LinkBack (1) | Thread Tools |
#41 | |
2001 Mustang GT
12.4@111 (N/A)
![]() iTrader: 1 reviews
My CR is 10.54:1 and you are close on my cams specs, but like you I don't like to post them up (especially since the grinds belong to Tim)
12.4 @ 111mph N/A 2V... (first trip out) in desperate need of a driver mod ![]() N2O times coming soon my junk at the track
#42 | |
2001 Mustang GT
12.4@111 (N/A)
took my car to the track today, and ran a 1.60 on 17" nittos I hope this wasn't referring to me...
#43 |
MM's Mad Scientist
Slow Fella
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
Yeah the cams and slight compression difference is probably where the power difference is.......
#44 |
MM's Mad Scientist
Slow Fella
Cam spec.s
Intake: 250 degrees @ .050" lift Exhaust: 246 degrees @ .050" lift ,545" lift both sides 110 degrees of lobe seperation I'm over it..........
#45 |
^ wow. I didn't expect that
#46 |
2001 Mustang GT
12.4@111 (N/A)
you had to flycut your pistons for those cams, right? What a/f are you running?
#47 |
someone explain those specs
#48 |
Genibus Nitito Canus
^+2
Red 1996 GT: JLT RAI, Steeda Underdrive pullies, Stewart Waterpump; nothing to brag about Black 2009 45th aniverary edition GT 5 speed: K&N CAI, BBK Twin 62mm Throttle Body, BBK Underdrive Pullies, muffler delete ![]() |
#49 |
Never Ran er!
^ I hope this helps I did a lab on an old diesel engine at my school
Objective: To obtain the timing circle of a diesel engine. Abstract: We turned a diesel engine about its flywheel and took measurements using a rod and top dead center (T.O.D.) and bottom dead center (B.O.D.) as a reference. Using masking tape on the flywheel we marked the various points of timing and in the end with simple calculations found the degrees at which it all occurred, than we displayed it on a four cycle timing diagram. Data: Measurement From TDC (in), Measurement From BDC (in), Angle Ahead or Behind (Degrees) Intake Opens: 1.18, 36, 7.17 Intake Closes: 37.50, 4.75, 228.81 Exhaust Opens: 27.00, 1.125, 164.75 Exhaust Closes: 2.19, 32.5, 13.36 Beginning of Pump Stroke (Injection) Open: 56.50, 27.5, 344.75 Circumference (in), bottom dead, top dead 59, 29.25, 31 Sample Calculations: (1.18/59)*360 = 7.17 degrees (37.5/59)*360 = 228.81 degrees (27.0/59)*360 = 164.75 degrees Results: 1.
#50 |
Never Ran er!
Hey ACmiller did you custom design those specs on your cam or did a shop do em for you?
#51 |
^^ i think he worked with comp on them..
#52 |
MM's Mad Scientist
Slow Fella
Yes, and it makes the best power around 12.5:1........
#53 | |
MM's Mad Scientist
Slow Fella
I came up with those...... However, I saw that Comp is peddaling the exact same grind to customers now.......
#54 |
2003 Mustang GT
12.28 @ 116
![]() ![]() iTrader: 11 reviews
After reading those cam specs I was like damn thats got to have a nice lopey sounding idle lol.
![]() 2003 Sonic Blue GT---SLP Longtubes, SLP X, Magnaflow Magnapack CB, 75mm TB/Plenum, MP2 Performance stage 2 heads, MHS Stage 3R cams, Built rear w/4.30's |
#55 |
MM's Mad Scientist
Slow Fella
#56 |
Never Ran er!
So I see you have a general knowledge in kinematics, I am reading a book on it right now, btw sounds sweet.
#57 | |
2003 Mustang GT
12.28 @ 116
And AC your car sounds amazing! I will probably be emailing you once i get closer to my build.
#58 |
holy shit that sounds means as hell!
BULLITT CREW #5 LT GTB mufflers for sale
#59 |
That sounds freakin nice!!
Noob question here but what part of the cam specs gives it that awesome idle or lope. is it the 110 degrees of lobe seperation? How close to that sound can you get before having to notch the pistons? |
#60 | |
2001 Mustang GT
12.4@111 (N/A)
an easy way to figure out how much chop (or lope) a cam will have is like this: The more overlap the choppier the sound. Figuring Overlap Of A Cam - Add the intake and exhaust durations - Divide the result by 4 - Subtract the LSA - Multiply the results by 2
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/81580-recipe-350-rwhp-na-2v.html
| Rings - Page 5 - LouisvilleMustangs.net | This thread | Refback | October 27th, 2011 11:38 AM | |
Threads Similar to: Recipe for a 350 RWHP NA 2V
| Recipe for a Kenne Bell GT | DSG04GT | 99-04 | 21 | September 2nd, 2008 04:19 PM |
| I need to get 350+ hp out of this | fordboy4rd | 5.0 Mustangs | 8 | April 30th, 2008 11:19 AM |
| hang over recipe | Trance | The Clubhouse | 15 | March 28th, 2008 02:19 PM |
| My Special Recipe :) | TheUNZippee! | The Clubhouse | 30 | November 3rd, 2007 02:46 PM |
| gt 350 | boostmaniac | 5.0 Mustangs | 0 | July 30th, 2006 04:11 PM |
