stock compression ratio
Old August 1st, 2008, 06:24 PM   #1
2002 mustang gt
13.5 @ 106
mustangjl is on a distinguished road
what is the stock compression ratio for a 2002 mustang gt?
mods: flowmaster catback,75mm tb,3.73,sct x3,turbo 70mm-10psi,3 core intercooler,injected engineering tune,mph blower cams. 450hp/460tq
fastest et 13.3@114
bowties are for little boys
Old August 1st, 2008, 06:52 PM   #2
Resident Bubblehead
00vabchgt's Avatar
00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough
Submariners Do It Deeper
Military Crew
MM1 (SS)
Order of the Bluenose
US Navy Veteran
Originally Posted by MamaStang View Post
"Boy Danny....nice cock ya got there. "
Old August 1st, 2008, 08:49 PM   #3
PowerShiftz02GT is just really nicePowerShiftz02GT is just really nicePowerShiftz02GT is just really nicePowerShiftz02GT is just really nicePowerShiftz02GT is just really nice
iTrader: 13 reviews
What do you have to do to take this test. i work at a dealership but and i want a mechanic to check mine but if its a big job, then forget because ill have to give them a little bit of money. But what does this process involve?
Old August 2nd, 2008, 01:01 AM   #4
cliffyk's Avatar
cliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of light
You cannot directly "test" the compression ratio, it is a physical/mechanical property of an engines design and represents the cylinder/combustion chamber volume at BDC divided by the cylinder/chamber volume at TDC.
It can be sort of inferred from cranking compression values, but not really.
The compression ratio for the '03 GT 4.6L 2V is listed as 9.74:1 in the '03 factory shop manual, I believe the '02s are the same.
-cliff knight-
My Mustang
2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat,
PP 70mm TB & plenum, DF Commando, Steeda UDPs,
Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs
3.73s, 262 rwHP/305 lb-ft.
Flex-fuel: burns gas and rubber...
Threads Similar to: stock compression ratio
stock 5.0l (89 gt) compression ratio EscortSportage 5.0 Mustangs 6 May 25th, 2008 05:25 PM
Compression Ratio invisa stang 5.0 Mustangs 8 January 8th, 2008 06:28 PM
Compression Ratio itschristorres8 V6 Mustangs 22 December 1st, 2007 01:46 PM
stock compression ratio and combustion chamber volume??? 83five0 5.0 Mustangs 1 May 15th, 2007 06:12 PM
96 gt compression ratio 96_gt_stanger 96-98 3 March 2nd, 2007 11:52 PM
