always get your power from a switched power soure but it might have a hard time getting the amps it needs to run correctly.
I like the meizere because of it's great rep for durabilty. Last thing you want is a electric pump failing and your motor overheating.
VORTECH V1 S-TRIM
Old July 7th, 2008, 01:38 AM   #12
99mustanggtman's Avatar
isnt the stewart pump not electric?
Vortech V2- S-Trim
Car is for sale. $7500 w/o the blower.
http://www.moddedmustangs.com/forums...laser-red.html
Old July 7th, 2008, 01:48 AM   #13
2000 GT
stewart is just an efficient belt driven water pump. I heard pros and cons both ways. Ill probably end up with an electric water pump, i have water temp, and intercooler temp gauge, so i would know to turn her off if it does go out.
think somebody had the relay stop working a week or so back on theirs.
2000 Black convertible GT: KB 15psi, and other goodies...
Old July 7th, 2008, 02:38 AM   #14
Mach Boy's Avatar
2004 Mustang Mach 1
13.81@104.11
The Stewart pump does not add double digit gains, maybe crank, but not to the wheels and it is NOT electrical. Mezieres used to be $100 more than that I believe so that is a good deal. It would be a good investment to get a water temperature gauge to compliment the Meziere if any of you are thinking of buying one. I think I bought my Autometer mechanical water temp gauge for ~$45 and the upgrade to an electrical gauge is maybe $20-$30 more.
I do have one question though. Do you have to buy a smaller belt when you put on an electric pump or attach another pulley?
302rwhp 321tq
Old July 7th, 2008, 08:44 AM   #15
Eagle2000GT's Avatar
The pump comes with an idler pulley that allows you to use the same belt. I bought one because I needed to get rid of the underdrive pulleys when the supercharger was installed. Mine is installed with the relay and I had to have the relay replaced not long ago. The car had strange symptoms. It started spraying coolant out the radiator cap before there was any sign of overheating. If it happens again I now know to hot wire around the relay to keep the pump running.
latest tune: 370 rwhp/377 rwtq
Garage: http://www.moddedmustangs.com/forums...-member-11329/
Previously Owned:
1966 Coronet 500, 426 ci est. 290-300 rwhp
1969 Camaro RS/SS, 350 ci est. 210-220 rwhp
Today is the real muscle car era.
Old July 7th, 2008, 06:16 PM   #16
2001 Mustang GT
12.4@111 (N/A)
I'm headed back to the dyno tomorrow so I should know then
Old July 8th, 2008, 02:27 PM   #17
jivepepper's Avatar
I knew it was a typo lmao they have already made then unavialiable. Its says NA on the price and gives you a link to a subsutute for 350 instead of 250.
I got mine but It wouldn't let me add it to cart myself. So I had to call it in. That was sunday and they just now shipped it. I don't think they wanted let me have it fot that much.
I also noticed that they dropped the handleing so I saved another 12 dollars.
VORTECH V1 S-TRIM
Old July 10th, 2008, 08:36 PM   #18
Mach Boy's Avatar
2004 Mustang Mach 1
13.81@104.11
FYI it's back to $350
302rwhp 321tq
Old July 10th, 2008, 09:48 PM   #19
July 08 ROTM
futureMACH1racer's Avatar
2004 Mach 1
Too Slow
How about 10-12hp from the Stewart Water Pump for $150.00 IMHO it's a much better deal for the gain.
For Mid 01-04
EMP/Stewart Components STE50046S - EMP Stewart Ford Mustang 4.6L High Performance Water Pumps - summitracing.com
For 96-01
EMP/Stewart Components STE50046L - EMP Stewart Ford Mustang 4.6L High Performance Water Pumps - summitracing.com
MM MACH 1 CREW MEMBER #2
McCain/Palin '08
Arsenal0328 (10:32:19 PM): mso gives me a raging hard on
Old July 10th, 2008, 10:27 PM   #20
jivepepper's Avatar
They only had one I guess. I bought and went na on the price. I think it was a mistake. I got it today and the connector was cracked but it still works. It has a black painted idler pulley instead of the aluminum. Maybe it discontinued?
Here's link
Meziere Enterprises WP346 - Meziere Modular Electric Water Pumps - summitracing.com
For Mid 01-04
For 96-01
I'd have to see real world dyno tests. An mechanical pump will never out perform an electric one. The motor dosen't have to turn anything.
There are other reasons to run an electric wp. With my overdrive pulley I would be spinning the wp to fast and air rating the coolant, and it's better in traffic for cooling also.
VORTECH V1 S-TRIM
Threads Similar to: Great deals on electric water pumps
electronic water pumps? cj1220 99-04 2 February 1st, 2008 05:43 PM
electric water pump Newtgadget 5.0 Mustangs 12 October 29th, 2007 10:06 PM
Electric Water Pump MyBloodRunsBlue 99-04 16 January 27th, 2007 08:10 PM
Advice on inline electric fuel pumps 83 5.0 5.0 Mustangs 4 November 28th, 2006 06:26 PM
performance water pumps? cdunc24 5.0 Mustangs 4 August 21st, 2006 12:33 PM
