New tune tomorrow.
LinkBack (1) Thread Tools
Old July 21st, 2008, 06:46 PM   1 links from elsewhere to this Post. Click to view. #1
jivepepper's Avatar
jivepepper is a jewel in the roughjivepepper is a jewel in the roughjivepepper is a jewel in the roughjivepepper is a jewel in the rough
New tune tomorrow.
Well I have an appointment with Don Lasota at Big Shot dyno in the morning. I have added an 8 rib set up, 18 percent overdrive crank pulley and a slightly bigger SC pulley. But I will still be spinning it a little harder than last time. I just hope I'm not getting a little over zealous and spinning my little V1 to hard. Well I know I am, but the s-trims seems to like a little of that. I would just like to see 16-17 psi. I also installed an electric water pump.
I went to Rodeheavers today and had the return for the bypass moved as close to the SC as they could. This seemed to have fixed about 90 percent of my drivabilty problems. I think with a little more tuning it should run pretty smooth.
2000 GT 665/540rwhp/rwtq On pump gas
Best 1/4 638hp street tune 11.01, best trap 134MPH, 80*+day, 10.5" DD Cobra R's & 315/35/17 DR'S
DYNO VID --->
http://www.youtube.com/watch?v=K9uOS732mdA
Old July 21st, 2008, 11:35 PM   #2
Roos85 is on a distinguished road
Send a message via AIM to Roos85
Good luck brotha
2004 Comp Orange GT - SLP Loudmouth, Pypes O/R X Pipe w/mils, Steeda Tri-ax, JLT Ram Air
Old July 22nd, 2008, 01:31 AM   #3
BLK01SS's Avatar
1/8 7.95@82.43
BLK01SS has a spectacular aura aboutBLK01SS has a spectacular aura about
I want numbers! lol
Topless Mustang Club Founder
2000 Mustang Gt 5.4 SOLD
2001 Camaro SS
Originally Posted by rk_2000_Z/28 View Post
Black C6Z06=pure, hot, nasty, unprotected sex
Old July 22nd, 2008, 01:44 AM   #4
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
Good luck dude! Glad you got the drivability figured out... im still working on mine for the past 6 months haha.
2000 Black convertible GT: KB 15psi, and other goodies...
1971 Datsun 240 z: Header and rebuilt motor. (The DD)
Old July 22nd, 2008, 01:48 AM   #5
sxynerd's Avatar
sxynerd is on a distinguished road
Good luck!
Old July 22nd, 2008, 01:51 AM   #6
1999 Mustang GT
hardhitter has a spectacular aura abouthardhitter has a spectacular aura abouthardhitter has a spectacular aura about
Send a message via AIM to hardhitter
Switching to blow through and ditching the bypass was the best thing I ever did. It fixed every problem.
Vortech V2 Si
Old July 22nd, 2008, 02:00 AM   #7
99mustanggtman's Avatar
1999 GT
99mustanggtman will become famous soon enough
iTrader: 7 reviews
Send a message via AIM to 99mustanggtman
good luck man!
Single 67mm turbo, ported pi heads, edelbrock vic jr. manifold w/HPP plenum, terminator shortblock, return fuel system... Goal 600+ rwhp.
Old July 22nd, 2008, 02:16 AM   #8
jivepepper's Avatar
It's not perfecr but alot better than before
I have considered it but I not sure if my Maf would be enough in that configuration. Besides mine is 90mm and it's to find a spot for it because you don't want any reducers right before or after the maf.
Originally Posted by sxynerd View Post
Good luck!
Originally Posted by 99mustanggtman View Post
good luck man!
Thanks guys
DYNO VID --->
Old July 22nd, 2008, 02:45 AM   #9
2000 GT
Wasnt happy with my numbers with all the work im putting into it. Went from 405/415 to 451/483 with 5 more psi (from 10-15) and an aluminum driveshaft. Not to mention drivability is not there yet (get a tune twice a week to tweak it lol).
So im thinking heads, or LT headers. then call it quits for hp mods and just enjoy it (and beef up rear end). What do you think i should get? Big restriction right now is the 2.1 kb inlet being only 75 and thats max. And i have catless midpipe so dont know if LT would make a huge difference. I know heads would probably make more, and cost a bit more.
Old July 22nd, 2008, 03:16 AM   #10
jivepepper's Avatar
I would do blower cams first.
DYNO VID --->
Old July 22nd, 2008, 03:21 AM   #11
2000 GT
Have cams, stage 2 blower vt.
If i get my heads ported will valves need to be changed? Or would they not touch that part? Cause i got stainless steel valves. Dont want to replace em haha. Would probably just buy already ported ones from somewhere if thats the case...
Old July 22nd, 2008, 03:59 AM   #12
1999 Mustang GT
If you're having any driveability problems I would definitely consider it. You can just sell the one you have and buy a different one, that's why I did. I got a 75mm Pro-M but I've heard the 05+ mafs are great too. The suck through caused too many problems for me it just wasn't worth it.
Vortech V2 Si
Old July 22nd, 2008, 05:45 AM   #13
jivepepper's Avatar
I didn't have them until recently that's when I installed the mondo. After that is when I had trouble. I have relocated where it enters the powerpipe and it seems alot better. KB's have made over 900 and they have bypasses just not close to the maf. If you can eliminate the back wash then it actually works better.
Besides my sct maf is a good one. Well I got to start getting ready. I tune at 9am and it's 200 miles away
DYNO VID --->
Old July 22nd, 2008, 03:39 PM   #14
1999 Mustang GT
I don't see how it would work better? The problem I was having had nothing to do with the bypass. It was that since the MAF was so close to the filter that any air blowing on the filter screwed with the MAF reading. I'm not saying you can't make 900hp with a draw through. Mine worked fine at WOT but I'm talking about the driveability. Looking forward to seeing your results.
Vortech V2 Si
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/81168-new-tune-tomorrow.html
New tune tomorrow. This thread Refback July 22nd, 2008 06:23 AM
Threads Similar to: New tune tomorrow.
Dyno tune vs Sniper email tune itschristorres8 The Clubhouse 72 May 22nd, 2008 05:27 AM
07 Mustang K&N intake tune or no tune Mustangsally91 V6 Mustangs 10 January 23rd, 2008 04:11 PM
Getting my tune tomorrow. 03 R Code The Clubhouse 24 February 2nd, 2007 12:47 PM
@Stangliter...going to test and tune tomorrow? L33T The Clubhouse 9 June 2nd, 2006 09:02 PM
Final Dyno tune, TOMORROW!!!!!!!!!!! 1SLO85 The Clubhouse 7 September 7th, 2005 04:48 PM
