Discussing quick help needed in the 99-04 Forum. im trying to repair the thread and put an insert for a sparkplug on my ...
Old July 11th, 2008, 06:40 PM   #1
1999 Mustang GT
quick help needed
im trying to repair the thread and put an insert for a sparkplug on my 99gt head, and i am wondering which inserts to use, theres a small, medium and long one.
Also i purchase a ngk tr55 and the thread is longer than the original autolite double platinum, is that normal?
thx guys.
Old July 12th, 2008, 07:41 AM   #2
andres0286's Avatar
NGK tr55 are ok, they will go down to were they have to
2002 GT SOLD
2003 Mustang GT Cobra Clone
Procharged
http://i247.photobucket.com/albums/g...Weekend059.jpg
Old July 12th, 2008, 07:46 AM   #3
MM's Mad Scientist
acmillr's Avatar
F-16 Killer
Tire Burn @ Warp Speed
Use the long one and measure the distance from the head deck to the top of the spark plug on an existing plug and check the insert depth to assure that the plug isn't in the head too far....
Old July 12th, 2008, 11:10 AM   #4
1999 Mustang GT
well i did that (used the long one) and the spark plug is higher than the previous one about 3/16. Not sure if it matters, i've put everything back together and the car seems to run fine, except the sound of the car is different ??
what i did: i threaded the spark plug hole with the tap putting grease on it to get most of the shaving. then i vacuumed it to get the rest of the shaving (i hope). then put loctite around the insert and screwed it in. then put anti seize on the tr55 spark plug and got it down on the new insert.
Old July 12th, 2008, 12:13 PM   #5
MM's Mad Scientist
acmillr's Avatar
F-16 Killer
You should have used the spark plug to screw in the insert and checked the measurement as you went down. Being a little high probably won't matter, but I doubt that the insert is seated properly if it is too high.
Old July 13th, 2008, 11:09 AM   #6
1999 Mustang GT
oh yeah thats what i did to screw the insert in, the spark plug. still, its about 1/8 to 3/16 higher.
Threads Similar to: quick help needed
Little Help Needed GTsetGO The Clubhouse 3 December 13th, 2007 06:52 PM
what all is needed?? Iownastang 5.0 Mustangs 6 October 24th, 2007 01:44 AM
Quick Question. Help quick. john0315 5.0 Mustangs 7 April 7th, 2007 04:33 PM
Help needed CNASHGO The Clubhouse 0 March 27th, 2007 01:43 PM
What's needed?? 2ndChildhood 94-95 3 December 3rd, 2006 11:49 PM
Forum is powered by vBulletin ©2000 - 2010, Jelsoft Ent. Ltd. & SEO by vBSEO 3.3.2 ©2009, Crawlability, Inc.
