gas mileage - Page 2
LinkBack (1) Thread Tools
Old July 22nd, 2008, 04:46 PM   1 links from elsewhere to this Post. Click to view. #21
2002 mustang gt
dowork is an unknown quantity at this point
o ok so wher can i get these and how much?
Old July 22nd, 2008, 04:47 PM   #22
One Man Wolf Pack
06RedfireGT's Avatar
2006 Mustang GT
13ish....maybe
Hey zinc, just a little tip. When taking close up pics like that put the camera into macro mode, that way it won't be all blurry.
And good info BTW.
ΜΟΛΩΝ ΛΑΒΕ
Old July 22nd, 2008, 04:49 PM   #23
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
zinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud of
Go to Oreilly's, Advance Auto Parts, or Autozone. They should carry them. If not theyll probably have them in a day or so.
And good info BTW.
Thank you man. I try lol. Thanks for the tips on the camera. I was ina rush to get em done and wasnt thinking LOL they work though and get the message through.
Mods in garage. Built suspension and gears since posted times.
Old July 22nd, 2008, 04:51 PM   #24
2002 mustang gt
ok so you would recommend the v power of the g power even with a dollar difference?
Old July 22nd, 2008, 04:52 PM   #25
One Man Wolf Pack
2006 Mustang GT
13ish....maybe
lol I'll do that some times.
ΜΟΛΩΝ ΛΑΒΕ
Old July 22nd, 2008, 04:53 PM   #26
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
being that I got the V Power's, Im going to side with them.
Either or will do honestly. I have heard thoguh that when using a platinum plug, you can actually scrape the platinum off the electrode when gapping them. Im not 100% sure on that, but I went with the coppers just to be safe.
Old July 22nd, 2008, 05:00 PM   #27
2002 mustang gt
o ight ill prob just go wit the v power then see if that helps with gas. and now that i think about it i do all city driving so thats prob why mine is lower and traffic in my area is TERRIBLE!!
Old July 22nd, 2008, 05:00 PM   #28
2002 mustang gt
is it easy to replace them?
Old July 22nd, 2008, 05:12 PM   #29
2002 mustang gt
o and i just looked mine are orange not pink
Old July 22nd, 2008, 05:18 PM   #30
whtpny's Avatar
whtpny is on a distinguished road
Send a message via AIM to whtpny
mine are orange, too. i'm a lame-O, though, i just go with motorcraft sp-493 (stockers).. i'll probably try some copper plugs next time since i hear good things about them
Mods: Fidanza Al Flywheel, Steeda UDP, EMP/Stewart Components WP, PP Plenum, K&N FIPK, Mac Prochamber, Magnapacks
WhtPny's Videos
Old July 22nd, 2008, 05:23 PM   #31
2002 mustang gt
i just looked at an installation guide and it talked about takin off the fuel line throttle body and all that do you really have to get into all that to change the spark plugs
Old July 22nd, 2008, 05:28 PM   #32
whtpny's Avatar
nope, i have yet to do that, i just take off the cai to get easier access to them and swivel the injectors a bit to gain room
WhtPny's Videos
Old July 22nd, 2008, 05:30 PM   #33
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
oragne is fine...
theyre still 19# injectors... Ford changed the color on em for what seems to be no good reason...
changing the spark plugs is easy as shit if you have the right tools and a little common knowledge...
Heres how I did mine.
1.Remove the intake hose and intake filter housing.
2. Remove the bolts (7mm) from the COP
3. Get a shopVac and vaccuum around the hole before unscrewing the plug. Doing this helps prevent debris from falling in the chamber.
4. Take a spark plug socket (i think its a 5/8) Ill ahve to check after I post this. Now place it down in the hole and push down and make sure that the socket is snug on the plugs.
5. Pull out the old spark plug and take pics of it. insepect it for damage.
6. Pull out the new plug and make sure the gap is .054 with a spark plug gap gauge
7.Put anti seize around the new spark plug's threads
8. put new spark plug into spark plug socket and make sure its in there snug
9. to avoid cross threading, spin the plug backs as if you were lossening it to align the threads. now tighten it down WITH YOU FINGERS on the exentsion, not the wrench. It should go in smoothly
10. torque it down to 15ft lbs or a little more than snug. use a 3/8s ratchet and put a little effort into it. not much though.
11. On cylinders 3 and 4 when its numbered qith the passenger side going numerically, youll need a swivel. itll be a tight squeeze into those, but youll be fine.
On cylinder number 4, go behind all the hosing and put the socket in fropm the backside. youll see what I mean
Old July 22nd, 2008, 05:33 PM   #34
2002 mustang gt
throttle didnt get in you way? and can i just undo my intake from the top or do i have to take it all the way out
Old July 22nd, 2008, 05:42 PM   #35
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
you undo the intake from the throttle body. the TB does not get in your way whatsoever. the only things that gets in the way are the injectors, but you can work around them.
Old July 22nd, 2008, 05:44 PM   #36
TyCouey2000GT is an unknown quantity at this point
I can get up to 280 a tank
Your Average GT
Old July 22nd, 2008, 05:44 PM   #37
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
thats all you need. And yes its a 5/8s spark plug socket. theres an old spark plug that I took out of mine in the socket to show you...
also when tightening down the plugs, put sctoch tape/duct tape around the socket and swivel. the socket will want to stay with the spark plug when you try to pull up
Old July 22nd, 2008, 05:44 PM   #38
2002 mustang gt
o ok dont have a spark plug gauge or anti seize
Old July 22nd, 2008, 05:47 PM   #39
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
they have it at the auto parts stores lol just ask
Old July 22nd, 2008, 05:49 PM   #40
The Mean Green
MATT02GT's Avatar
MATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really nice
The stock platinum plugs are good for more than 49k especially if you car is mostly stock. It wouldnt hurt to change them, I just wouldnt pay someone to do it for you yet. But its a cake job if you have a lil mechanical know-how
Bolt on list in Garage..
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/81295-gas-mileage.html
gas mileage - Page 2 This thread Refback July 22nd, 2008 05:25 PM
Threads Similar to: gas mileage
gas mileage dgt_mustang V6 Mustangs 85 March 4th, 2008 04:07 PM
V6 gas mileage Racerchik02 The Clubhouse 62 June 12th, 2007 07:23 PM
My gas mileage has gone up some how ujslost 96-98 10 April 1st, 2007 10:37 PM
Gas Mileage? Blue98GT 96-98 2 October 22nd, 2006 11:48 PM
Gas Mileage? oldernewbie General Tech 19 October 9th, 2006 03:37 PM
