Strut Replacement For Dummies - Page 3
LinkBack (20) Thread Tools
Old August 3rd, 2008, 04:10 AM   #41
Look Ma! My First Post!
2002GTvert is on a distinguished road
Sorry in advance for the novice questions. I have looked around here and this seems to be the best thread for the type of info I am looking for.
I have a 2002 GT Convert. Front end feels like mush. I started searching for solutions, and dont mind doing it myself, and I read this thread. Excellent job, thank you.
I have seen many types of solutions. Coil over may be too complex for me at this stage. So I am probably looking at replacement of front struts and perhaps springs. I see kits with struts, shocks, and springs that say they lower 1.5 inches for a better ride. Not sure I need lowering....or shocks, as back feels ok I guess.
My main problem is with my choice of strut in relation to spring. I do not see any lowered struts vs stock struts....the option is just sport or other titles to imply sportyness. This has confused me.
If I use a kit...and lower for 1.5 inches...and use say Bilstien Strut, that strut is for the lowered clearance. But if I keep the stock spring, I see absolutely no difference in strut. Would I use the same strut for a stock spring setup as I would for a 1.5 inch lowered spring setup?
How can I tell the difference between a "stock spring" strut and a "1.5 inch lower" strut? Or perhaps even, is there a difference?
Thanks in advance. Great forum here.
Old August 3rd, 2008, 02:28 PM   #42
Genibus Nitito Canus
HBK_2007's Avatar
2009 Ford Mustang GT
HBK_2007 will become famous soon enough
Send a message via MSN to HBK_2007
honestly if u gonna get new springs, i would convert to a coil over, its not that hard if u know how to read the directions and ask questions on here. im not sure about ur strut question tho
Red 1996 GT: JLT RAI, Steeda Underdrive pullies, Stewart Waterpump; nothing to brag about
Black 2009 45th aniverary edition GT 5 speed: K&N CAI, BBK Twin 62mm Throttle Body, BBK Underdrive Pullies, SLP Loudmouth
Old August 4th, 2008, 10:27 AM   #43
MM's Mad Scientist
acmillr's Avatar
Slow Fella
acmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to behold
Coilovers are a little "floppy" at times. The struts will work for dropped or stock height cars...
Old August 6th, 2008, 05:32 PM   #44
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
nice long tubes, btw.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old November 30th, 2008, 01:57 AM   #45
V6Power is an unknown quantity at this point
great write-up
Old November 30th, 2008, 01:52 PM   #46
MM's Mad Scientist
acmillr's Avatar
Slow Fella
Thanks, I wil try to get some more write-ups done pretty soon.
Old July 19th, 2010, 02:04 PM   #47
Zevi2004 is on a distinguished road
Send a message via AIM to Zevi2004
This seems simple, but how do I know my struts need to be replaced? I don't wanna replace them and have it be something else. Also, how much do they cost?
Old December 15th, 2010, 07:05 PM   #48
matholland is on a distinguished road
Thanks man, I just bought shocks/struts, and I am planning on changing them tomorrow. Good write up!
Old December 15th, 2010, 09:27 PM   #49
BaznastyDave's Avatar
2004 Mustang
BaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to all
Subscribe'd for later when i do mine
305/333 WHP/WTQ with CMS Stage II cams
440/552 WHP/WTQ on Spray
7.86 @ 89.1mph, 1.61 60 foot N/A
7.20 @ 98.8MPH 1.55 60 foot on spray
Stock Longblock with Cams
Old February 18th, 2011, 09:30 PM   #50
emack is on a distinguished road
2002 v6
I just changed the struts in my 2002 V6 convert... here's my observation.
Great write up here on how to replace the struts. I found it easier to just remove the single strut nut on the top, rather than disassemble the whole plate. Once you remove the two bottom bolts the strut simply drops out.
Use plenty of penetration fluid, and air tools saves so much time on that top nut. Also if you have a high mileage car, get new bushings, rubber mounts and retainer. The strut installation is super easy... and if you only have to replace the top nut you should be able to avoid a front end alignment. Replacing the shocks and struts made this pony ride like a new car. Best mod for the money, and very easy to do. Good luck! Hope this helps. Thanks for the write up. It helped a lot.
Old August 13th, 2011, 12:13 PM   #51
Jesus Freak - 4V Fan
cobrabro is on a distinguished road
I agree regarding just removing the top nut instead of the plate. I just finished mine and did it both methods, one on each side. I suggest removing and re-installing the top nut with the strut on the car. Those "screwdriver" slots are a pain - make sure you have the biggest screwdriver your local hardware store carries and use something like PB Blaster on the top notes if they are the originals a few days in advance. Half of my time was spent finding the right tool sizes so I thought I would list what worked for my '98:
Stock Top Nut - 15/16
Strut spindle bolts - 13/16
Strut spindle nuts - 15/16
Plate bolts (if needed) - 15mm
New Tokico top nut - 15/16
Old October 24th, 2011, 01:26 AM   #52
2003 3.8 V6 Mustang
lordvoldemort is on a distinguished road
I just removed one of my front struts but I cannot get the top nut off, even with one person holding it with a screwdriver or a vice-grip. I'm thinking it might be easier to put back the strut in, tigthen all the bolts and then loosen the top nut as if I was starting from scratch. My question is :
When you say "removing and re-installing the top nut with the strut on the car", should I be jacking up the lower arm (and compressing the spring) when loosening the top nut ?
