Help Please Timing Cover!!!!
Old July 8th, 2008, 09:50 PM   #1
Stang281GT's Avatar
Stang281GT is on a distinguished road
So to make a long story short, the timing cover on the front of my 02 GT motor is cracked and is now leaking oil. Does anyone know where I can get a replacement besides the ford dealer. Also I don't have time to fix it right now with work and all; does anyone know about how much the dealer will charge me to replace it. Thanks.
Old July 8th, 2008, 10:02 PM   #2
Modified88Dreamer's Avatar
1988 Mustang GT
N/A
Modified88Dreamer will become famous soon enough
Its close to a 4.5 -5 hr job. If your dealer charges about $99/an hour thats $500 right there at most. It's showing me that the (est.) cost for the cover is around $200 give or take a few
"I know that son-of-a-bitch is cheatin! Cause, I'm cheatin and he beat me"!
Old July 8th, 2008, 10:06 PM   #3
Stang281GT's Avatar
Thanks man do you think the best place to take it is the dealer?
It's just so expensive, the motor has 77K on it, I was wondering if it would be worth it just to replace the motor with a 99 cobra motor. What do you think?
Old July 8th, 2008, 10:10 PM   #4
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
cobra motor would be a lot more than 700 bucks. You can take it to any mechanic... its pretty straight forward just takes a bit of time. Think there was one for sale (timing cover) in the classifids
2000 Black convertible GT: KB 15psi, and other goodies...
1971 Datsun 240 z: Header and rebuilt motor. (The DD)
Old July 8th, 2008, 10:16 PM   #5
1988 Mustang GT
N/A
Personally, I myself would take it. It is under warranty by chance? I wonder if something like that is covered and as Ryan said $700 is ALOT cheaper than a cobra motor. Putting in a cobra motor vs a timing cover takes alot more man hours to do therefore leaving you stranded without a car longer.
Old July 8th, 2008, 10:30 PM   #6
Stang281GT's Avatar
Unfortunately it's not under warranty anymore. I think I'll just make an appointment for tomorrow. Do you think it will be less if most of the accessories and pulleys are off the front of the motor? I began to do most of it today.
Old July 8th, 2008, 10:39 PM   #7
1988 Mustang GT
N/A
Doubt it. Most the labor is elsewhere than pulleys. The technician might be like let the service manager know things are missing and then you may get a call from the service manager lol
Old July 8th, 2008, 10:44 PM   #8
1988 Mustang GT
N/A
Heres a list of what they have to do.
Remove the nuts and position the radio ignition interference capacitors aside.
Remove the valve covers.
Remove the cooling fan.
Remove the accessory drive belt.
Remove bolts and the water pump pulley
Remove the nut and position the A/C muffler aside.
Remove the bolts and position the power steering pump aside.
Disconnect the Crankshaft Position (CKP) sensor electrical connector.
Drain the engine oil.
Remove the two support nuts and position the battery cable aside.
Remove the crankshaft front oil seal.
Remove the front oil pan bolts.
Remove the bolts and position the power steering reservoir aside.
Disconnect the Camshaft Position (CMP) sensor electrical connector.
Remove the bolts and the belt idler pulleys.
Remove the engine front cover bolts and the studs.
Discard the gaskets. Clean and inspect the sealing surfaces.
Old July 8th, 2008, 10:47 PM   #9
Garhfer's Avatar
2004 Mustang GT Conv.
Garhfer is on a distinguished road
Send a message via AIM to Garhfer
Just do it yourself and save money... it isn't that complicated.
2004 GT Boosted by Vortech
Old July 9th, 2008, 12:23 AM   #10
BLK01SS's Avatar
1/8 7.95@82.43
BLK01SS has a spectacular aura aboutBLK01SS has a spectacular aura about
A few months ago I had to replace my timing chains and it took me all of about an hour and 1/2 for just the timing cover. You will have to unbolt the valve covers but you won't need to take them completly off and also take off ALL of the pulleys, the fan/motor, and your power steering pump and reservoir then just find the bolts ,take it off. Then when your new one is ready make sure not to mess up the oil pan gasket, by the way there are 4 bolts down there. Then put some high temp RTV around the lip of the oil pan and then your cover is ready to go back on. I mean this is after I took it off about three time times before so give or take an hour or so. You can do it your self man its not that hard. Good Luck
Topless Mustang Club Founder
2000 Mustang Gt 5.4 SOLD
2001 Camaro SS
Originally Posted by rk_2000_Z/28 View Post
Black C6Z06=pure, hot, nasty, unprotected sex
Old July 9th, 2008, 04:37 PM   #11
johnr2001's Avatar
2001 GT
johnr2001 is on a distinguished road
the power steering pump pulley is the worst part of the job.
03 Mach 1 full eaton swap, 18" chrome bullitts, H&R springs, 5.0 shifter, slp2, mac catted H, FRP 4.10's,
443 RWHP/ 386 TQ
Old July 9th, 2008, 04:41 PM   #12
BLK01SS's Avatar
1/8 7.95@82.43
I just took the 4 bolts out of it and droped it, it wasn't that hard
2001 Camaro SS
Old July 9th, 2008, 05:53 PM   #13
The Mean Green
MATT02GT's Avatar
MATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really nice
Ive got a front cover in my garage, let me know if your interested.
Bolt on list in Garage..
Threads Similar to: Help Please Timing Cover!!!!
timing cover Black Five 0h 5.0 Mustangs 3 April 17th, 2008 09:52 AM
Timing Cover 68 dlxcoupe 96-98 3 March 31st, 2008 01:59 AM
timing chain cover mpboy 99-04 3 March 16th, 2008 10:10 PM
my timing cover is aluminum right? YNOT 5.0 Mustangs 4 August 1st, 2007 10:08 PM
Does my timing cover need to be replaced? LaserRed96GT Modular Mustangs 2 July 2nd, 2007 04:16 PM
