LinkBack (1) | Thread Tools |
#1
87 Coupe
![]() iTrader: 3 reviews
UPR firewall adjuster speed clutch quadrant
Anyone running thoe, and what do you think? I'm leaning towards getting them because I've always had good luck w/ their products.
Eats rice daily
87 Coupe
Anyone have an opinion on them from what they might have heard??
Eats rice daily
N/A 4v Guru
2003 Mach 1
I have the full UPR setup but I don't have enough miles with it to say great or not. If feels good though it is kinda hard to adjust. But again I haven't driven enought with it to realy say.
![]() Military Crew U.S. Army Aviation Apache's Lead The Way |
87 Coupe
I was told the stock cable is better to keep in and just use the quadrant and firewall adjuster. I think I'm gonna go w/ it. If it feels good and I've always liked the products I got from them then should be fine.
Eats rice daily
I have been running their triple-hook quadrant and "Quick-click" adjuster for 35k miles or so (stock cable). Very pleased with it...
-cliff knight- My Mustang 2003 GT, UPR X, FRPP 24lb/h injectors, Magnaflow, 180° stat, PP 70mm TB & plenum, Delta Force Commando, Steeda UDPs, Ralco RZ_flywheel, RAM HDX clutch 3.73s, 262 rwHP/305 ft.lb. Flex-fuel: burns gas and rubber... |
N/A 4v Guru
2003 Mach 1
Yea the only reason I got the cable was because I was automatic and I needed the whole clutch setup up so I just bought the whole kit with triple hook, adjuster, and cable
87 Coupe
cool.....I'm thinkin bout gettin the speed quadrant not the triple hook. Don't think I need the triple. Glad you guys have liked yours though cuz it makes me hope it will be as good for me.
Eats rice daily
i have the UPR triple hook and firewall adjuster with the stock cable and i have nothing bad to say about it. has the same release every time.
03 GT 5sp, K&N FIPK, MAC LT ceramic coated headers, MAC Prochamber, Steeda Tri-ax, 3.73, SCT X-cal2 tuned by D&G Dyno Tune, NX plate Kit, Eibach Pro Springs, CMS Stage 2 cams. STRIKE design from MK Motorsports. |
You will likely have to use an adjustable cable with the speed quadrant.
87 Coupe
What makes you say that cliffyk??
Eats rice daily
87 Coupe
Some of the guys I've talked to say get those and stay w/ the stock one that most aftermarket ones are garbage.
Eats rice daily
Mostly because that's what the people at UPR told me, the speed quadrant hook is so far "back" that the OEM cable may not work...
I was going the get the speed quadrant, but having to use (maybe, apparently some OEM cables will work) an adjustable cable soured me on it after the numerous tales of woe I've heard re: aftermarket cables--even Steeda's...
i have a steeda firewall adjuster, and double hook qaudrent and the stock cable works good with it
2004 Black Mustang GtWhen I see a 5.0...I respect my elders. |
87 Coupe
Guy at american muscle said keep the stock cable. not too sure. Might get the triple hook if it looks like it will be a prob keepin the stock cable(which is new)
Eats rice daily
The speed release quadrant noticably increases the pedal effort. This is just basic mechanical principles at work--doing "x" amount of work in less time requires more force.
It's not absolutely horrible once you get used to it, but you will notice it...
87 Coupe
Understand that. We'll see. I'll talk to the UPR guys and see what they recommend.
Eats rice daily
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/82489-upr-firewall-adjuster-speed-clutch-quadrant.html
| UPR firewall adjuster speed clutch quadrant | This thread | Refback | July 30th, 2008 06:22 PM | |
Threads Similar to: UPR firewall adjuster speed clutch quadrant
| Steeda Clutch Adjustment Quadrant, Cable, Firewall Adjuster. | fallstar01 | Parts | 4 | August 26th, 2010 02:51 PM |
| Quadrant,firewall adjuster, adjustable clutch cable | silver99gt | 99-04 | 2 | March 11th, 2008 12:21 AM |
| upr clutch quadrant and fire wall adjuster | ujslost | Parts | 0 | April 19th, 2007 12:32 AM |
| Clutch quadrant and Firewall adjuster | ujslost | 96-98 | 4 | April 15th, 2007 08:39 PM |
