front brakes are grabbing
Old July 12th, 2008, 03:52 PM   #1
Swatstallion00 is on a distinguished road
my Buddies front brakes are grabbing on his Mustang and he was wondering if u knew how to fix that?
Old October 17th, 2008, 12:15 PM   #2
scubasteve041186's Avatar
2004 mustang 40th annv.
scubasteve041186 is on a distinguished road
Send a message via MSN to scubasteve041186
meh go to the basics and take them off and put them back on. wait and see if that changes anything maybe some new pads or check if the rotors are warped
Old October 18th, 2008, 09:27 AM   #3
TheUNZippee!'s Avatar
This could be a caliper going bad, seizing up.
Things to watch for are:
-car will pull in the direction of the side the bad caliper is on.
-a sticky caliper can overheat the brake rotor. Look for discoloration on rotors
-when removing and replacing calipers, keep in mind that the piston on the rear brakes must also turn as it pushes in.
-ensure that proper anti-seize lubricant is used at all sliding points of the caliper.
-remove the brake fluid reservoir cap before sliding the pistons back in to the calipers.
-if you're not familiar with working on brakes, do only one side at a time, so you can look at the other side for reference if you forget how something should go together..
Originally Posted by My Wife
Old October 18th, 2008, 10:47 PM   #4
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
+1
Happened on mine...
Threads Similar to: front brakes are grabbing
Putting Front Brakes on Rear? Garhfer 99-04 5 July 5th, 2008 03:02 PM
about to put new brakes front and back Paulnhbtx 99-04 1 January 8th, 2008 12:34 AM
4cyl>V8 front brakes Racinjason81 5.0 Mustangs 1 December 1st, 2007 08:04 PM
Brakes (New Front Calipers) 02stang02 V6 Mustangs 2 September 1st, 2007 02:34 AM
Front Brakes HELP! bbrewer03 96-98 4 May 31st, 2007 10:01 PM
