T45 specs?.....
LinkBack (5) Thread Tools
Old August 3rd, 2008, 06:43 PM   5 links from elsewhere to this Post. Click to view. #1
prodrifterx's Avatar
prodrifterx is on a distinguished road
Send a message via AIM to prodrifterx
T45 specs?.....
i am and have been searching for info on this....hoping someone will aid me in the search of what each gear was/is for a 1999 mustang gt t45.
1st
2nd
3rd
4th
5th
i am debating and weighing in the options/ideas of tko500, tko600, t56, & t45 transmissions being swapped in...i want more of a close ratio transmission than factory....mainly when going from 3rd thrr 5th....thinking of a 6speed because i could still get decent driving out of the car when going to work...nonetheless i could better figure which gear i would want to go with in the rear end once i am able to determine such factory trans specs and then can compare them to other factory or aftermarket trans specs in order to optimize the gearing in the car.
so any info on the t45 specs would be great.
Originally Posted by Fryrice View Post
You cant buy horsepower off a Autozone shelf. If you wanna play you gotta pay.
Old August 3rd, 2008, 06:47 PM   #2
this is what i found on allfordmustangs.com------
Borg Warner T45 5 speed manual transmission has an aluminum alloy gear case, tail housing and bell housing. The T45 is used only behind the 4.6L Mustangs from 1996 to 1999. Tremec replaced the T-45 with the Tremec 3650 in 2000. It has single rail gear selector and carbon lined steel synchronizer rings. The T-45 installed in the 1996-1998 GT Mustangs is different than the Cobra Mustangs. The transmission mount position and speedo gear are the main differences. The Mustang Cobra T-45 has a 7 tooth speedo gear. The Mustang GT T45 has an 8 tooth speedo gear. In 1999 all T-45's were changed to the Cobra specs. The T45 case casting number is “1381”. The Mustang T45 has an input torque rating of 325 ft-lb and the standard gear ratios on the Borg Warner T45 and Tremec T45 are: 1st Gear: 3.37, 2nd Gear: 1.99, 3rd Gear: 1.33, 4th Gear: 1.00, 5th Gear:, 0.67, Rev Gear: 3.22--------------------is this correct bc i thought these numbers were for the t5 that existed in the 2000 v6 mustangs.
rep for help on this info.
Old August 6th, 2008, 07:04 PM   #3
bump.............these numbers right?
Old August 6th, 2008, 07:07 PM   #4
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
TTC: TREMEC Transmissions
Old August 6th, 2008, 07:22 PM   #5
thanks again....2nd time u help me.......are you stalking me lol?
Old August 6th, 2008, 07:32 PM   #6
Resident Bubblehead
00vabchgt's Avatar
00vabchgt is just really nice00vabchgt is just really nice00vabchgt is just really nice00vabchgt is just really nice00vabchgt is just really nice
the T45 was used till mid 01
Submariners Do It Deeper
Military Crew
MM1 (SS)
Order of the Bluenose
US Navy Veteran
Originally Posted by MamaStang View Post
"Boy Danny....nice cock ya got there. "
Old August 6th, 2008, 07:32 PM   #7
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
of course sexy..
Old August 6th, 2008, 07:35 PM   #8
lol.....aw shucks.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/83027-t45-specs.html
T45 specs?..... This thread Refback May 14th, 2012 12:33 PM
T-45 Differences - SVTPerformance This thread Refback May 3rd, 2011 08:22 PM
Info.com - t45 transmission - www.Info.com This thread Refback February 16th, 2011 12:28 PM
T-45 Differences - SVTPerformance This thread Refback September 27th, 2008 08:00 PM
Threads Similar to: T45 specs?.....
tr3650 t45 mystang0673 99-04 5 March 18th, 2008 03:34 AM
t45 jkovacs60 99-04 1 February 21st, 2008 07:23 PM
t45 RC02GT 96-98 13 February 20th, 2008 07:28 AM
T45 mantis99 V6 Mustangs 4 November 2nd, 2006 03:31 PM
shifter for a t45 wolffer 96-98 3 August 21st, 2006 07:41 AM
