Boost gets you laid
installing my procharger!!! few questions though.
ok, my procharger finally came and is halfway installed! sorry for not giving everyone the update, but it all came and all the parts and pieces were there
. the head unit is in perfect condition, everything except for the air filter and also the L bracket for the upper intercooler mounting flange (i don't even know what this is, it just says in the instructions and its not there). so far i have the injectors, fuel pressure switch, head unit, intercooler, piping, and belt hooked up but i need a little help. so, couple questions... 1) how do you run the MAF plug to the MAF? its relocated into the fender and the wire is way too short, how should i fix this? 2) does anyone know how the upper part of the intercooler (flange) connects to the hood latch support? 3) the rubber connector for the maf is made for the stock maf. i have a 90mm maf and need a 4" inner diameter piece of tubing to fit over the bigger maf, and the rubber connector has to be tapered to be able to accomodate the 2.5in piping that connects to the other side of the rubber connector.. anyone know where i can get something like this? also, if anyone knows where i can get a decent Blow off valve and an air filter for a decent price please let me know.
![]() '01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress 2003 Rubicon (wheelin rig) 2008 Silverado 4x4 (towin rig/road queen) 2009 KTM 450 XC-W (Brap Brap!) |
1) you add an extra length of wire to each of the wires in the harness
3) you can get all kinds of silicone reducers and hoses on ebay or just search on google for silicone reducers.. if your maf is only 90mm why do you need a 4" hose? I had a 100mm maf that needed a 4" hose. I bought a Greddy Type-RS bov on ebay and it sounds good and I bought a K&N air filter but its up to you if you want to pay that much.. originally I bought one of the universal filters at autozone
Vortech V2 Si
The Mean Green
1. I just unclipped the harness and was able to make it reach the MAF.
2. You dont re-use the that support bar, the hood will still close fine. Just toss that.
I Poop Entirely Way Too Much
Blown 03 GT
Your MAF is in the fender, is it before the s/c?
#5 | |
Boost gets you laid
The Mean Green
Its in the fender, after the blower and i/c
#7 | |
~C~, The Other White Meat!
BLOWN Bumblebeast! 370 rwhp / 381 ft lbs ![]() ~Tuned by JJ at WMS ![]() "Like the blind man says......We shall see...."
Why do you have a maf that big? You are going to lose a lot of down low resolution in your tune and the bigger maf isn't going to help if it's mated to 2.5" piping. I would get a powerpipe if I were you then it would be 4" all the way to the supercharger.
Vortech V2 Si
#9 | |
Boost gets you laid
the maf is after the supercharger, its blow through. and i don't know, it just came with the kit.. i measured the stock maf and its about 3 inches in diameter so its not like 4 inches is all that huge compared to stock. i dunno though i'm new at all this stuff this is the first supercharger i've ever installed.
#10 | |
Vortech V2 Si
Boost gets you laid
well it has a reducer but its just not big enough.. i'm heading to the mustang shop right now to see what they say i'll keep everyone updated.
Boost gets you laid
i just got a reducer, air filter, and greddy type s blowoff valve.. they gave it all to me for free too! i gotta give the guy $50 for the BOV next time i go down there though. still a killer deal.
Threads Similar to: installing my procharger!!! few questions though.
| need help installing | disturbdgt | 99-04 | 3 | May 14th, 2008 12:56 PM |
| Installing x pipe questions | sorrowfulkiller | 96-98 | 17 | November 6th, 2007 03:00 PM |
| procharger kit questions | 95Pony | General Tech | 4 | October 12th, 2007 10:51 PM |
| Procharger Questions | MATT02GT | 99-04 | 12 | September 27th, 2007 10:36 PM |
| Procharger Questions | hawks05 | 99-04 | 5 | March 6th, 2007 11:26 PM |
