BOV?
Old July 17th, 2008, 10:42 PM   #1
carlos's Avatar
carlos is on a distinguished road
BOV?
Can i use my minirace bypass valve as a BOV? Can I just remove the hose from the valve to the inlet pipe and just blow the air out to the atmosphere? my maf is draw thrue and my IAT sensor is by the throtle body.
Old July 17th, 2008, 11:23 PM   #2
johnr2001's Avatar
2001 GT
johnr2001 is on a distinguished road
I dont see why it would not work.
03 Mach 1 full eaton swap, 18" chrome bullitts, H&R springs, 5.0 shifter, slp2, mac catted H, FRP 4.10's,
443 RWHP/ 386 TQ
Old July 18th, 2008, 01:54 AM   #3
B0B
Boost gets you laid
B0B's Avatar
2001 Mustang GT
12.93@113.7 (on the 18's)
B0B is just really niceB0B is just really niceB0B is just really niceB0B is just really nice
Send a message via AIM to B0B
if its a draw through you need to keep the bypass, if its blow through you can run a BOV but with a draw through you will disrupt the air/fuel mixture if you use a blowoff valve.
'01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress
2003 Rubicon (wheelin rig)
2008 Silverado 4x4 (towin rig/road queen)
2009 KTM 450 XC-W (Brap Brap!)
Old July 18th, 2008, 02:58 AM   #4
carlos's Avatar
OK thanks!!
Old July 18th, 2008, 03:06 AM   #5
gray8188's Avatar
2003 mustang gt
yr 1965 @ 88mph
gray8188 is just really nicegray8188 is just really nicegray8188 is just really nicegray8188 is just really nice
iTrader: 5 reviews
any vids yet?
i'm pretty sure that when i move into my own place i'm gonna mount an anti aircraft gun on my roof with somebody manning it 24 hours a day.
why?
because it would be fucking AWESOME.[/quote]
Old July 18th, 2008, 02:36 PM   #6
carlos's Avatar
Im a little confused. When you use a bypass, you are blowing the air back into the inlet pipe, which is drawing air from the outside. I dont get why it makes a difference, you still are using the bypass valve regardless of where the air is going to. I was under the impression that the bypass or BOV was only there to relieve the pressure from the discharge pipe to protect the blower. Could you explain alittle more on the air/fuel mixture issue?
Old July 18th, 2008, 04:04 PM   #7
Hunt_chevs's Avatar
88 Gt
Not Slow
there are two types of wastegates,.. the kind that blows into the atmosphere, and the kind that recirculates. Some vehicles do not perform well without the recirculating bov/wastegate. Not Sure if it has anything to do with boosted stangs, but i know that a subaru functions better with a recirculating one
Old July 18th, 2008, 04:33 PM   #8
B0B
Boost gets you laid
B0B's Avatar
2001 Mustang GT
on draw through systems, the mass air meter is before the blower.. it measures all air that goes into the engine, whether its compressed or not. if you run a blowoff valve on a draw through system, once the air goes into the atmosphere the car will think its getting more air than it actually is and cause it to run rich. it will probably backfire when you shift and let off the gas if you run a blowoff on a draw through system, i don't know though. with a blow through the maf is after the blower and bov/bypass valve so it doesn't hurt anything to vent the air back into the atmosphere since it only meters the air that is past everything. if i'm wrong someone please correct me because this is what i interpreted from what chrisj told me
Old July 18th, 2008, 04:45 PM   #9
carlos's Avatar
Ok it makes more sense to me now. Thans BOB
Threads Similar to: BOV?
Setting A BOV shadowgames81 SVO 26 January 7th, 2009 07:13 PM
good bov? hardhitter 99-04 27 October 26th, 2008 10:22 PM
BOV Question MATT02GT 99-04 17 February 21st, 2008 04:10 PM
Svt Bov? AnglicoGT98 99-04 8 January 10th, 2008 01:24 PM
Hisssing BOV? 97Cobra General Tech 2 September 25th, 2006 04:34 PM
