Discussing HELP! Buz through my speakers? in the 99-04 Forum. Anyone ever have a problem with a buzzing sound from your speakers? When I turn ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2004 Mustang GT Convert.
When I turn the radio off its stops but comes right back if I turn it on. Usually if I shut the car down and start up again it will stop. Last edited by Volstang : July 17th, 2008 at 10:12 PM. |
keep your cell phone away from your radio they can mess with them
check your ground wire behind the stereo, same problem was going on w/ my dads truck.. and that was the issue
![]() Mods: Fidanza Al Flywheel, Steeda UDP, EMP/Stewart Components WP, PP Plenum, K&N FIPK, Mac Prochamber, Pypes Violator Catback WhtPny's Videos
usually a bad ground, either from your deck or even one of the amps if you have the Mach 460 system. Might be worth regrounding your deck, just find the ground wire and then reconnect it to a good clean ground.
2003 mustang gt
yr 1965 @ 88mph
ground.. make sure theres nothing getting between it like paint, carpet, etc..
03 mustang gt low sexy and slow ![]() NOBAMA O8 |
Thanks! Ill check the ground. I hope thats it.
check a few things, make sure the speaker cover is secure and not vibrating on window, this could cause a constant buzz. Or it could be altenator noise, does the buzzing change pitch when you push the gas? Or you could have blown one or two speakers.
zo•o•tox•in (zō'ə-tŏk'sĭn)-animal poison; venom
It does change pitch when I give it gas, but it doesnt do it all the time. I can go days, weeks, months and then it will start.
2003 mustang gt
yr 1965 @ 88mph
do your lights dim or flicker..
2003 mustang gt
yr 1965 @ 88mph
ill bet you may have just blown a speaker..
2006 GT
13.73@100.32
Its your ground. Take your ground off and use sand paper around where it makes contact with the metal, then wipe it with some alcohol to make sure you get it clean and reconnect. If that doesnt work, might try a ground loop isolater.
Ok, I checked the ground and there are three grounds to my radio. The antenna is grounded, there is a main ground and another I dont know what its for, but I checked and I had continuity to the chassis from all three. And the radio would power up with any one of the three but not without one. So I grounded the 2 wires to a new chassis point and left the antenna alone. But it isnt buzzing currently so I wont know if what I did will fix it. I guss if it never does it again it worked.
Threads Similar to: HELP! Buz through my speakers?
| Speakers | graystang01 | V6 Mustangs | 21 | April 8th, 2008 12:06 PM |
| Speakers! | soccerboy08 | Electronics | 23 | December 9th, 2007 12:18 AM |
| Speakers went out? | HessiaN257 | 99-04 | 5 | April 7th, 2007 11:04 AM |
| speakers | WeCircleTheProblem | Electronics | 3 | March 18th, 2007 11:49 PM |
| Best Speakers | PONYBOY14 | Electronics | 1 | January 26th, 2007 09:45 PM |
