2003 Mustang GT
new intake mani?!
AM just posted up a the new and improved? professional products typhoon intake manifold. any info on it?
It claims 21.5hp over stock. I find that hard to believe with just the swap of an intake. Maybe with some other goodies workin with it. But it looks kinda cool.
Check my garage for pics and mods! ![]() Originally Posted by svtkidd23 if my gears were a vagina.. id beat it up! |
MM's nicest mod, :)
once junk always junk, again everyone for the money our stock intake's work just fine. There are a million other things that will help the car go faster and run better for the money than a crappy intake
06 Dodge MegaCab Diesel 455rwhp/815rwtq REAL TRUCKS DON'T USE SPARK PLUGS |
Save your money and get a blower
![]() 2004 Comp Orange GT - SLP Loudmouth, Pypes O/R X Pipe w/mils, Steeda Tri-ax, JLT Ram Air |
Genibus Nitito Canus
well someone is gonna buy one so i guess we will find out if they are worth a crap
Red 1996 GT: JLT RAI, Steeda Underdrive pullies, Stewart Waterpump; nothing to brag about Black 2009 45th aniverary edition GT 5 speed: K&N CAI, BBK Twin 62mm Throttle Body, BBK Underdrive Pullies, muffler delete ![]() |
I was thinking about the typhoon, I was told the shorter runner length is better for spray. Is that true? If so is it worth the money then?
![]() 2001 GT Stang "Bullitt #5583 wanna-be" Best ET 13.8 104mph (b4 motor/gear) D.S.S. ProMod ShrotBlock, DiabloSport Predator, Steeda TriAX, FRPP 4.10s & D-shaft, FRPP 24# injct, Flowmasters, 03 Cobra Brakes, one awesome tune & much more ;] |
ive always been told and read shorter for FI
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
there are pros and cons to runner length. runner lenght, plenum area, induction type, etc are all factors in selecting an intake manifold. like any other intake discussion, the stocker is fine for 90% of the 99+ gt's.
which is y i wont be buying an aftermarket one
2003 Mustang GT
i wont either i was just wondering
#11 | |
Theres so many different aspects to the design of an intake manifold that it's unreal...So many of the ones you see, even the high quality ones like Edelbrock, use short runners which do give you more horsepower, if it can run at 7-8k rpms. And most of them tell you you need heads and cams to see the gains that they have. Then they talk about increased airflow and plenum area, and the problem there can be unless you've got huge horsepower you're losing velocity, and therefore more low end torque which the 4.6 is already lacking anyway... Frankly what someone needs to do is just remake the factory manifold in aluminum...The closest that I've seen to that is this one even then, that's really only useful if you're going to be pumping outrageous amounts of boost or something through it and you've cracked your factory one. For most of us, it's just not a worthwhile mod and most intake manifolds can cause you to lose power anyway.. |
If I break another intake im getting the typhoon, tired of this cheap plastic junk.
Eww stay away, once junk, always junk made in taiwan crap
![]() Single 67mm turbo, ported pi heads, edelbrock vic jr. manifold w/HPP plenum, terminator shortblock, return fuel system... Goal 600+ rwhp. |
Well it may be plastic but atleast it doesn't heat soak like a aluminum manifold, any aftermarket manifold will just add weight and kill your power unless you got serious mods, that being 500+rwhp. The stock PI manifold is great.
just wondering how in the hell you keep breaking intakes? yo have to be doing something wrong to break one. ive been spraying a 150 shot through mine for qute awhile now and have only lost one and thats becuase the solonoids stuck open and caused a backfire.
03 Mach 1
Too slow
As one who is currently using a Professional Products Typhoon intake and fuel rail system I can speak from experience that the quality of the products are not worth wasting your money on. In the first place, there was NO horsepower gain at all. Also, in the 3 months I have had the intake on, one of the fuel injector mounts broke off, and I have had 2 bolts holes strip out including one that bolts my plenum down. The fuel rails look cool, until you rub one or bump something against it and the blue color comes right off! Very terrible craftsmanship all around! I would not recommend either one of these products. If you really feel the need to change the intake, I would say go with the Trick Flow Trackheat.
JLT CAI, Plenum Spacer, Steeda Triax, Aluminum flywheel and Driveshaft, 373 gears, Moser 31 spline axles & LPW diff cover, SSS ehaust, Sniper Tune, MT ETs, NX 150 Wet Shot, MSD window switch, MSD 2-Step. |
I have a fully ported tyhpoon and it seems to work pretty good. It took a little work to get it mounted. I felt a decent gain up top with it, and I ran .2 faster in the quarter. Dunno if it was all the intake buts thats the only mod Ive done since I went to the track last. Its not the best intake, but I got a decent deal on it.
Its not how fast you drive, but how you drive fast. 2002 Mustang GT... Just The Usual Bolt-Ons ![]() ![]() Bolt on list in Garage.. Last edited by MATT02GT; July 28th, 2008 at 12:05 PM. |
hey guys what is everyone's feeling on this intake?
Trick Flow Specialties TFS-51800002 - Trick Flow Track Heat Intake Manifolds for Ford 4.6L 2V - summitracing.com |
Proud American
What do you start spraying at?
Threads Similar to: new intake mani?!
| Stock intake mani? | 93HatchsBFF | 99-04 | 13 | July 18th, 2008 09:59 PM |
| GT 40 intake mani off explorer | 93hatch | 5.0 Mustangs | 12 | February 21st, 2008 07:31 PM |
| heads cams intake mani | nHuman | 96-98 | 3 | February 19th, 2008 12:32 AM |
| PI intake mani, and injector size | josh95mx | 96-98 | 3 | December 27th, 2006 01:05 AM |
