Discussing UDPs to stock...Who has done it? in the 99-04 Forum. Question above....answers below?...
Old July 7th, 2008, 10:11 AM   #1
~C~
~C~'s Avatar
Y2K YellowJacket GT
~TBD~
BLOWN Bumblebeast!
370 rwhp and 381 ft lbs
MILITARY CREW
LT
August Birthday Club Co-Founder
"Like the blind man says......We shall see...."
Old July 7th, 2008, 10:33 AM   #2
MM's Mad Scientist
2003 GT
Street Fast 16.9@76MPH
Are you asking if anyone has replaced the UDP's with stock components?
Old July 7th, 2008, 10:54 AM   #3
2000 Ford Mustang GT
14.41
i dont see why that would be so hard... i no my buddy's GT with a VQ-2 he put stock back on because the Steeda was robbing power and lowering his PSI
K&N intake, Diablosport predator, Steeda Underdrive pulley set, Steeda Tri-ax, SLP Catted X-pipe, Flowmaster 50 series DeltaFlow's, Sumitomo HTRZ+ 255\45\17's, Pro Products Plenum\70mm TB kit.
now that i can drive, hope to break my crappy 14.4
Old July 7th, 2008, 11:42 AM   #4
Eagle2000GT's Avatar
Since the previous owner installed the UDPs I didn't have the stock pulleys to put back on. But I went back to a stock crank pulley and an electric water pump (same diameter as a stock water pump pulley) when I had the Procharger installed.
latest tune: 370 rwhp/377 rwtq
Garage: http://www.moddedmustangs.com/forums...-member-11329/
Previously Owned:
1966 Coronet 500, 426 ci est. 290-300 rwhp
1969 Camaro RS/SS, 350 ci est. 210-220 rwhp
Today is the real muscle car era.
Old July 7th, 2008, 12:11 PM   #5
~C~
~C~'s Avatar
Y2K YellowJacket GT
~TBD~
Yes asking who has done it. I want to make sure I have the right pulleys going on the right places. I will try to post up pics of the stocks I have so some one could identify them correctly. I am pretty sure the small pulley is the alt pulley, the large pulley is the crankshaft pulley, and the one that looks like a hollowed out shell is the water pump. I dont remember since I installed them with a friend back in 2001.
BLOWN Bumblebeast!
MILITARY CREW
LT
Old July 7th, 2008, 02:29 PM   #6
Small is the alt. pulley, heavy one is crank, hollowed out one is water pump. Reinstall is easy. Just remember to get a new crank bolt.
Intercooled Procharger, 3.33" Pulley, Boost Pipe, Magnaflow catback exhaust, UPR offroad x-pipe.
SCT tuned by TonyG @ HP Perfomance.
405.91 rwhp
409.79 rwtq
www.cardomain.com/id/what_a_wang
Old July 7th, 2008, 03:52 PM   #7
~C~
~C~'s Avatar
Y2K YellowJacket GT
~TBD~
thats what I thought. Any other tips before I tear it apart?
BLOWN Bumblebeast!
MILITARY CREW
LT
Old July 7th, 2008, 05:32 PM   #8
Mach Boy's Avatar
2004 Mustang Mach 1
13.81@104.11
It's pretty self explanitory. Just make sure the belt is running smoothly when you get everything back on.
302rwhp 321tq
Old July 7th, 2008, 07:59 PM   #9
~C~
~C~'s Avatar
Y2K YellowJacket GT
~TBD~
So i took another look today and damn there is a ton of room in the front! I now remember we only had to remove or drop the fan a bit to get a little more leverage on the UDP install. With the fan and radiator out the way, it should go by pretty quick. Thanks.
BLOWN Bumblebeast!
MILITARY CREW
LT
Old July 8th, 2008, 04:26 PM   #10
14.41
why did you have to remove the fan? usualy there is enough clearence without removing anything. just remember after you install the belt to crank the motor over a couple times, but dont start it, just so you have a chance to see the belt in motion to make sure everything is smooth. also make sure you follow the torque requirments and steps for the crank pulley, otherwise you might get codes and other problems.
Old July 8th, 2008, 04:27 PM   #11
MM's Mad Scientist
2003 GT
Old July 9th, 2008, 08:12 AM   #12
14.41
Well of course if your crank pulley comes loose your gonna have problems, and from what was explained to me if your crank pulley becomes too lose and wobbles the computer will throw a code. and if that pulley falls off your F***ed if ur stuck on the side of the road
Old July 9th, 2008, 08:52 AM   #13
~C~
~C~'s Avatar
Y2K YellowJacket GT
~TBD~
I dont think I removed the fan, but the bracket holding up the coolant tank I think had to be moved. i dont know if we moved the fan slightly for added clearance or not....its been a while.
BLOWN Bumblebeast!
MILITARY CREW
LT
Old July 9th, 2008, 10:46 AM   #14
o damn so theres no fail safe then? I remember seeing a video and said to crank but dont start a couple times cause the tensioner has to tighten up right?
B&M Short Shifter / Ford Heavy Duty Clutch / 3.73 gears / Nitto Drag Radials / Steeda CAI / Diablo Tuned / Mac LT Headers / Lethal Cated Xpipe / Pypes Exhaust / Stage1 Cam / Smoked headlights and Tail lights / Custom GT floor mats
Old July 9th, 2008, 12:06 PM   #15
dude496's Avatar
04 Mustang GT
huh what? Its an automatic tensioner, it will tighten itself right away. Cranking the engine over a little bit is just to make sure the belt is lining up properly. Pretty easy to miss a rib here and there if your not paying attention.
Yes the crank pulley could come off i guess if the bolt came loose...pretty damn hard for it to come lose though...torque that thing down hard and never look back.
Old July 9th, 2008, 03:49 PM   #16
14.41
no, i wouldnt crank n not look back....
How To Install Underdrive Pulleys | AutoHow.TV
Thats all you need.
P.S., thats stolen from American Muscle just so you know. it is also posted on there website
Threads Similar to: UDPs to stock...Who has done it?
UDPs trade? ~C~ Power Adders 1 July 3rd, 2008 07:15 PM
Udps stangNV 2005+ 5 June 26th, 2008 01:37 PM
05+ Steeda UDPs scramblr Engine 1 June 18th, 2008 09:07 AM
New UDPs Mach Boy 99-04 14 January 9th, 2008 02:13 AM
steeda udps jat 2005+ 12 June 21st, 2007 05:53 PM
