Discussing battery terminal corrosion in the 99-04 Forum. I have had an accelerated corrosion on the negative terminal... i mean crazy fast, its ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2000 GT
battery terminal corrosionThink its an electrical issue like overcharging or something? or am i just crazy, and its no big deal.. Have not had problems starting car either.
2000 Black convertible GT: KB 15psi, and other goodies... |
i changed out my cables ends they sale them at auto zone for 5 bucks a piece and cleaned the terminals and use battery post grease on the ends and i havent had a problem since
2004 Black Mustang Gt"I'm a agent of chaos" -Joker,Dark Knight |
2000 GT
I guess ill have to do that. Its weird its happening so fast though. And i did have dielectric grease stuff on there.
just peel the loom on the cables back a lil bit to see hor far the corosion goes down then cut it off there just make sure you leave yourself enough cable to each the battery and clean the terminals off GOOD, baking soda and a lil water eats it off pretty good, and make sure you are not leaking acid around the terminals. also autozone sells terminal protectors im not sure if they really work but i threw them on for the hell of it, i havent had any problems yet
Thats what I did also, and I put the green and red rings on there. I havent ahd a problem that was around 3 or 4 months ago.
Foxlake stage 2 heads, CMS stage 2 cams, Custom Diablo tune, BBK LT's, BBK O/R H, Bassani Race Mufflers, MGW STS, 75MM TB, K&N CAI, Eibach Sportlines, 4.10's Mineral Gray Club Member #1
2000 GT
Ok ill do that, another thing on the to do list lol! Thanks for the response
Just spray them with lube.
![]() Fast, Reliable & Cheap... ...Pick two |
2000 GT
That terminal was the cause of it, its loose and has a little water around it. Going to get it returned! I knew it wasnt just doing that randomly...
Threads Similar to: battery terminal corrosion
| Corrosion | whtpny | Exhaust | 7 | April 3rd, 2008 12:53 AM |
| I'm on Terminal Leave! | 00vabchgt | The Clubhouse | 11 | August 17th, 2007 05:55 PM |
| battery relocation with second battery | onewinner | 5.0 Mustangs | 1 | May 30th, 2007 11:30 AM |
| Battery | Mustang Mike | 99-04 | 2 | February 27th, 2007 07:07 PM |
| I Have A New Battery | 232stang | V6 Mustangs | 9 | November 9th, 2006 06:20 PM |
