!FACEPLATED!
Traction...........
I have a 2002 Mustang GT running Nitto Drag Radials and I can't seem to get them to hook off the line. I have my 2 step set at 3k and running 15 psi in the tires. Any suggestions? I also have a video I could upload if you want to see.
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ |
![]() iTrader: 1 reviews
heat em up
Just Another Bolt on GT [IMG]http://i45.tinypic.com/54f5ua.jpg[/IMG] Stock Longblock - 287/276 Low 12s NA! 10s on the spray? |
!FACEPLATED!
They got heated. I was told that with the Nitto you really have to heat them up so I probably did a 10 sec burnout. Think I should do longer?
you auto or 5 speed?
!FACEPLATED!
5 speed.
!FACEPLATED!
Actually I'm Running the same size tire you are.
you feather the clucth out?
!FACEPLATED!
When I left off the 2 step it was the last run of the night and I just dumped the clutch and went. It spun through 1st and still had a 13.57. The other times I left aggresively off the clutch
#9 | |
rite around 4500 the clcuth is all the way out and the gas is at WOT i dont spin at all...
!FACEPLATED!
Alright, I'm going friday night. I'll see what I can do.
if you just dump the clucth your def gonna spin like crazy tho lol
!FACEPLATED!
With drag radials and the traction additive at the track they shouldnt spinat 3k. Theres NMRA guys leaving the line at 10k on drag radials
#13 | |
![]() and i know for a fact if a i luach at 2500 and just side step the clucth ill spin a little you gotta feather it out
!FACEPLATED!
Yeah these were only to get me through the year. Next year I'll be running Hoosers on 15" Weld Pro Stars
wat other mods you have?
2001 Mustang GT
8.9@78
![]() iTrader: 2 reviews
I assume he is talking about a full prepd track man..huge differnce. I dumpd my clutch at 2500 and it scared me how good i hooked on my BFGs. Try a longer burn out..are maybe go to a wider tire. I have 315s so that might be the issue
Fire it up, burn it down.
well he said he stepped off the clucth and spun through first....
2001 Mustang GT
8.9@78
Ya something is not right..with drs..lower pressure and a prep'd track he should have no problem hooking on nitto dr's. I feather the clutch so i dont break my stock rear..but damn if i do when that gets beefed up..i cant wait to drop the car at a good rpm and see what those expensive tires can really do
#19 | |
2001 Mustang GT
8.9@78
I think yall need to get a wider tire on there...315 ftw.
Threads Similar to: Traction...........
| Help I need Traction | MustangOne | Classic Mustangs | 17 | August 4th, 2008 01:29 PM |
| traction Q | obdnanr | V6 Mustangs | 6 | February 27th, 2008 06:35 PM |
| Traction help! | cammed281 | 99-04 | 6 | June 25th, 2007 09:12 AM |
| Traction....I need some | chase | 5.0 Mustangs | 6 | February 24th, 2007 11:38 PM |
| Traction | acehole | 99-04 | 11 | November 18th, 2006 09:01 PM |
