headers
Old July 13th, 2008, 06:01 PM   #1
moosenuk17's Avatar
2000 ford mustang GT
moosenuk17 is a jewel in the roughmoosenuk17 is a jewel in the roughmoosenuk17 is a jewel in the rough
Send a message via AIM to moosenuk17 Send a message via MSN to moosenuk17 Send a message via Yahoo to moosenuk17
headers
i saw a pair of hedman headers and the tubes for the 7 and eight cylinders are "slip fit" why are they like this? easier to install?
Old July 14th, 2008, 09:12 PM   #2
neverfastenough1's Avatar
Yes the Hedman 88690's have two slipjoints to ease install around steering column. The left side header flange is in two pieces, the front half is attached to the tubes that go behind the steering column. After you swing the column back into place you can slip the two outer tubes together and attach the other half of the flange to the engine. Keeps you from having to remove the entire steering column to slide it through the pipes.
Old July 14th, 2008, 09:30 PM   #3
moosenuk17's Avatar
does this affect air flow? do i have to weld? or is it fine the way it is or is i a bad choice in header?
Old July 14th, 2008, 10:10 PM   #4
Never had any, but they are good hedders. I won't say they won't leak where the two tubes slip together, but they are designed not to need to be welded. They are tork step hedders meaning the tubes get larger the closer they get to the collector. Supposed to help create more torque.
Old July 14th, 2008, 11:32 PM   #5
blk01gt is on a distinguished road
Send a message via AIM to blk01gt
My flowtech headers are slip joint and they leak at the joint. Don`t have any experience with Hedman though.
01 Mustang GT | 5 Speed | Bullitt Intake | 4.10's | Diablo Tuner | JLT CAI | Flowtech LT Headers, bbk catted H, dynomax catback |
01 Carbon Black BMW M3 w/dynomax exhaust
Threads Similar to: headers
Long tube headers or short tube headers? 2much4u 99-04 20 October 11th, 2009 10:49 PM
(2005-2008)Long headers vs shorty Headers RetroKid V6 Mustangs 9 April 12th, 2008 01:14 PM
JBA Headers vs BBK headers 06GTMustang89 2005 - 2010 70 March 18th, 2008 07:59 AM
Headers? ricerraper33 V6 Mustangs 15 January 28th, 2008 03:50 PM
headers DarkSidejoker V6 Mustangs 7 January 24th, 2008 07:24 PM
