My Car Is Running Too Lean, How Do I Fix It? MY SEVICE ENGINE SOON LIGHT IS ON AND HAS BEEN ON 4-EVER, I CHECKED THE CODES OUT ON THIS SIGHT AND IT SAYS THAT MY CAR IS TOO LEAN HOW DO I FIX THAT!! I HAVE TO GET THE EMISSIONS DONE QUICK SO I CAN PUT ON MY NEW EHAUST FROM HEADERS BACK!! YEAH!! !! 40 SERIES TOO!!
11.47@120.58
I doubt your car's actually running lean, most likely you have a bad oxygen sensor. What's the code your getting? It'll tell you which 02 sensor is tripping the light. 99% chance it's a bad 02. PS - turn off the caps : )
Perhaps you will be lucky and have it be an O2 sensor. Maybe a plugged fuel flter. TPS. Pressure regulator. Good luck and be sure to let us know what the problem when you get it resolved and hopefully soon.
By the way a lean mix is better for inspection than a rich running motor. mark
'99 Convertible. 4.10's, PYPES catted X-pipe and catback. UDP's. 75mmBBK TB/plenum. JLT CAI. UDP's, Brenspeed custom tuned SCT. SVO intake & SHM cams this winter! Lord willing. |
THE EMISSIONS STATION INSPECT. GAVE ME THESE CODES: P0136 (O2 SENSOR) , P0156 (O2 AGAIN), P1131, P1150, AND P1151. I LOOKED THEM UP ON THIS SITE AND IT SAID IT WAS TOO LEAN.
VICKI REED |
#5 | |
I'm getting the bad O2 sensor codes as well. What sucks is that I bought them brand new along with the extension harnesses. You would think that brand new sensors would work just fine, but obviously mine don't.
Get this. So I found this website where I can type in the part I am looking for and it will send an email to a whole network of junkyards and such looking for the parts. I figure, hey, if I get them off another 2000 model then I am sure they will work. So I get a couple responses. They all want MORE for the used ones than what I paid for the brand new ones! What's up with that?
2000 Mustang GT 5 speed BBK LT headers BBK O/R X pipe Magnaflow Magnapack catback UPR CAI |
I HAVE'NT MESSED WITH MY CAR LATELY, BEEN TOO BUSY WORKING TO PAY FOR MY ADDICTION TO RACING AND OTHER THINGS!! THANX YOU ALL FOR THE FEEDBACK!! I JUST GOT MOST OF MY EXHAUST FOR IT NOW IM WAITING ON THE H-PIPE. MY HUSBAND GOT IT ALL FOR ME OFF E-BAY FOR REAL CHEAP, I CANT WAIT TO PUT IT ON MY SHITBOX!! HE ALSO GOT ME THE ELIMINATORS TOO, WILL IT PASS EMISSIONS IF I PUT ALL THE EXHAUST ON WITH THE ELIMINATORS? IS LONG TUBE CERAMIC COATED HEADERS, H-PIPE, AND 40 SERIES FLOW MASTERS AND TIPS, ALL 2 1/2 IN. I USED TO WORK @ THE EMISSIONS STATION, BUT NEVER HAD ANYONE COME IN WITH THAT SETUP THATS Y I WAS WONDERING. THANX AGAIN GUYS!! I ALSO HAVE A MYSPACE ACCT. TOO ITS UNDER "MRS.REED" IF I'M NOT ON HERE. BUT IT DOES'NT HAVE MY PICS OF MY 92' SHITBOX ONLY MY 02' .
VICKI REED |
From what I understand, LT's will not pass emmissions testing. Now, whether that is with the sniffer or a visual inspection, I don't know. All the MIL's do is trick the car's computer into thinking there are still catalytic converters installed, so that won't affect the outcome of an emmission's testing in any way.
#10 | |
P1150 Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank No. 2 A code P1151 may mean that one or more of the following has happened: Electrical: * Short to VPWR in the harness or HO2S * Water in the harness connector * Open/shorted HO2S circuit * Corrosion or poor mating terminals and wiring * Damaged HO2S * Damaged PCM Fuel System: * Excessive fuel pressure Leaking/contaminated fuel injectors Leaking fuel pressure regulator Low fuel pressure or running out of fuel Vapor recovery system Induction System: * Air leaks after the MAF * Vacuum Leaks PCV system: * Improperly seated engine oil dipstick EGR System: * Leaking gasket * Stuck EGR valve * Leaking diaphragm or EVR Base Engine: * Oil overfill * Cam Timing * Cylinder compression * Exhaust leaks before or near the HO2S(s) |
look my caps lock is off :lala
Threads Similar to: My Car Is Running Too Lean, How Do I Fix It?
| RUNNING LEAN !!!! | 97MUSCLESTANG | Modular Mustangs | 6 | March 5th, 2007 09:03 AM |
| Difference between running rich/lean | 1996gt | 96-98 | 3 | January 29th, 2007 03:30 PM |
| 96 GT Running Lean on both Banks | kennyvick | General Tech | 4 | September 28th, 2006 10:31 PM |
| 1995 5.0 Running Lean | jcc1991 | 5.0 Mustangs | 3 | September 7th, 2006 10:58 AM |
| A Running Lean Code DUN DUN DUN!!!!!!! | 97Cobra | 96-98 | 4 | March 6th, 2006 11:06 PM |