Old October 24th, 2011, 01:29 PM   #53
codycat91's Avatar
2003 MUSTANG GT
codycat91 is a jewel in the roughcodycat91 is a jewel in the roughcodycat91 is a jewel in the roughcodycat91 is a jewel in the rough
iTrader: 10 reviews
Nice write up!
4v MMR 4.75 Stroker, Teksid block .020 over, 9.27:1CR, Posi Race Ported Eaton
4v MMR Stroker 1000 / Posi Race Ported Eaton Build
How To: 2v to 4v COP Swap
Old November 3rd, 2011, 01:49 PM   #54
393notch is on a distinguished road
YES, Jack the car up, put a jack or jack stand under the lower a arm, then lower the car to put the wieght on the lower a arm or the spring might fly out and do some serious damage. Maybe even kill u.
Old November 3rd, 2011, 03:34 PM   #55
2003 3.8 V6 Mustang
Thanks.
Actually, I was able to loosen the top hexnut off by having the car on jack stands but not having the spring compressed (no floor jack under the spring). Once I got it loose, I put the floor jack to compress the spring and proceeded further.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/79867-strut-replacement-dummies.html
Anyone know of a Shock and Strut How to?? | Mustang Forums at StangNet This thread Refback April 29th, 2012 09:41 PM
What struts & how to install??? - 2003-04 Mach 1 Registry Owners Club This thread Refback March 12th, 2012 05:21 PM
What prevents struts from popping over the tower? This thread Pingback February 23rd, 2012 01:58 AM
strut nut help - MustangForums.com This thread Refback February 9th, 2012 02:56 PM
Mach 1 springs + bilstein shocks/struts installed (w/ pics) - Page 2 This thread Refback August 26th, 2011 05:15 PM
Mach 1 springs + bilstein shocks/struts installed (w/ pics) This thread Refback May 18th, 2011 12:00 PM
Instructions on How to Install a Strut Tower on a 2000 Mustang GT | eHow.com This thread Refback March 8th, 2011 09:59 AM
Mach 1 springs + bilstein shocks/struts installed (w/ pics) This thread Refback February 14th, 2011 06:50 AM
Anyone know of a Shock and Strut How to?? - Mustang Forums at StangNet This thread Pingback July 4th, 2010 01:16 PM
Mach 1 springs + bilstein shocks/struts installed (w/ pics) - 3.8 Mustang Message Board This thread Refback June 30th, 2010 03:35 AM
Mach 1 springs + bilstein shocks/struts installed (w/ pics) - 3.8 Mustang Message Board This thread Refback June 14th, 2010 03:43 PM
How Strut Replacement - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback April 4th, 2010 01:53 PM
Mach 1 springs + bilstein shocks/struts installed (w/ pics) - 3.8 Mustang Message Board This thread Refback March 12th, 2010 04:06 PM
strut nut help - MustangForums.com This thread Refback January 23rd, 2010 09:09 PM
Mach 1 springs + bilstein shocks/struts installed (w/ pics) - 3.8 Mustang Message Board This thread Refback January 8th, 2010 07:24 PM
Mach 1 springs + bilstein shocks/struts installed (w/ pics) - 3.8 Mustang Message Board This thread Refback January 2nd, 2010 09:47 PM
Mach 1 springs + bilstein shocks/struts installed (w/ pics) - 3.8 Mustang Message Board This thread Refback January 2nd, 2010 05:22 PM
Front Strut Replacement on Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback July 17th, 2009 08:08 AM
Installing lakewood 90/10s - Modular Revolution Forums This thread Refback January 29th, 2009 12:31 PM
Strut Replacement For Dummies This thread Refback July 14th, 2008 12:49 AM
Threads Similar to: Strut Replacement For Dummies
Doing Your First Mod ? Read This...Mods for Dummies ! Fryrice General Tech 18 November 15th, 2010 07:21 PM
PI Intake porting for dummies acmillr 99-04 17 January 21st, 2008 09:27 PM
Mini Starter install for dummies Tony_90fox 5.0 Mustangs 5 September 29th, 2007 09:58 PM
Strut Replacement Gunny 2005 - 2010 3 August 5th, 2007 02:24 PM
Exhaust for Dummies Lord Chabelo General Tech 1 March 6th, 2007 04:25 PM
