Discussing yet another gear thread! in the 99-04 Forum. i'm thinkin about 4.10s on my car but i havn't really heard ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
yet another gear thread! |
2004 gt convertible
pretty damn slow
with an auto more people will choose 4:10's over 3:73's but its still personal preference. Theres a sticky at the top of the 99-04 section to look at if you havent already that will hep with further questions.
![]() give blood play hockey ![]() Add me= www.myspace.com/brandonthorpe26 silver vehicle club #4 |
4.30s for an auto, 4.10s for a manual.
Accufab 75mm tb & plenum MRT h-pipe Flowmaster catback FRPP king cobra clutch FRPP aluminum driveshaft FRPP 4.10 gear TA Perfromance girdle Steeda tri-ax shifter Moser 31 spline axles FRPP C Springs |
is there anything i can buy to beef up my trac loc too?
have any of you heard of driveline critical speed? i was reading that with the 4.10s at 76mph your driveline is spinning critically fast and you should be getting alot of vibrations and such.
2000 GT
4.10s are fine, almost everybody gets them. Your differential will be fine unless you have serious power, and are running radials or slicks on a track.
2000 Black convertible GT: KB 15psi, and other goodies... |
2004 Mustang GT Conv.
uhm, that's funny because at like 76mph my car does shake a little, and I have 4.10's uhmm... I swapped out my tires and all and it still does it... my rotors and all are brand new too... maybe that's the reason... I was trying to figure it out I figured it was because of my tires or rotors but now I'm kind of lost.... lol
![]() 2004 GT Boosted by Vortech |
2003 Mustang GT
Every rotating shaft has a critical speed. It's just the nature of the material. Simple solution, don't drive at 76mph. Jump up/down 1 or 2 mph and it should stop.
In 5th with a 3650 the driveshaft spins at 1.61 times engine speed, with 4.10 and lower gears the driveshaft can really get humming at speeds over 75. With the OEM 3.27 gears at 80 the engine's spinning 2200 rpm and the driveshaft at 3540 rpm. With 4.10s the driveshaft will be spinning around 4400 rpm at 80.
An aluminum driveshaft can help a lot as generally, and within reason, a lesser mass rotating object of given dimensions will exhibit a higher critical speed... |
#10 | |
![]() 2004 Comp Orange GT - SLP Loudmouth, Pypes O/R X Pipe w/mils, Steeda Tri-ax, JLT Ram Air |
#11 | |
2001 Mustang GT
14.1@97 1.9 60ft. first pass - 130 degree track
![]() pm for info on getting snap-on products at 40% off ![]() WTB used nx kit, zex traction control swicth, and Ford GT supercar fuel pump! |
I am, BSME MIT '71...
so what your tryin to say is, if im gonna get 4.10s and i wanna go faster than 75 or 80 i should invest in either a carbon fiber, or aluminum driveshaft?
02 Mustang GT
17.8@16.44
there a guy rolling around by me with an auto GT and he has 4.56's in his
![]() NEXT TO SEX, MY MUSTANG IS BEST |
#15 | |
2004 Black Mustang Gt"I'm a agent of chaos" -Joker,Dark Knight |
2003 Mustang GT
No, what he's saying is if you avoid 76 mph you'll be fine. Critical speed on a rotating shaft is only at a specific speed (multiple speeds but the first harmonic is the worst and most likely the only one to worry about). Get above or below 76 mph (the critical speed) and the vibrations will go away.
#17 | |
That said, an aluminum driveshaft (carbon fibre is a waste of $$) is near the top of my "next mod" list. It's about the cheapest and easest way there is to reduce driveline inertia. |
Editor
GET 3.73's for your auto. . . . unless you drive only 65 on the highway
This entire thread is the largest collection of utter bullsh1t I have ever heard. Except for the part where I said get 430s for your auto.
Lol, 4.10+ is the only way to go n/a...Autos could go steeper
![]() 2001 GT Stang "Bullitt #5583 wanna-be" Best ET 13.8 104mph (b4 motor/gear) D.S.S. ProMod ShrotBlock, DiabloSport Predator, Steeda TriAX, FRPP 4.10s & D-shaft, FRPP 24# injct, Flowmasters, 03 Cobra Brakes, one awesome tune & much more ;] |
Threads Similar to: yet another gear thread!
| Gear to gear on a Mach | stangless24 | 4V / SVT | 25 | June 11th, 2008 06:24 PM |
| Cam gear and camshaft position sensor gear... | 99v6stang | V6 Mustangs | 17 | January 17th, 2008 02:00 PM |
| Does anyone use gear to gear timing? | e3sean | 5.0 Mustangs | 24 | December 27th, 2007 02:37 PM |
| 4.30 Gear to much gear for street use/daily driver? | Bigb2000GT | 99-04 | 10 | March 28th, 2007 05:22 PM |
| OH GEEZ! Another Gear Thread! | einod | V6 Mustangs | 5 | July 28th, 2006 11:46 PM |
