96-04 engine block...
is the block in the 96-98 gt's different from the 99-04 block?
black 96 gt w/ non pi motor, cai, built t45, built rear end w/ 3.73's, completely modded suspension, race radiator.....startin over.www.rk-collection.com |
![]() iTrader: 1 reviews
you asking just about the block or about the heads and cams as well?
Just Another Bolt on GT [IMG]http://i45.tinypic.com/54f5ua.jpg[/IMG] Stock Longblock - 287/276 Low 12s NA! 10s on the spray? |
i think the block is the same
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
block alone, not really. there are the windsor and romeo castings. that all that i can think of off the top of my head.
im just talking bout the block. i have the 96 block and i think i may have cracked the block thats in the car which is a 2000 block...whats the difference, and can i use the block from the 96?
mm's nitrous mod
2000 mustang gt
yes
Just out of curiosity, why do you think you cracked the block?
Accufab 75mm tb & plenum MRT h-pipe Flowmaster catback FRPP king cobra clutch FRPP aluminum driveshaft FRPP 4.10 gear TA Perfromance girdle Steeda tri-ax shifter Moser 31 spline axles FRPP C Springs |
If your using the 96 in your 2000 you'll notice a slight compression bump
![]() Single 67mm turbo, ported pi heads, edelbrock vic jr. manifold w/HPP plenum, terminator shortblock, return fuel system... Goal 600+ rwhp. |
how much of a compression bump? i was thinkin about just gettin a new motor from vt if its cracked cause i have another vehicle now and i can let the mustang sit while i save up money.
goodluck on getting a motor from vt
#11 | |
J/KYou will only see a increase if you use the pistons from the 96......
get a mmr motor way better
Resident Bubblehead
with the pistons from the 96 and the PI heads, you should see about 10.5:1 compression...
+ 1.
I've been happy with mine for almost 3 years.
2000 GT 665/540rwhp/rwtq On pump gas Best 1/4 638hp street tune 11.01, best trap 134MPH, 80*+day, 10.5" DD Cobra R's & 315/35/17 DR'S DYNO VID ---> http://www.youtube.com/watch?v=K9uOS732mdA |
!FACEPLATED!
If you use a whole short block yes. The dish in the top of the pistons isnt as large as the ones in the 99-04s I believe. MM&FF I believe did a write up on it. Putting the PI heads and intake boosted the compression
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ |
Threads Similar to: 96-04 engine block...
| 99-04 GT engine block | 00GT | 99-04 | 19 | July 10th, 2007 09:42 PM |
| engine block | 88mstang | 5.0 Mustangs | 5 | June 18th, 2007 04:05 PM |
| Mach 1 engine block? | JAY'SRED02 | 99-04 | 12 | June 4th, 2007 03:23 PM |
| 3.8l engine block | 98Stang | V6 Mustangs | 3 | January 31st, 2007 11:56 PM |
