Discussing EGR Solenoid Question in the 99-04 Forum. I put vacuum to both ports on the egr control solenoid and neither one would ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2001 Mustang GT
I put vacuum to both ports on the egr control solenoid and neither one would hold vacuum. I assumed it was bad so I went to AutoZone and got a new one. Well the new one doesn't hold vacuum either. So is there supposed to be a vacuum leak here? I'm I missing something?
#2 | |
From the '03 factory shop manual:
-cliff knight- My Mustang GT 2003 GT, UPR X, Magnaflow, 180° stat, PP 70mm TB & plenum, Sniper Commando tuned 3.73s, 252 rwHP/296 ft.lb. Multi-fuel: burns gas and rubber... |
2001 Mustang GT
Thanks for the info
What problem are you experiencing?
2001 Mustang GT
The car is pinging at high RPM at WOT. I've replaced all the sensors on the car at this point and am running a stock tune with 91octane. Still pinging. I have a wideband installed and see 12.4/1 A/F ratio when it pings. I was checking for vacuum leaks when I noticed if I put vacuum to the EGR solenoid it leaked. I thought for sure that this was my problem but everything I've read so far says its OK.
Threads Similar to: EGR Solenoid Question
| egr vacuum solenoid | mscribellito | V6 Mustangs | 6 | December 30th, 2007 03:25 PM |
| EGR Solenoid | dgt_mustang | V6 Mustangs | 12 | October 20th, 2007 04:15 AM |
| solenoid after solenoid after solennoid | fakesaleen | General Tech | 13 | May 11th, 2007 10:42 PM |
| starter solenoid question | fastford3388 | 5.0 Mustangs | 2 | April 23rd, 2007 11:40 PM |
| EGR Question | Autotech | 94-95 | 3 | September 1st, 2006 02:18 AM |
